Icinga Web 1.6.2 released
by | Mar 1, 2012
It may be no 1.7 but we do have a release for you today: Download Icinga Web 1.6.2 from Sourceforge now!
As promised, the web team has resolved a bunch of bugs – some of which have resulted in what can be construed as new ‘features’.
These include:
Tactical header à la Classic UI: the status header now is analogous to the one in Classic UI, with critical services categorized as “acknowledged”, “unacknowledged” and “handled”. The header also loads faster and comes with a refresh button too.
Configuration files in etc/conf.d: the previously scattered configuration files can now all be found in etc/conf.d. See our corresponding wiki article on xml configuration.
Tackle Cronk now “Object Info” the plugin output, perf data and relations components of our Tackle Cronk are now integrated into an extended “Object Info” box.
A few may also be glad to hear that we have resolved PNP integration bugs as well as the missing quick tips for various buttons.
For a complete list see the change log below.
CHANGE LOG
Features
  • Default reporting cronk for admins only
  • Disabled tackle per default #2275 (not ready yet)
  • LDAP TLS feature #1980
  • Logout for HTTP BASIC AUTH #1005
  • Cleaner configuration way, more overwrites #2233
  • Analogue head summary counts to classic interface #2159, #2328
  • Manual refresh counter for head cronks
  • New security layer for new api (DOCTRINE filter chain) #2297
  • Removed useless SQL counts for views: history, logs, notification
  • Fixed old JS objects the JSHINT way (performance, IE compatible)
  • Added tackle components for object info #2132
  • Some UI enhancements (congruent icons, label and locations) #1558
  • More logging, verbose query logging #2277
  • New “simple” searchbox #2353
  • Show downtime type (fixed, flexible) #2076
Bugfixes
  • Fixed Auth.Dispatch import group assign #2284
  • Auth dispatcher lowercase fix #2080
  • PNP integration fixes (typo, js errors)
  • Update script fixes #2229
  • Removed unique index from email field #2228
  • Fix for sending commands to slaves
  • Rewritten makefiles for more portable installation #2080
  • Removed all spaces from files (mostly cronk images)
  • Servertime fix if not logged in #1005
  • Automatic width fix for cronks in head bar #2230
  • Global search (CTRL+ALT+F) works not on all browsers
  • QTIP fixes
  • Fixing custom cronk deletion #2155
  • Error handling reporting module #2248
  • Growl stack IE fix (also new layout and icons support) #2194
  • Json error handling if not logged in
  • Doctrine connection handling for modules
  • Fixes for host comments and object_id for info icons #2225
  • Notification view shows random contacts #1987, #2199
  • API and authkey access fixes #2305, #2325, #2326
Releasing Icinga Web v2.12.2
Today we’re announcing the general availability of Icinga Web v2.12.2. You can find all issues related to this release...
