Icinga Web 2 v2.0.0-rc1 released
by | Jun 18, 2015
Thank God, RC1 is out!
This release candidate is the result of 751 days of blood, sweat and tears and round about 7K commits in our git. It was not easy and we learned our lessons but now we’re very proud to put a rc tag on Icinga Web 2. Created from scratch, a clean and reduced interface is born with everything you need: Speed, accessible and extensible. The new interface is a monitoring swiss army knife without tailoring or customisation. It is focused on your problems and provide context sensitive interaction with your IT infrastructure.
Please grab another cup of coffee, lean back and enjoy monitoring!
Beside this awesome moment we want to thank all the testers, patchers, issue-openers, developers and all the brave men out there using a so-called beta software already! You are the greatest!
Have you seen the new full screen and compact mode (try /icingaweb2/dashboard?showFullscreen&showCompact as url)? Buts that’s only a small change. RC1 also contains full-featured user- and group management interfaces, enforces restrictions and permissions on every view. And we ship the package with a fully working Postgres 9.1 backend implementation.
Enjoy Icinga Web 2, check the Changelog below and start your download!
What’s New in Version 2.0.0-rc1
Changes
  • Improve layout and look and feel in many ways
  • Apply host, service and custom variable restrictions to all monitoring objects
  • Add fullscreen mode (?showFullscreen)
  • User and group management
  • Comment and Downtime Detail View
  • Show icon_image in host/service views
  • Show Icinga program version in monitoring health
Features
  • Feature 4139: Notify monitoring backend availability problems
  • Feature 4498: Allow to add columns to monitoring views via URL
  • Feature 6392: Resolve Icinga 2 runtime macros in action and notes URLs
  • Feature 6729: Fullscreen mode
  • Feature 7343: Fetch user groups from LDAP
  • Feature 7595: Remote connection resource configuration
  • Feature 7614: Right-align icons
  • Feature 7651: Add module information (module.info) to all core modules
  • Feature 8054: Host Groups should list number of hosts (as well as services)
  • Feature 8235: Show host and service notes in the host and service detail view
  • Feature 8247: Move notifications to the bottom of the page
  • Feature 8281: Improve layout of comments and downtimes in the host and service detail views
  • Feature 8310: Improve layout of performance data and check statistics in the host and service detail views
  • Feature 8565: Improve look and feel of the monitoring multi-select views
  • Feature 8613: IDO queries related to concrete objects should not depend on collations
  • Feature 8665: Show icon_image in the host and service detail views
  • Feature 8781: Automatically deselect rows when closing the detail area
  • Feature 8826: User and group management
  • Feature 8849: Show only three (or four) significant digits (e.g. in check execution time)
  • Feature 8877: Allow module developers to implement new/custom authentication methods
  • Feature 8886: Require mandatory parameters in controller actions and CLI commands
  • Feature 8902: Downtime detail view
  • Feature 8903: Comment detail view
  • Feature 9009: Apply host and service restrictions to related views as well
  • Feature 9203: Wizard: Validate that a resource is actually an IDO instance
  • Feature 9207: Show icinga program version in Monitoring Health
  • Feature 9223: Show the active ido endpoint in the monitoring health view
  • Feature 9284: Create a ServiceActionsHook
  • Feature 9300: Support icon_image_alt
  • Feature 9361: Refine UI for RC1
  • Feature 9377: Permission and restriction documentation
  • Feature 9379: Provide an about.md
Bugfixes
  • Bug 6281: ShowController’s hostAction() and serviceAction() do not respond with 400 for invalid/missing parameters and with 404 if the host or service wasn’t found
  • Bug 6778: Duration and history time formatting isn’t correct
  • Bug 6952: Unauthenticated users are provided helpful error messages
  • Bug 7151: Play nice with form-button-double-clickers
  • Bug 7165: Invalid host address leads to exception w/ PostgreSQL
  • Bug 7447: Commands sent over SSH are missing the -i option when using a ssh user aside from the webserver’s user
  • Bug 7491: Switching from MySQL to PostgreSQL and vice versa doesn’t change the port in the resource configuration
  • Bug 7642: Monitoring menu renderers should be moved to the monitoring module
  • Bug 7658: MenuItemRenderer is not so easy to extend
  • Bug 7876: Not all views can be added to the dashboard w/o breaking the layout
  • Bug 7931: Can’t acknowledge multiple selected services which are in downtime
  • Bug 7997: Service-Detail-View tabs are changing their context when clicking the Host-Tab
  • Bug 7998: Navigating to the Services-Tab in the Service-Detail-View displays only the selected service
  • Bug 8006: Beautify command transport error exceptions
  • Bug 8205: List views should not show more than the five worst pies
  • Bug 8241: Take display_name into account when searching for host and service names
  • Bug 8334: Perfdata details partially hidden depending on the resolution
  • Bug 8339: Lib: SimpleQuery::paginate() must not fetch page and limit from request but use them from parameters
  • Bug 8343: Status summary does not respect restrictions
  • Bug 8363: Updating dashlets corrupts their URLs
  • Bug 8453: The filter column “_dev” is not allowed here
  • Bug 8472: Missing support for command line arguments in the format –arg=
  • Bug 8474: Improve layout of dictionaries in the host and service detail views
  • Bug 8624: Delete multiple downtimes and comments at once
  • Bug 8696: Can’t search for Icinga 2 custom variables
  • Bug 8705: Show all shell commands required to get ready in the setup wizard
  • Bug 8706: INI files should end with a newline character and should not contain superfluous newlines
  • Bug 8707: Wizard: setup seems to fail with just one DB user
  • Bug 8711: JS is logging “ugly” side exceptions
  • Bug 8731: Apply host restrictions to service views
  • Bug 8744: Performance data metrics with value 0 are not displayed
  • Bug 8747: Icinga 2 boolean variables not shown in the host and service detail views
  • Bug 8777: Server error: Service not found exception when service name begins or ends with whitespaces
  • Bug 8815: Only the first external command is sent over SSH when submitting commands for multiple selected hosts or services
  • Bug 8847: Missing indication that nothing was found in the docs when searching
  • Bug 8860: Host group view calculates states from service states; but states should be calculated from host states instead
  • Bug 8927: Tactical overview does not respect restrictions
  • Bug 8928: Host and service groups views do not respect restrictions
  • Bug 8929: Setup wizard does not validate whether the PostgreSQL user for creating the database owns the CREATE ROLE system privilege
  • Bug 8930: Error message about refused connection to the PostgreSQL database server displayed twice in the setup wizard
  • Bug 8934: Status text for ok/up becomes white when hovered
  • Bug 8941: Long plugin output makes the whole container horizontally scrollable instead of just the row containing the long plugin output
  • Bug 8950: Improve English for “The last one occured %s ago”
  • Bug 8953: LDAP encryption settings have no effect
  • Bug 8956: Can’t login when creating the database connection for the preferences store fails
  • Bug 8957: Fall back on syslog if the logger’s type directive is misconfigured
  • Bug 8958: Switching LDAP encryption to LDAPS doesn’t change the port in the resource configuration
  • Bug 8960: Remove exclamation mark from the notification “Authentication order updated!”
  • Bug 8966: Show custom variables visually separated in the host and service detail views
  • Bug 8967: Remove right petrol border from plugin output in the host and service detail views
  • Bug 8972: Can’t view Icinga Web 2’s log file
  • Bug 8994: Uncaught exception on empty session.save_path()
  • Bug 9000: Only the first line of a stack trace is shown in the applications log view
  • Bug 9007: Misspelled host and service names in commands are not accepted by icinga
  • Bug 9008: Notification overview does not respect restrictions
  • Bug 9022: Browser title does not change in case of an error
  • Bug 9023: Toggling feature…
  • Bug 9025: A tooltip of the service grid’s x-axe makes it difficult to click the title of the currently hovered column
  • Bug 9026: Add To Dashboard … on the dashboard
  • Bug 9046: Detail View: Downtimes description misses space between duration and comment text
  • Bug 9056: Filter for host/servicegroup search doesn’t work anymore
  • Bug 9057: contact_notify_host_timeperiod
  • Bug 9059: Can’t initiate an ascending sort by host or service severity
  • Bug 9198: monitoring/command/feature/object does not grant the correct permissions
  • Bug 9202: The config\* permission does not permit to navigate to the configuration
  • Bug 9211: Empty filters are being rendered to SQL which leads to syntax errors
  • Bug 9214: Detect multitple icinga_instances entries and warn the user
  • Bug 9220: Centralize submission and apply handling of sort rules
  • Bug 9224: Allow anonymous LDAP binding
  • Bug 9281: Problem with Icingaweb 2 after PHP Upgrade 5.6.8 -> 5.6.9
  • Bug 9317: Web 2’s ListController inherits from the monitoring module’s base controller
  • Bug 9319: Downtimes overview does not respect restrictions
  • Bug 9350: Menu disappears in user group management view
  • Bug 9351: Timeline links are broken
  • Bug 9352: User list should be sorted
  • Bug 9353: Searching for users fails, at least with LDAP backend
  • Bug 9355: msldap seems not to be a first-class citizen
  • Bug 9378: Rpm calls usermod w/ invalid option on openSUSE
  • Bug 9384: Timeline+Role problem
  • Bug 9392: Command links seem to be broken
Releasing Icinga Web v2.12.2
Today we’re announcing the general availability of Icinga Web v2.12.2. You can find all issues related to this release...
