Introduction¶
This module allows to send notifications to JIRA and integrates nicely into the Icinga Web 2 frontend.
Features¶
NotificationCommand for Icinga¶
You want to create a JIRA issue for all or some of your Hosts and Services? Then this project might be what you’re looking for. Sending notifications is as easy as follows:
icingacli jira send problem \
--host some.example.com \
--state DOWN \
--project ITSM \
--issuetype Incident \
--output 'CRITICAL - 127.0.0.1: rta nan, lost 100%'
Read more about sending notifications.
Icinga Director Integration¶
You do not want to manually create a NotificationCommand
definition? No need
to do so. Given director/admin
permissions, this module allows you to generate
definitions for hosts and services with a single click.
Have a look at out short tutorial, showing how this works.
Brief issue history overview¶
Granted access to this module you can get a quick overview showing the most recent JIRA issues created by Icinga. Read more about what information we’re going to show.
Monitoring module hook¶
This module hooks into the monitoring
module and provides so-called Host and
Service Action Hooks:
A single click brings you to your Host (or Service) issue history.
Getting started¶
It’s free and Open Source, so what are you waiting for? Please read on how to install and configure this module.
