Monitoring¶
Process Check Command¶
The module provides a CLI command to check a business process.
Usage¶
General: icingacli businessprocess process check <process> [options]
Options:
--config <configname> Name of the config that contains <process>
--details Show problem details as a tree
--colors Show colored output
--state-type <type> Define which state type to look at. Could be either soft
or hard, overrides an eventually configured default
--blame Show problem details as a tree reduced to the nodes
which have the same state as the business process
--root-cause Used in combination with --blame. Only shows
the path of the nodes which are responsible
for the state of the business process
--downtime-is-ok Treat hosts/services in downtime always as UP/OK.
--ack-is-ok Treat acknowledged hosts/services always as UP/OK.
Detail View Integration¶
It is possible to show the monitored process in the service detail view.
For this to work, the name of the checkcommand configured in Icinga 2 must either
be icingacli-businessprocess or the name that can be configured in the module
configuration:
/etc/icingaweb2/modules/businessprocess/config.ini
[DetailviewExtension]
checkcommand_name=businessprocess-check
A service can define specific custom variables for this. Mandatory ones that are not defined, cause the detail view integration to not be active.
| Variable Name | Mandatory | Description |
| icingacli_businessprocess_process | Yes | The <process> being checked |
| icingacli_businessprocess_config | No | Name of the config that contains <process> |
| icingaweb_businessprocess_as_tree | No | Whether to show <process> as tree or tiles |
