We’re happy to announce the releases of the Icinga Web 2 versions 2.3.4, 2.2.2 and 2.1.4.
Besides some minor bug fixes, Icinga Web 2 version 2.3.4 tackles problems with external links and HTML in plugin output. Those were no longer rendered correctly in the previous version. You’ll find all issues for version 2.3.4 over here.
All released versions fix the possibility of remote code execution via the remote command transport. Thanks to you guys for reporting this issue. If you’re using the remote command transport, make sure to upgrade as soon as possible.
As usual you can get the packages or check out our releases from Github.
If you’re wondering what happened with version 2.3.3, we had some packaging problems which forced us to increase the version number.
Releasing Icinga Web v2.12.2
Today we’re announcing the general availability of Icinga Web v2.12.2. You can find all issues related to this release...
