We have just released version 2.3.3. This release fixes a number of bugs and introduces a select few minor features and documentation changes:
- Feature 8685: Show state/type filter names in notice/debug log
- Feature 8686: Update documentation for “apply for” rules
- Feature 8693: New function: parse_performance_data
- Feature 8740: Add “access objects at runtime” examples to advanced section
- Feature 8761: Include more details in –version
- Feature 8816: Add “random” CheckCommand for test and demo purposes
- Feature 8827: Move release info in INSTALL.md into a separate file
- Bug 8660: Update syntax highlighting for 2.3 features
- Bug 8677: Re-order the object types in alphabetical order
- Bug 8724: Missing config validator for command arguments ‘set_if’
- Bug 8734: startup.log broken when the DB schema needs an update
- Bug 8736: Don’t update custom vars for each status update
- Bug 8748: Don’t ignore extraneous arguments for functions
- Bug 8749: Build warnings with CMake 3.1.3
- Bug 8750: Flex version check does not reject unsupported versions
- Bug 8753: Fix a typo in the documentation of ICINGA2_WITH_MYSQL and ICINGA2_WITH_PGSQL
- Bug 8755: Fix VIM syntax highlighting for comments
- Bug 8757: Add missing keywords in the syntax highlighting files
- Bug 8762: Plugin “check_http” is missing in Windows environments
- Bug 8763: Typo in doc library-reference
- Bug 8764: Revamp migration documentation
- Bug 8765: Explain processing logic/order of apply rules with for loops
- Bug 8766: Remove prompt to create a TicketSalt from the wizard
- Bug 8767: Typo and invalid example in the runtime macro documentation
- Bug 8769: Improve error message for invalid field access
- Bug 8770: object Notification + apply Service fails with error “…refers to service which doesn’t exist”
- Bug 8771: Correct HA documentation
- Bug 8829: Figure out why command validators are not triggered
- Bug 8834: Return doesn’t work inside loops
- Bug 8844: Segmentation fault when executing “icinga2 pki new-cert”
- Bug 8862: wrong ‘dns_lookup’ custom attribute default in command-plugins.conf
- Bug 8866: Fix incorrect perfdata templates in the documentation
- Bug 8869: Array in command arguments doesn’t work
You can look up the bug ID in our issue tracker at dev.icinga.com. Updated packages should be available shortly.
