Icinga 1.10.2 Bug Fix Release
by | Dec 5, 2013
Icinga 1.10.2 is out for download and is our prompt response to potential security issues. In particular, this release is recommended for users who allow public access to their Classic UI.
Aside from this, Icinga 1.10.2 irons out Oracle compiling and upgrading in IDOUtils and adds a few minor config related fixes to the Core.
Thanks to all users who have contributed their patches and bug reports, and special kudos goes to DTAG Group Information Security for alerting us to the security threats
CHANGE LOG
CORE
  • Add an Icinga syntax plugin for Vim #4150 – LE/MF
  • Document dropped options log_external_commands_user and event_profiling_enabled #4957 – BA
  • Type in spec file on ido2db startup #5000 – MF
  • Build fails: xdata/xodtemplate.c requires stdint.h #5021 – SH
CLASSIC UI
  • Fix status output in JSON format not including short and long plugin output properly #5217 – RB
  • Fix possible buffer overflows #5250 – RB
  • Fix Off-by-one memory access in process_cgivars() #5251 – RB
IDOUTILS
  • IDOUtils Oracle compile error #5059 – TD
  • Oracle update script 1.10.0 failes while trying to drop nonexisting index #5256 – RB
Releasing Icinga Web v2.12.2
Today we’re announcing the general availability of Icinga Web v2.12.2. You can find all issues related to this release...
