Skip to content
Automation
It is possible to issue command actions without a browser. To do so, a form needs to be submitted by a tool such as curl. This is also used in the example below.
Request Format
The request is required to be an Icinga Web API request. For this it is necessary to transmit the Accept HTTP header and set it to application/json. In addition to this, the request must be authenticated using the Basic schema. The HTTP request method is POST if not documented otherwise and it might be necessary to manually configure this (e.g. -X POST for curl).
All endpoints support filters. To issue commands only for specific items, define a filter in the request’s query string. If this filter is omitted, all items are affected.
The options need to be transmitted in the request body as multipart/form-data.
Response Format
If the request succeeds, the HTTP response code is 200 and the response body contains a JSON object such as this:
  "status": "success",
  "data": [
      "type": "success",
      "message": "Added comment successfully"
If there’s something wrong with the options, the HTTP response code is 422 and the response body contains a JSON object such as this:
  "status": "fail",
  "data": {
    "comment": [],
    "expire": [],
    "expire_time": ["The expire time must not be in the past"]
Example
USER="icingaadmin"
PASSWORD="icinga"
BASEURL="http://localhost/icingaweb2"
FILTER="host.name=docker-master"
curl -H "Accept: application/json" -u $USER:$PASSWORD "$BASEURL/icingadb/hosts/add-comment?$FILTER" \
  -F "comment=kaput" -F "expire_time=2023-10-05T20:00:00" -F "expire=y"
USER="icingaadmin"
PASSWORD="icinga"
curl -H "Accept: application/json" -u $USER:$PASSWORD -X POST "$BASEURL/icingadb/hosts/delete-comment?$FILTER"
Option Types
Text
A simple text message. May contain newlines.
Number
An integer value.
BoolEnum
A string with the value of y for true and n for false.
DateTime
A date time string in the following format: Y-m-d\TH:i:s
The timezone this is interpreted in depends on the user who’s transmitting the request. To change this, log in as this user and change its preference setting.
State
Value Description Applicable To
0 UP / OK Host / Service
1 DOWN / WARNING Host / Service
2 CRITICAL Service
3 UNKNOWN Service
PerfData
Please have a look at the Monitoring Plugins Development Guidelines.
ChildOption
Value Description
0 Do nothing with child hosts
1 Schedule triggered downtime for all child hosts
2 Schedule non-triggered downtime for all child hosts
Endpoints
Info
Some of the endpoints support configuration options. These are explained in the Configuration section.
Acknowledge Problem
Routes
  • icingadb/hosts/acknowledge
  • icingadb/services/acknowledge
Options
Option Required Type Depends On Default Configuration Option
comment y Text - - acknowledge_comment_text
persistent n BoolEnum - n acknowledge_persistent
notify n BoolEnum - y acknowledge_notify
sticky n BoolEnum - n acknowledge_sticky
expire n BoolEnum - n acknowledge_expire
expire_time y DateTime expire now + 1 hour acknowledge_expire_time
Add Comment
Routes
  • icingadb/hosts/add-comment
  • icingadb/services/add-comment
Options
comment y Text - - -
expire n BoolEnum - n comment_expire
expire_time y DateTime expire now + 1 hour comment_expire_time
Delete Comments
Routes
  • icingadb/comments/delete
Options
None.
Check Now
Routes
  • icingadb/hosts/check-now
  • icingadb/services/check-now
Options
None.
Process Check Result
Routes
  • icingadb/hosts/process-checkresult
  • icingadb/services/process-checkresult
Options
status y State
output y Text
perfdata n PerfData
Remove Acknowledgement
Routes
  • icingadb/hosts/remove-acknowledgement
  • icingadb/services/remove-acknowledgement
Options
None.
Schedule Check
Routes
  • icingadb/hosts/schedule-check
  • icingadb/services/schedule-check
Options
Option Required Type Default
check_time y DateTime now + 1 hour
force_check n BoolEnum -
Schedule Host Downtime
Routes
  • icingadb/hosts/schedule-downtime
Options
comment y Text - - hostdowntime_comment_text
start y DateTime - now -
end y DateTime - now + 1 hour (fixed), now + 2 hours (flexible) hostdowntime_end_fixed, hostdowntime_end_flexible
flexible n BoolEnum - n -
hours y Number flexible 2 hostdowntime_flexible_duration
minutes y Number flexible 0 hostdowntime_flexible_duration
all_services n BoolEnum - n hostdowntime_all_services
child_options n ChildOption - - -
Schedule Service Downtime
Routes
  • icingadb/services/schedule-downtime
Options
comment y Text - - servicedowntime_comment_text
end y DateTime - now + 1 hour (fixed), now + 2 hours (flexible) servicedowntime_end_fixed, servicedowntime_end_flexible
hours y Number flexible 2 servicedowntime_flexible_duration
minutes y Number flexible 0 servicedowntime_flexible_duration
Delete Downtimes
Routes
  • icingadb/downtimes/delete
Options
None.
Send Custom Notification
Routes
  • icingadb/hosts/send-custom-notification
  • icingadb/services/send-custom-notification
Options
Option Required Type Default Configuration Option
comment y Text - -
forced n BoolEnum n custom_notification_forced
