Understanding Observability, Monitoring, and Telemetry Differences
by | Jan 20, 2025
Last updated on September 24, 2026
Observability vs. Monitoring vs. Telemetry: Key Differences Explained
Monitoring, observability, and telemetry are three related but distinct concepts in IT operations, and they are easy to mix up. Telemetry is the process that collects and transmits data from your systems. Monitoring watches that data and alerts you when a known threshold is breached. Observability uses the same data to explain why a system behaves the way it does. Put simply: telemetry gathers the data, monitoring watches it, and observability interprets it.
The distinction matters because each answers a different question. Monitoring answers “what is happening?”. Observability answers “why is it happening?”. Telemetry answers “how is the data gathered in the first place?”. This post looks at each one, where they overlap, and where a tool like Icinga fits.
Observability is the ability to understand a system’s internal state from its external outputs – its metrics, logs, and traces. It tells you not just that something broke, but why.
Monitoring collects performance data and checks it against known thresholds. When a value crosses a limit, it alerts. This is how you catch the problems you already know to look for.
Telemetry is the automated collection and transmission of data from remote or distributed systems. It is the raw input that both monitoring and observability depend on.
Defining the Terms: Observability, Monitoring, and Telemetry
Observability
Observability is the ability to understand a system’s internal state from its external outputs – its metrics, logs, and traces. A system is observable when you can work out what is going on inside it without adding new instrumentation for every question you have.
The point of observability is the “why”. Monitoring can tell you a service is slow. Observability helps you trace that back to the database call, the queue, or the deploy that caused it. That matters most in systems too complex to hold in your head, where the failure you are debugging is one you did not anticipate.
Monitoring
Monitoring collects performance data and checks it against known thresholds. When a value crosses a limit – CPU over 90 percent, a service down, disk nearly full – it raises an alert. This is how you catch the problems you already know to look for.
Monitoring is largely reactive by design, and that is a feature, not a flaw. You define what “healthy” means, and the system tells you when reality drifts from it. When something breaks, monitoring tools notify the right people so they can act before users notice.
Telemetry
Telemetry is the automated collection and transmission of data from remote or distributed systems. It is the raw input that both monitoring and observability depend on. No telemetry, nothing to watch or interpret.
In distributed setups, telemetry is what makes the data from dozens of hosts, containers, and short-lived services available in one place, continuously, without anyone collecting it by hand.
Observability vs. Monitoring: What’s the Difference?
Monitoring tells you that something is wrong. Observability helps you understand why. Monitoring works from predefined metrics and thresholds; observability works from the full picture of metrics, logs, and traces and lets you ask questions you did not plan for in advance.
Monitoring Observability Telemetry
Purpose Track system health and performance Diagnose and resolve complex issues Collect and transmit system data
Scope Predefined metrics and alerts Logs, metrics, and traces Metrics, logs, and traces
Reactive/Proactive Reactive Proactive and investigative Foundational
Key Questions “What is happening?” “Why is it happening?” “How is data gathered?”
The two are not competing approaches. Monitoring is a part of observability, not an alternative to it. You still need thresholds and alerts for the known failure modes; observability adds the context to investigate the ones you did not see coming. Most teams run both, and the line between them is where a lot of monitoring tools are evolving.
Where exactly that line sits depends on scale. A 50-host environment and a 5,000-host enterprise environment put different demands on configuration ownership, engineering time and data retention. We cover what it takes to run monitoring and observability at scale in a webinar with Kris Buytaert (DevOps and Open Source Expert) and Blerim Sheqa (COO Icinga).
Telemetry vs Observability: How They Intersect
Without telemetry, monitoring and observability have nothing to work with. Telemetry moves data out of your hosts, containers, and network devices and into the tools that analyze it – continuously, and without someone logging in to collect it. In distributed and cloud-native setups, where the data you need is spread across dozens of short-lived components, that automated flow is the whole point.
For years, getting telemetry data from one system into another meant a custom exporter and some glue code for every backend. That is the problem OpenTelemetry set out to solve. OpenTelemetry (OTel) is a vendor-neutral, CNCF-backed standard that defines one common format for metrics, logs, and traces. A system emits its data once, in OTLP format, and you route it wherever it needs to go.
Icinga 2 supports this directly. Since v2.16, the OTLPMetricsWriter exports monitoring metrics in the OpenTelemetry format to Prometheus, Grafana, Datadog, or any other OTLP-compatible backend – no middleware, no custom exporter in between. Your monitoring data and the rest of your telemetry end up in the same place. For the full setup, see the Icinga 2 OpenTelemetry integration blog post.
The Three Pillars of Observability: Metrics, Logs, and Traces
Observability rests on three types of data, often called the three pillars: metrics, logs, and traces. Each answers a different part of the question, and you usually need all three to get a full picture.
  • Metrics are numeric measurements over time – CPU usage, memory consumption, request rate, error count. They are cheap to store and good for spotting trends and triggering alerts, but they tell you that something changed, not why.
  • Logs are timestamped records of events. They carry the detail metrics leave out: the exact error, the request that failed, the config that was loaded. Logs are where you go once a metric tells you where to look.
  • Traces follow a single request as it moves across services. In a distributed or microservices architecture, a trace is what shows you which hop in a chain of ten added the latency.
Metrics point you at the problem, logs explain it, and traces tell you where it happened. Collecting all three – and keeping them together – is what turns raw metrics and logs into something you can actually reason about.
Reducing Alert Fatigue with Better Observability
Alert fatigue happens when a system sends so many alerts, many of them not actionable, that the people on call start ignoring them. It is one of the most common ways a monitoring setup quietly stops working, because the alert that matters gets lost in the noise.
Better observability data helps because it lets you make alerts more specific. Instead of firing on a single raw threshold, you can build alerts that account for context – is this spike normal for this time of day, is the dependency already down, is this the cause or just a symptom. Fewer, sharper alerts mean the ones that do fire are worth reading. If your team is drowning in notifications, it is worth reading more on why alert fatigue happens and how to reduce it.
Icinga: Open-Source Infrastructure Monitoring and Observability for SysAdmins
Icinga has been around since 2009, and it is open-source with no investors and no shareholders behind it. That independence shapes what it is: monitoring built by and for the people who run it, not a product steered by a funding round. It covers both sides of this post – tracking the state you already watch, and exporting the metrics and logs that make a system observable.
Where Icinga earns its place is configuration and scale. You define checks in the web UI, in the Icinga Director, or directly in code, whichever fits how your team works. Icinga DB stores current and historical state, Icinga Web presents it, and the same setup runs from a single host up to millions of checks across distributed zones. As the OTLPMetricsWriter shows, it also connects outward: monitoring data leaves Icinga in open formats instead of staying locked inside it.
The other half is the community. Plugins, modules, and integrations come from people solving their own monitoring problems and sharing the result, and the source sits on GitHub for anyone to read, extend, or file an issue against. That is a slower kind of development than a vendor roadmap, but it tends to track what operators actually need.
Where to Go Next
The fastest way to see how monitoring, observability, and telemetry come together is to run it. You can get started with Icinga in your own environment, browse the full documentation, or look at the integrations that connect Icinga to the rest of your stack. Questions are welcome in the community channel.
FAQ
What is the difference between monitoring and observability?
Monitoring tracks predefined metrics and alerts when a threshold is breached - it answers "what is happening". Observability uses metrics, logs, and traces to explain "why" a system behaves the way it does. Monitoring is one part of a broader observability strategy, not a replacement for it.
Do you need both monitoring and observability?
Monitoring is about status: is a service up or down, and is a value within the thresholds you set. Observability serves a different purpose - it helps you understand why a system behaves the way it does, including problems you never planned for. They are complementary, not an either/or choice.
What is telemetry in IT monitoring?
Telemetry is the automated collection and transmission of data - metrics, logs, and traces - from remote or distributed systems. It is the foundation that both monitoring and observability rely on for their input data.
What are the three pillars of observability?
The three pillars of observability are metrics, logs, and traces. Metrics give you numeric measurements over time, logs record events with detail, and traces follow a request across distributed services.
How does OpenTelemetry relate to telemetry?
OpenTelemetry (OTel) is a vendor-neutral, CNCF-backed standard that defines a common format for telemetry data. Instead of a custom exporter per backend, systems emit data in OTLP format. Icinga 2 supports this natively through the OTLPMetricsWriter since v2.16.
Is Icinga a monitoring or an observability tool?
Icinga is an open-source monitoring tool that also feeds observability workflows. It tracks known state and alerts on it, and since Icinga 2 v2.16 the OTLPMetricsWriter exports metrics in OpenTelemetry format to backends like Prometheus, Grafana, or Datadog, where they become part of a wider observability setup.
