Skip to content
Installing Icinga Web Jira Integration
The recommended way to install Icinga Web Jira Integration and its dependencies is to use prebuilt packages for all supported platforms from our official release repository. Please note that Icinga Web is required and if it is not already set up, it is best to do this first.
The following steps will guide you through installing and setting up Icinga Web Jira Integration.
