Icinga 1.9.3 with bugfix for Postgresql
by | Jul 7, 2013
Unfortunately a fix for an ugly libdbi bug causing bad performance was applied not only for MySQL, but also Postgresql causing wrong queries. It slipped through testing and silently made 1.9.2 a faulty IDOUtils Postgresql release. My bad, sorry for that (Sundays are always sleepy 😉 ).
Other than that Eric approached me last week with an init script bug, not returning the correct lsb exit codes when called with ‘status’ – I’ve already fixed that for 1.10 but it’s now backported into 1.9.3 too.
So, if you’re happy with 1.9.2 stick with it. If you are using Postgresql, fetch 1.9.3 from Github as usual.
Releasing Icinga DB v1.2.1
Today we are releasing a new version of Icinga DB, version 1.2.1, a maintenance release that addresses HA issues and...
Releasing Icinga Director v1.11.3
We are happy to announce the release of Icinga Director version 1.11.3. This release addresses few important bug fixes...
Releasing Icinga Director v1.11.2
We are pleased to announce the release of Icinga Director version 1.11.2, which addresses several important bug fixes...
