Releasing Icinga Web v2.9.3
by | Aug 10, 2021
Today we’re announcing the general availability of Icinga Web 2 Version 2.9.3. This is a standard bugfix release and includes fixes for RHEL/CentOS 7, SLES/OpenSUSE 15+ and automatic downtime removal.
You can also find the issues related to this release on our Roadmap.
Staying remembered on RHEL/CentOS 7 now possible
RHEL/CentOS 7 still relies on OpenSSL v1.0.2 by default. A change in v2.9.1 resulted in an error in combination with this when ticking Stay Logged In during authentication. Staying logged in now works fine also on this platform.
  • Stay Logged In – Unknown cipher algorithm #4493
Missing icons with SLES/OpenSUSE 15
If you’re running Icinga Web 2 Version 2.9.x on a SLES/OpenSUSE 15.x, you may have noticed some missing icons in the UI. This is due to a missing PHP extension fileinfo. By upgrading to this release using packages, this dependency will now be installed automatically.
  • Missing fileinfo php extension on SLES/OpenSUSE 15+ #4503
Child downtimes for services are now removed automatically
With Icinga v2.13, Icinga Web 2 will now make sure that service downtimes that were created automatically are also removed automatically. This will only work for downtimes you create with the All Services option after upgrading to this release. It will not work for downtimes created with earlier versions of Icinga Web 2.
  • If appropriate, set the API parameter all_services for schedule-downtime #4501
Releasing Icinga DB v1.2.1
Today we are releasing a new version of Icinga DB, version 1.2.1, a maintenance release that addresses HA issues and...
Releasing Icinga Director v1.11.3
We are happy to announce the release of Icinga Director version 1.11.3. This release addresses few important bug fixes...
