Updates for Icinga Web Graphite and GenericTTS Integrations
by | Nov 30, 2022
Today we’re announcing the general availability of Icinga Web GenericTTS Integration v2.1.0 and Icinga Web Graphite Integration v1.2.2.
What’s New
Both releases are mainly defined by several maintenance tasks. But of course, we wouldn’t announce them on the blog without having at least something for you, our trusty readers, in store.
  • Graphs are displayed again even if the monitoring module is not installed
  • Thanks to a community contribution: Graphs retain their aspect ratio now if a template defines a different width or height than the default
They are Twins!
Well, not identical. But both are available as package from Icinga now! Just remove the current installation and install the icinga-graphite and icinga-generictts package.
In case of the Graphite integration you should make a backup of the default templates, if you have adjusted them in the past. Templates that are stored as part of the module configuration are safe and will not be affected.
Icinga Director 1.12 Release
