Releasing Icinga Business Process Modelling v2.5.1
by | Apr 24, 2024
Last updated on April 10, 2025
We’ve just released Icinga Business Process Modelling v2.5.1, and it comes with a few valuable updates and fixes to make modelling your infrastructure even smoother.
With Business Process Modelling, you can combine multiple monitoring checks into logical units – giving you a clear view of entire services or workflows instead of isolated components. This is especially helpful for complex infrastructures, where knowing the overall status of a business-critical process matters more than a single host or service.
What’s New in Version 2.5.1
Enhancements
  • Ensure compatibility with PHP 8.3
Fixes
  • Process check command throws an error if the sub-node is empty #440
  • Error when adding/editing host or service node after switching to icingadb backend #430
  • Handled nodes are not handled #428
  • Duplicate display names cause problems in Dropdown #427
  • Sort control overlaps action bar #421
  • Adjust notification success messages #405
You can find all issues related to this release on our roadmap.
Releasing Icinga DB v1.5.1
Today we are announcing the release of Icinga DB version 1.5.1. This release addresses the issue of leaking SQL...
