Icinga 2 bug fix release 2.2.4
by | Feb 5, 2015
We have just released version 2.2.4. This release fixes a number of bugs:
* Bug #6943: Configured recurring downtimes not applied on saturdays
* Bug #7660: livestatus / nsca / etc submits are ignored during reload
* Bug #7685: kUn-Bashify mail-{host,service}-notification.sh
* Bug #8128: Icinga 2.2.2 build fails on SLES11SP3 because of changed boost dependency
* Bug #8131: vfork() hangs on OS X
* Bug #8162: Satellite doesn’t use manually supplied ‘local zone name’
* Bug #8192: Feature statusdata shows wrong host notification options
* Bug #8201: Update Icinga Web 2 uri to /icingaweb2
* Bug #8214: Fix YAJL detection on Debian squeeze
* Bug #8222: inconsistent URL http(s)://www.icinga.org
* Bug #8223: Typos in readme file for windows plugins
* Bug #8245: check_ssmtp command does NOT support mail_from
* Bug #8256: Restart fails after deleting a Host
* Bug #8288: Crash in DbConnection::ProgramStatusHandler
* Bug #8295: Restart of Icinga hangs
* Bug #8299: Scheduling downtime for host and all services only schedules services
* Bug #8311: Segfault in Checkable::AddNotification
* Bug #8321: enable_event_handlers attribute is missing in status.dat
* Bug #8368: Output in “node wizard” is confusing
You can look up the bug ID in our issue tracker at dev.icinga.com. Updated packages should be available shortly.
Releasing Icinga Web v2.12.2
Today we’re announcing the general availability of Icinga Web v2.12.2. You can find all issues related to this release...
