Icinga Director Integration¶
You do not need to manually create a NotificationCommand definition. This
module integrates nicely with the Icinga Director
and allows you to generate definitions for hosts and services with a single
click.
Please note that this option will not be shown unless you have director/admin
permissions. This is how it looks like on a fresh installation:
Now, please click the Sync to Director action link:
You should be notified about the successful operation, and the sync state will get green:
And don’t worry, you can click the Sync action as many times as you want,
nothing bad will happen. In case you modified your definition in the Director,
this will be recognized - and a single click will allow you to restore the
defaults. Of course only in case this is what you want to happen.
A single click on the object name brings you directly to the related Command definition in your Director module.
