Icinga DB Web Automation
by | Aug 7, 2025
Icinga DB Web Automation allows you to automate monitoring tasks and integrate them directly into your systems and workflows. It is possible to issue command actions without a browser. To do so, a form needs to be submitted by a tool such as cUrl.
Every request you send follows the same permission rules and access restrictions defined in the web interface, so security and user roles still apply.
Want to target specific hosts or services? Simply add filter parameters to the URL. If no filter is given, the command will apply to all available objects – so be precise!
You can also control the response:
  • Use the limit parameter to restrict how many results are returned.
  • Use the sort parameter to order the results the way you want.
The request must transmit the `Accept` HTTP header and set it to `application/json`. In addition to this, the request must be authenticated using the `Basic` schema.
What can you do with it?
Query Objects:
Retrieve details as json about hosts, services, downtimes, notifications, and more in real time.
# Fetch 5 hosts sorted by display_name
curl -i -u user:password -H "Accept: application/json" \
'http://localhost/icingaweb2/icingadb/hosts?limit=5&sort=host.display_name'
python3 -c "import requests; \
url = 'http://localhost/icingaweb2/icingadb/hosts?limit=5&sort=host.display_name'; \
r = requests.post(url, headers={'Accept': 'application/json'}, auth=('user', 'password')); \
print('Status:', r.status_code); print('Body:', r.text)"
Acknowledge Problems:
Acknowledge hosts and services:
# Acknowledge hosts:
curl -H "Accept: application/json" -u user:password -X POST \
"http://localhost/icingaweb2/icingadb/hosts/acknowledge?host.name=switch-1" \
-F "comment=my comment"
url = 'http://localhost/icingaweb2/icingadb/hosts/acknowledge?host.name=switch-1'; \
data = {'comment': 'my comment'}; \
r = requests.post(url, data=data, headers={'Accept': 'application/json'}, auth=('user', 'password')); \
print('Status:', r.status_code); print(r.text)"
Remove the acknowledgement:
# Remove Acknowledgement:
"http://localhost/icingaweb2/icingadb/hosts/remove-acknowledgement?host.name=switch-1"
url = 'http://localhost/icingaweb2/icingadb/hosts/remove-acknowledgement?host.name=switch-1'; \
Manage Downtimes:
Schedule downtimes for hosts and services:
# Schedule downtime for host "switch-1":
curl -H "Accept: application/json" -u user:password \
"http://localhost/icingaweb2/icingadb/hosts/schedule-downtime?host.name=switch-1" \
-F "type=fixed" \
-F "start=$(date "+%Y-%m-%dT%H:%M:%S")" \
-F "end=$(date -v+1H '+%Y-%m-%dT%H:%M:%S')" \
-F "comment=Maintenance"
python3 -c "import requests, datetime; \
now = datetime.datetime.now(); \
end = now + datetime.timedelta(hours=1); \
url = 'http://localhost/icingaweb2/icingadb/hosts/schedule-downtime?host.name=switch-1'; \
data = { \
  'type': 'fixed', \
  'start': now.strftime('%Y-%m-%dT%H:%M:%S'), \
  'end': end.strftime('%Y-%m-%dT%H:%M:%S'), \
  'comment': 'RebootHostAandB' \
print(r.status_code); print(r.text);"
Remove the downtimes:
# Remove downtime by host name (This will remove all downtimes of host switch-1, use downtime.name filter to remove a specific downtime):
"http://localhost/icingaweb2/icingadb/downtimes/delete?host.name=switch-1"
url = 'http://localhost/icingaweb2/icingadb/downtimes/delete?host.name=switch-1'; \
print('Status:', r.status_code); print(response.text)"
Comments:
Add comments to hosts and services:
# Add a comment to a service "agent-check" of host "switch-1":
"http://localhost/icingaweb2/icingadb/services/add-comment?service.name=agent-check&host.name=switch-1" \
-F "comment=Testing"
url = 'http://localhost/icingaweb2/icingadb/services/add-comment?service.name=agent-check&host.name=switch-1'; \
data = {'comment': 'Testing'}; \
Remove comments:
# Remove comment of host "switch-1" (This will remove all comments of host "switch-1", use "comment.name" filter to remove a specific comment):
"http://localhost/icingaweb2/icingadb/comments/delete?host.name=switch-1"
url = 'http://localhost/icingaweb2/icingadb/comments/delete?host.name=switch-1'; \
These are just a few examples, for a deeper dive into what’s possible, check out the official Icinga DB Web documentation.
Icinga TOTP Web 1.0.0 Release
