Advanced Topics ¶
This chapter provides details for advanced Icinga Web 2 topics.
- Global URL parameters
- VirtualHost configuration
- Advanced Authentication Tips
- Source installation
- Automated setup
- Kiosk Mode Configuration
Global URL Parameters ¶
Parameters starting with _
are for development purposes only.
Parameter | Value | Description |
showFullscreen | - | Hides the left menu and optimizes the layout for full screen resolution. |
showCompact | - | Provides a compact view. Hides the title and upper menu. This is helpful to embed a dashboard item into an external iframe. |
format | json/csv/sql | Selected views can be exported as JSON or CSV. This also is available in the upper menu. You can also export the SQL queries for manual analysis. |
_dev | 0/1 | Whether the server should return compressed or full JS/CSS files. This helps debugging browser console errors. |
Examples for showFullscreen
http://localhost/icingaweb2/dashboard?showFullscreen http://localhost/icingaweb2/monitoring/list/services?service_problem=1&sort=service_severity&showFullscreen
Examples for showCompact
http://localhost/icingaweb2/dashboard?showCompact&showFullscreen http://localhost/icingaweb2/monitoring/list/services?service_problem=1&sort=service_severity&showCompact
Examples for format
http://localhost/icingaweb2/monitoring/list/services?format=json http://localhost/icingaweb2/monitoring/list/services?service_problem=1&sort=service_severity&dir=desc&format=csv
VirtualHost Configuration ¶
This describes how to run Icinga Web 2 on your FQDN’s /
entry point without
any redirect to /icingaweb2
VirtualHost Configuration for Apache ¶
Use the setup CLI commands to generate the default Apache configuration which serves
Icinga Web 2 underneath /icingaweb2
The next steps are to create the VirtualHost configuration:
- Copy the
<Directory "/usr/share/icingaweb2/public">
into the main VHost configuration. Don’t forget to correct the indent. - Set the
DocumentRoot
variable to look into/usr/share/icingaweb2/public
- Modify the
RewriteBase
variable to use/
instead of/icingaweb2
Example on RHEL/CentOS:
vim /etc/httpd/conf.d/web.icinga.com.conf
<VirtualHost *:80>
ServerName web.icinga.com
## Vhost docroot
# modified for Icinga Web 2
DocumentRoot "/usr/share/icingaweb2/public"
## Rewrite rules
RewriteEngine On
Options SymLinksIfOwnerMatch
AllowOverride None
<IfModule mod_authz_core.c>
# Apache 2.4
<RequireAll>
Require all granted
</RequireAll>
</IfModule>
<IfModule !mod_authz_core.c>
# Apache 2.2
Order allow,deny
Allow from all
</IfModule>
SetEnv ICINGAWEB_CONFIGDIR "/etc/icingaweb2"
EnableSendfile Off
<IfModule mod_rewrite.c>
RewriteEngine on
# modified base
RewriteBase /
RewriteRule ^.*$ - [NC,L]
</IfModule>
<IfModule !mod_rewrite.c>
ErrorDocument 404 /error_norewrite.html
</IfModule>
</Directory>
</VirtualHost>
Reload Apache and open the FQDN in your web browser.
systemctl reload httpd
Advanced Authentication Tips ¶
Manual User Creation for Database Authentication Backend ¶
Icinga Web 2 v2.5+ uses the native password hash algorithm provided by PHP 5.6+.
In order to generate a password, run the following command with the PHP CLI >= 5.6:
php -r 'echo password_hash("yourtopsecretpassword", PASSWORD_DEFAULT);'
Please note that the hashed output changes each time. This is expected.
Insert the user into the database using the generated password hash.
INSERT INTO icingaweb_user (name, active, password_hash) VALUES ('icingaadmin', 1, '$2y$10$bEKU6.1bRYjE7wxktqfeO.IGV9pYAkDBeXEbjMFSNs26lKTI0JQ1q');
Puppet ¶
Please do note that the $
character needs to be escaped with a leading backslash in your
Puppet manifests.
Example from puppet-icingaweb2:
exec { 'create default user':
command => "mysql -h '${db_host}' -P '${db_port}' -u '${db_username}' -p'${db_password}' '${db_name}' -Ns -e 'INSERT INTO icingaweb_user (name, active, password_hash) VALUES (\"icingaadmin\", 1, \"\$2y\$10\$QnXfBjl1RE6TqJcY85ZKJuP9AvAV3ont9QihMTFQ/D/vHmAWaz.lG\")'",
refreshonly => true,
Icinga Web 2 Manual Setup ¶
If you have chosen not to run the setup wizard, you will need further knowledge about
- manual creation of the Icinga Web 2 database
icingaweb2
including a default user (optional as authentication and session backend) - additional configuration for the application
- additional configuration for the monitoring module (e.g. the IDO database and external command pipe from Icinga 2)
This comes in handy if you are planning to deploy Icinga Web 2 automatically using Puppet, Ansible, Chef, etc.
Warning
Read the documentation on the respective linked configuration sections before deploying the configuration manually.
If you are unsure about certain settings, use the setup wizard as described in the installation instructions once and then collect the generated configuration as well as sql dumps.
Icinga Web 2 Manual Database Setup ¶
Create the database and add a new user as shown below for MySQL/MariaDB:
sudo mysql -p
CREATE DATABASE icingaweb2;
GRANT SELECT, INSERT, UPDATE, DELETE, DROP, CREATE VIEW, INDEX, EXECUTE ON icingaweb2.* TO 'icingaweb2'@'localhost' IDENTIFIED BY 'icingaweb2';
quit
mysql -p icingaweb2 < /usr/share/doc/icingaweb2/schema/mysql.schema.sql
Then generate a new password hash as described in the authentication docs
and use it to insert a new user called icingaadmin
into the database.
mysql -p icingaweb2
INSERT INTO icingaweb_user (name, active, password_hash) VALUES ('icingaadmin', 1, '$1$EzxLOFDr$giVx3bGhVm4lDUAw6srGX1');
quit
Icinga Web 2 Manual Configuration ¶
resources.ini providing the details for the Icinga Web 2 and Icinga 2 IDO database configuration. Example for MySQL:
vim /etc/icingaweb2/resources.ini
[icingaweb2]
type = "db"
db = "mysql"
host = "localhost"
port = "3306"
dbname = "icingaweb2"
username = "icingaweb2"
password = "icingaweb2"
[icinga2]
type = "db"
db = "mysql"
host = "localhost"
port = "3306"
dbname = "icinga"
username = "icinga"
password = "icinga"
config.ini defining general application settings.
vim /etc/icingaweb2/config.ini
[logging]
log = "syslog"
level = "ERROR"
application = "icingaweb2"
[preferences]
type = "db"
resource = "icingaweb2"
authentication.ini for e.g. using the previously created database.
vim /etc/icingaweb2/authentication.ini
[icingaweb2]
backend = "db"
roles.ini granting the previously added icingaadmin
user all permissions.
vim /etc/icingaweb2/roles.ini
[admins]
users = "icingaadmin"
permissions = "*"
Icinga Web 2 Manual Configuration Monitoring Module ¶
config.ini defining additional security settings.
vim /etc/icingaweb2/modules/monitoring/config.ini
[security]
protected_customvars = "*pw*,*pass*,community"
backends.ini referencing the Icinga 2 DB IDO resource.
vim /etc/icingaweb2/modules/monitoring/backends.ini
[icinga2]
type = "ido"
resource = "icinga2"
commandtransports.ini defining the Icinga 2 API command transport.
vim /etc/icingaweb2/modules/monitoring/commandtransports.ini
[icinga2]
transport = "api"
host = "localhost"
port = "5665"
username = "api"
password = "api"
Icinga Web 2 Manual Setup Login ¶
Finally visit Icinga Web 2 in your browser to login as icingaadmin
user: /icingaweb2
Automating the Installation of Icinga Web 2 ¶
Prior to creating your own script, please look into the official resources which may help you already:
If you are automating the installation of Icinga Web 2, you may want to skip the wizard and do things yourself. These are the steps you’d need to take assuming you are using MySQL/MariaDB. If you are using PostgreSQL please adapt accordingly. Note you need to have successfully completed the Icinga 2 installation, installed the Icinga Web 2 packages and all the other steps described above first.
- Install PHP dependencies:
php
,php-intl
,php-imagick
,php-gd
,php-mysql
,php-curl
,php-mbstring
used by Icinga Web 2. - Create a database for Icinga Web 2, i.e.
icingaweb2
. - Import the database schema:
mysql -D icingaweb2 < /usr/share/icingaweb2/etc/schema/mysql.schema.sql
. - Insert administrator user in the
icingaweb2
database:INSERT INTO icingaweb_user (name, active, password_hash) VALUES ('admin', 1, '<hash>')
, where<hash>
is the output ofphp -r 'echo password_hash("yourtopsecretpassword", PASSWORD_DEFAULT);'
. - Make sure the
ido-mysql
andapi
features are enabled in Icinga 2:icinga2 feature enable ido-mysql
andicinga2 feature enable api
. - Generate Apache/nginx config. This command will print an apache config for you on stdout:
icingacli setup config webserver apache
. Similarly for nginx. You need to place that configuration in the right place, for example/etc/apache2/sites-enabled/icingaweb2.conf
. - Add
www-data
user toicingaweb2
group if not done already (usermod -a -G icingaweb2 www-data
). - Create the Icinga Web 2 configuration in
/etc/icingaweb2
. The directory can be easily created with:icingacli setup config directory
. This command ensures that the directory has the appropriate ownership and permissions. If you want to create the directory manually, make sure to chown the group toicingaweb2
and set the access mode to2770
The structure of the configurations looks like the following:
/etc/icingaweb2/
/etc/icingaweb2/modules/monitoring/instances.ini
/etc/icingaweb2/enabledModules
/etc/icingaweb2/enabledModules/monitoring
/etc/icingaweb2/enabledModules/doc
Have a look here for the contents of the files.
Kiosk Mode Configuration ¶
Be aware that when you create a kiosk user every person who has access to the kiosk is able to perform tasks on it.
Therefore you would need to create a user in the roles.ini
in /etc/icingaweb2/roles.ini
[kioskusers] users = “kiosk”
If you need special permissions you should add those permissions to the user via the admin account in icingaweb2 to the role of the kiosk user.
For the Dashboard system where you want to display the kiosk you can add also the following part into the icingaweb2.conf
So it starts directly into the kiosk mode.
If you want to show a specific Dashboard you can enforce this onto the kiosk user via the enforceddashboard module.
<ifmodule mod_authz_core.c>
# Apache 2.4
SetEnvIf Remote_Addr "X.X.X.X" REMOTE_USER=kiosk
<requireall>
Require all granted
</requireall>
</ifmodule>
Replace Remote_Addr with the IP where the kiosk user is accessing the Web to restrict further usage from other IPs.
