Library Reference ¶
Global functions ¶
These functions are globally available in assign/ignore where expressions, functions, API filters and the Icinga 2 debug console.
You can use the Icinga 2 debug console as a sandbox to test these functions before implementing them in your scenarios.
regex ¶
Signature:
function regex(pattern, value, mode)
Returns true if the regular expression pattern matches the value, false otherwise.
The value can be of the type String or Array (which
contains string elements).
The mode argument is optional and can be either MatchAll (in which case all elements
for an array have to match) or MatchAny (in which case at least one element has to match).
The default mode is MatchAll.
Tip: In case you are looking for regular expression tests try regex101.
Example for string values:
$ icinga2 console
Icinga 2 (version: v2.11.0)
<1> => host.vars.os_type = "Linux/Unix"
null
<2> => regex("^Linux", host.vars.os_type)
true
<3> => regex("^Linux$", host.vars.os_type)
false
Example for an array of string values:
$ icinga2 console
<1> => host.vars.databases = [ "db-prod1", "db-prod2", "db-dev" ]
null
<2> => regex("^db-prod\\d+", host.vars.databases, MatchAny)
true
<3> => regex("^db-prod\\d+", host.vars.databases, MatchAll)
false
match ¶
Signature:
function match(pattern, text, mode)
Returns true if the wildcard (?*) pattern matches the value, false otherwise.
$ icinga2 console
<1> => var name = "db-prod-sfo-657"
null
<2> => match("*prod-sfo*", name)
true
<3> => match("*-dev-*", name)
false
$ icinga2 console
Icinga 2 (version: v2.11.0-28)
<1> => host.vars.application_types = [ "web-wp", "web-rt", "db-local" ]
null
<2> => match("web-*", host.vars.application_types, MatchAll)
false
<3> => match("web-*", host.vars.application_types, MatchAny)
true
cidr_match ¶
Signature:
function cidr_match(pattern, ip, mode)
Returns true if the CIDR pattern matches the IP address, false otherwise.
IPv4 addresses are converted to IPv4-mapped IPv6 addresses before being
matched against the pattern. The mode argument is optional and can be
either MatchAll (in which case all elements for an array have to match) or MatchAny
(in which case at least one element has to match). The default mode is MatchAll.
Example for a single IP address:
$ icinga2 console
<1> => host.address = "192.168.56.101"
null
<2> => cidr_match("192.168.56.0/24", host.address)
true
<3> => cidr_match("192.168.56.0/26", host.address)
false
Example for an array of IP addresses:
$ icinga2 console
<1> => host.vars.vhost_ips = [ "192.168.56.101", "192.168.56.102", "10.0.10.99" ]
null
<2> => cidr_match("192.168.56.0/24", host.vars.vhost_ips, MatchAll)
false
<3> => cidr_match("192.168.56.0/24", host.vars.vhost_ips, MatchAny)
true
range ¶
Signature:
function range(end)
function range(start, end)
function range(start, end, increment)
Returns an array of numbers in the specified range.
If you specify one parameter, the first element starts at 0.
The following array numbers are incremented by 1 and stop before
the specified end.
If you specify the start and end numbers, the returned array
number are incremented by 1. They start at the specified start
number and stop before the end number.
Optionally you can specify the incremented step between numbers
as third parameter.
Example:
$ icinga2 console
<1> => range(5)
[ 0.000000, 1.000000, 2.000000, 3.000000, 4.000000 ]
<2> => range(2,4)
[ 2.000000, 3.000000 ]
<3> => range(2,10,2)
[ 2.000000, 4.000000, 6.000000, 8.000000 ]
len ¶
Signature:
function len(value)
Returns the length of the value, i.e. the number of elements for an array or dictionary, or the length of the string in bytes.
Note: Instead of using this global function you are advised to use the type’s prototype method: Array#len, Dictionary#len and String#len.
Example:
$ icinga2 console
<1> => host.groups = [ "linux-servers", "db-servers" ]
null
<2> => host.groups.len()
2.000000
<3> => host.vars.disks["/"] = {}
null
<4> => host.vars.disks["/var"] = {}
null
<5> => host.vars.disks.len()
2.000000
<6> => host.vars.os_type = "Linux/Unix"
null
<7> => host.vars.os_type.len()
10.000000
union ¶
Signature:
function union(array, array, ...)
Returns an array containing all unique elements from the specified arrays.
Example:
$ icinga2 console
<1> => var dev_notification_groups = [ "devs", "slack" ]
null
<2> => var host_notification_groups = [ "slack", "noc" ]
null
<3> => union(dev_notification_groups, host_notification_groups)
[ "devs", "noc", "slack" ]
intersection ¶
Signature:
function intersection(array, array, ...)
Returns an array containing all unique elements which are common to all specified arrays.
Example:
$ icinga2 console
null
null
<3> => intersection(dev_notification_groups, host_notification_groups)
[ "slack" ]
keys ¶
Signature:
function keys(dict)
Returns an array containing the dictionary’s keys.
Note: Instead of using this global function you are advised to use the type’s prototype method: Dictionary#keys.
Example:
$ icinga2 console
<1> => host.vars.disks["/"] = {}
null
<2> => host.vars.disks["/var"] = {}
null
<3> => host.vars.disks.keys()
[ "/", "/var" ]
string ¶
Signature:
function string(value)
Converts the value to a string.
- Number#to_string
- Boolean#to_string
- String#to_string
- Object#to_string for Array and Dictionary types
- DateTime#to_string
Example:
$ icinga2 console
<1> => 5.to_string()
"5"
<2> => false.to_string()
"false"
<3> => "abc".to_string()
"abc"
<4> => [ "dev", "slack" ].to_string()
"[ \"dev\", \"slack\" ]"
<5> => { "/" = {}, "/var" = {} }.to_string()
"{\n\t\"/\" = {\n\t}\n\t\"/var\" = {\n\t}\n}"
<6> => DateTime(2016, 11, 25).to_string()
"2016-11-25 00:00:00 +0100"
number ¶
Signature:
function number(value)
Converts the value to a number.
Example:
$ icinga2 console
<1> => number(false)
0.000000
<2> => number("78")
78.000000
bool ¶
Signature:
function bool(value)
Converts the value to a bool.
Example:
$ icinga2 console
<1> => bool(1)
true
<2> => bool(0)
false
random ¶
Signature:
function random()
Returns a random value between 0 and RAND_MAX (as defined in stdlib.h).
$ icinga2 console
<1> => random()
1263171996.000000
<2> => random()
108402530.000000
log ¶
Signature:
function log(value)
Writes a message to the log. Non-string values are converted to a JSON string.
Signature:
function log(severity, facility, value)
Writes a message to the log. severity can be one of LogDebug, LogNotice,
LogInformation, LogWarning, and LogCritical.
Example:
$ icinga2 console
<1> => log(LogCritical, "Console", "First line")
critical/Console: First line
null
<2> => var groups = [ "devs", "slack" ]
null
<3> => log(LogCritical, "Console", groups)
critical/Console: ["devs","slack"]
null
typeof ¶
Signature:
function typeof(value)
Returns the Type object for a value.
Example:
$ icinga2 console
<1> => typeof(3) == Number
true
<2> => typeof("str") == String
true
<3> => typeof(true) == Boolean
true
<4> => typeof([ 1, 2, 3]) == Array
true
<5> => typeof({ a = 2, b = 3 }) == Dictionary
true
get_time ¶
Signature:
function get_time()
Returns the current UNIX timestamp as floating point number.
Example:
$ icinga2 console
<1> => get_time()
1480072135.633008
<2> => get_time()
1480072140.401207
parse_performance_data ¶
Signature:
function parse_performance_data(pd)
Parses a performance data string and returns an array describing the values.
Example:
$ icinga2 console
<1> => var pd = "'time'=1480074205.197363;;;"
null
<2> => parse_performance_data(pd)
counter = false
crit = null
label = "time"
max = null
min = null
type = "PerfdataValue"
unit = ""
value = 1480074205.197363
warn = null
getenv ¶
Signature:
function getenv(key)
Returns the value from the specified environment variable key.
Example:
$ MY_ENV_VAR=icinga2 icinga2 console
Type $help to view available commands.
<1> => getenv("MY_ENV_VAR")
"icinga2"
dirname ¶
Signature:
function dirname(path)
Returns the directory portion of the specified path.
Example:
$ icinga2 console
<1> => var path = "/etc/icinga2/scripts/xmpp-notification.pl"
null
<2> => dirname(path)
"/etc/icinga2/scripts"
basename ¶
Signature:
function basename(path)
Returns the filename portion of the specified path.
Example:
$ icinga2 console
null
<2> => basename(path)
"xmpp-notification.pl"
path_exists ¶
Signature:
function path_exists(path)
Returns true if the specified path exists, false otherwise.
Example:
$ icinga2 console
null
<2> => path_exists(path)
true
glob ¶
Signature:
function glob(pathSpec, type)
Returns an array containing all paths which match the
pathSpec argument.
The type argument is optional and specifies which types
of paths are matched. This can be a combination of the GlobFile
and GlobDirectory constants. The default value is GlobFile | GlobDirectory.
$ icinga2 console
<1> => var pathSpec = "/etc/icinga2/conf.d/*.conf"
null
<2> => glob(pathSpec)
[ "/etc/icinga2/conf.d/app.conf", "/etc/icinga2/conf.d/commands.conf", ... ]
glob_recursive ¶
Signature:
function glob_recursive(path, pattern, type)
Recursively descends into the specified directory and returns an array containing
all paths which match the pattern argument.
$ icinga2 console
<1> => var path = "/etc/icinga2/zones.d/"
null
<2> => var pattern = "*.conf"
null
<3> => glob_recursive(path, pattern)
[ "/etc/icinga2/zones.d/global-templates/templates.conf", "/etc/icinga2/zones.d/master/hosts.conf", ... ]
escape_shell_arg ¶
Signature:
function escape_shell_arg(text)
Escapes a string for use as a single shell argument.
Example:
$ icinga2 console
<1> => escape_shell_arg("'$host.name$' '$service.name$'")
"''\\''$host.name$'\\'' '\\''$service.name$'\\'''"
escape_shell_cmd ¶
Signature:
function escape_shell_cmd(text)
Escapes shell meta characters in a string.
Example:
$ icinga2 console
<1> => escape_shell_cmd("/bin/echo 'shell test' $ENV")
"/bin/echo 'shell test' \\$ENV"
escape_create_process_arg ¶
Signature:
function escape_create_process_arg(text)
Escapes a string for use as an argument for CreateProcess(). Windows only.
sleep ¶
Signature:
function sleep(interval)
Sleeps for the specified amount of time (in seconds).
Scoped Functions ¶
This chapter describes functions which are only available in a specific scope.
macro ¶
Signature:
function macro("$macro_name$")
The macro function can be used to resolve runtime macro
strings into their values.
The returned value depends on the attribute value which is resolved
from the specified runtime macro.
This function is only available in runtime evaluated functions, e.g. for custom variables which use the abbreviated lambda syntax.
This example sets the snmp_address custom variable
based on $address$ and $address6$.
vars.snmp_address = {{
var addr_v4 = macro("$address$")
var addr_v6 = macro("$address6$")
if (addr_v4) {
return addr_v4
} else {
return "udp6:[" + addr_v6 + "]"
More reference examples are available inside the Icinga Template Library and the object accessors chapter.
Object Accessor Functions ¶
These functions can be used to retrieve a reference to another object by name.
get_check_command ¶
Signature:
function get_check_command(name);
Returns the CheckCommand object with the specified name, or null if no such CheckCommand object exists.
get_event_command ¶
Signature:
function get_event_command(name);
Returns the EventCommand object with the specified name, or null if no such EventCommand object exists.
get_notification_command ¶
Signature:
function get_notification_command(name);
Returns the NotificationCommand object with the specified name, or null if no such NotificationCommand object exists.
get_host ¶
Signature:
function get_host(host_name);
Returns the Host object with the specified name, or null if no such Host object exists.
get_service ¶
Signature:
function get_service(host_name, service_name);
function get_service(host, service_name);
Returns the Service object with the specified host name or object and service name pair,
or null if no such Service object exists.
Example in the debug console
which fetches the disk service object from the current Icinga 2 node:
$ ICINGA2_API_PASSWORD=icinga icinga2 console --connect 'https://root@localhost:5665/'
<1> => get_service(NodeName, "disk")
<2> => get_service(NodeName, "disk").__name
"icinga2-master1.localdomain!disk"
<3> => get_service(get_host(NodeName), "disk").__name
get_services ¶
Signature:
function get_services(host_name);
function get_services(host);
Returns an array of service objects for the specified host name or object,
or null if no such host object exists.
Example in the debug console which fetches all service objects from the current Icinga 2 node:
<1> => get_services(NodeName).map(s => s.name)
[ "disk", "disk /", "http", "icinga", "load", "ping4", "ping6", "procs", "ssh", "users" ]
Note: map takes a lambda function as argument. In this example
we only want to collect and print the name attribute with s => s.name.
This works in a similar fashion for a host object where you can extract all service states in using the map functionality:
<2> => get_services(get_host(NodeName)).map(s => s.state)
[ 2.000000, 2.000000, 2.000000, 0.000000, 0.000000, 0.000000, 2.000000, 0.000000, 0.000000, 1.000000, 0.000000, 0.000000 ]
get_user ¶
Signature:
function get_user(name);
Returns the User object with the specified name, or null if no such User object exists.
get_host_group ¶
Signature:
function get_host_group(name);
Returns the HostGroup object with the specified name, or null if no such HostGroup object exists.
get_service_group ¶
Signature:
function get_service_group(name);
Returns the ServiceGroup object with the specified name, or null if no such ServiceGroup object exists.
get_user_group ¶
Signature:
function get_user_group(name);
Returns the UserGroup object with the specified name, or null if no such UserGroup object exists.
get_time_period ¶
Signature:
function get_time_period(name);
Returns the TimePeriod object with the specified name, or null if no such TimePeriod object exists.
get_object ¶
Signature:
function get_object(type, name);
Returns the object with the specified type and name, or null if no such object exists. type must refer
to a type object.
get_objects ¶
Signature:
function get_objects(type);
Returns an array of objects whose type matches the specified type. type must refer
to a type object.
Math object ¶
The global Math object can be used to access a number of mathematical constants
and functions.
Math.E ¶
Euler’s constant.
Math.LN2 ¶
Natural logarithm of 2.
Math.LN10 ¶
Natural logarithm of 10.
Math.LOG2E ¶
Base 2 logarithm of E.
Math.PI ¶
The mathematical constant Pi.
Math.SQRT1_2 ¶
Square root of 1/2.
Math.SQRT2 ¶
Square root of 2.
Math.abs ¶
Signature:
function abs(x);
Returns the absolute value of x.
Math.acos ¶
Signature:
function acos(x);
Returns the arccosine of x.
Math.asin ¶
Signature:
function asin(x);
Returns the arcsine of x.
Math.atan ¶
Signature:
function atan(x);
Returns the arctangent of x.
Math.atan2 ¶
Signature:
function atan2(y, x);
y and x.
Math.ceil ¶
Signature:
function ceil(x);
Returns the smallest integer value not less than x.
Math.cos ¶
Signature:
function cos(x);
Returns the cosine of x.
Math.exp ¶
Signature:
function exp(x);
Returns E raised to the xth power.
Math.floor ¶
Signature:
function floor(x);
Returns the largest integer value not greater than x.
Math.isinf ¶
Signature:
function isinf(x);
Returns whether x is infinite.
Math.isnan ¶
Signature:
function isnan(x);
Returns whether x is NaN (not-a-number).
Math.log ¶
Signature:
function log(x);
Returns the natural logarithm of x.
Math.max ¶
Signature:
function max(...);
Returns the largest argument. A variable number of arguments can be specified. If no arguments are given, -Infinity is returned.
Math.min ¶
Signature:
function min(...);
Returns the smallest argument. A variable number of arguments can be specified. If no arguments are given, +Infinity is returned.
Math.pow ¶
Signature:
function pow(x, y);
Returns x raised to the yth power.
Math.random ¶
Signature:
function random();
Returns a pseudo-random number between 0 and 1.
Math.round ¶
Signature:
function round(x);
Returns x rounded to the nearest integer value.
Math.sign ¶
Signature:
function sign(x);
Returns -1 if x is negative, 1 if x is positive
and 0 if x is 0.
Math.sin ¶
Signature:
function sin(x);
Returns the sine of x.
Math.sqrt ¶
Signature:
function sqrt(x);
Returns the square root of x.
Math.tan ¶
Signature:
function tan(x);
Returns the tangent of x.
Json object ¶
The global Json object can be used to encode and decode JSON.
Json.encode ¶
Signature:
function encode(x);
Encodes an arbitrary value into JSON.
Json.decode ¶
Signature:
function decode(x);
Decodes a JSON string.
Number type ¶
Number#to_string ¶
Signature:
function to_string();
The to_string method returns a string representation of the number.
Example:
var example = 7
example.to_string() /* Returns "7" */
Boolean type ¶
Boolean#to_string ¶
Signature:
The to_string method returns a string representation of the boolean value.
Example:
var example = true
example.to_string() /* Returns "true" */
String type ¶
String#find ¶
Signature:
function find(str, start);
Returns the zero-based index at which the string str was found in the string. If the string
was not found, -1 is returned. start specifies the zero-based index at which find should
start looking for the string (defaults to 0 when not specified).
Example:
"Hello World".find("World") /* Returns 6 */
String#contains ¶
Signature:
function contains(str);
Returns true if the string str was found in the string. If the string
was not found, false is returned. Use find
for getting the index instead.
Example:
"Hello World".contains("World") /* Returns true */
String#len ¶
Signature
function len();
Returns the length of the string in bytes. Note that depending on the encoding type of the string this is not necessarily the number of characters.
Example:
"Hello World".len() /* Returns 11 */
String#lower ¶
Signature:
function lower();
Returns a copy of the string with all of its characters converted to lower-case.
Example:
"Hello World".lower() /* Returns "hello world" */
String#upper ¶
Signature:
function upper();
Returns a copy of the string with all of its characters converted to upper-case.
Example:
"Hello World".upper() /* Returns "HELLO WORLD" */
String#replace ¶
Signature:
function replace(search, replacement);
Returns a copy of the string with all occurences of the string specified in search replaced
with the string specified in replacement.
String#split ¶
Signature:
function split(delimiters);
Splits a string into individual parts and returns them as an array. The delimiters argument
specifies the characters which should be used as delimiters between parts.
Example:
"x-7,y".split("-,") /* Returns [ "x", "7", "y" ] */
String#substr ¶
Signature:
function substr(start, len);
Returns a part of a string. The start argument specifies the zero-based index at which the part begins.
The optional len argument specifies the length of the part (“until the end of the string” if omitted).
Example:
"Hello World".substr(6) /* Returns "World" */
String#to_string ¶
Signature:
Returns a copy of the string.
String#reverse ¶
Signature:
function reverse();
Returns a copy of the string in reverse order.
String#trim ¶
Signature:
function trim();
Removes trailing whitespaces and returns the string.
Object type ¶
This is the base type for all types in the Icinga application.
Object#clone ¶
Signature:
function clone();
Returns a copy of the object. Note that for object elements which are reference values (e.g. objects such as arrays or dictionaries) the entire object is recursively copied.
Object#to_string ¶
Signature:
Returns a string representation for the object. Unless overridden this returns a string
of the format “Object of type ‘
Example:
[ 3, true ].to_string() /* Returns "[ 3.000000, true ]" */
Object#type ¶
Signature:
String type;
Returns the object’s type name. This attribute is read-only.
Example:
get_host("localhost").type /* Returns "Host" */
Type type ¶
Inherits methods from the Object type.
The Type type provides information about the underlying type of an object or scalar value.
All types are registered as global variables. For example, in order to obtain a reference to the String type the global variable String can be used.
Type#base ¶
Signature:
Type base;
Returns a reference to the type’s base type. This attribute is read-only.
Example:
Dictionary.base == Object /* Returns true, because the Dictionary type inherits directly from the Object type. */
Type#name ¶
Signature:
String name;
Returns the name of the type.
Type#prototype ¶
Signature:
Object prototype;
Returns the prototype object for the type. When an attribute is accessed on an object that doesn’t exist the prototype object is checked to see if an attribute with the requested name exists. If it does, the attribute’s value is returned.
The prototype functionality is used to implement methods.
Example:
3.to_string() /* Even though '3' does not have a to_string property the Number type's prototype object does. */
Array type ¶
Array#add ¶
Signature:
function add(value);
Adds a new value after the last element in the array.
Array#clear ¶
Signature:
function clear();
Removes all elements from the array.
Array#shallow_clone ¶
function shallow_clone();
Returns a copy of the array. Note that for elements which are reference values (e.g. objects such as arrays and dictionaries) only the references are copied.
Array#contains ¶
Signature:
function contains(value);
Returns true if the array contains the specified value, false otherwise.
Array#freeze ¶
Signature:
function freeze()
Disallows further modifications to this array. Trying to modify the array will result in an exception.
Array#len ¶
Signature:
function len();
Returns the number of elements contained in the array.
Array#remove ¶
Signature:
function remove(index);
Removes the element at the specified zero-based index.
Array#set ¶
Signature:
function set(index, value);
Sets the element at the zero-based index to the specified value. The index must refer to an element
which already exists in the array.
Array#get ¶
Signature:
function get(index);
Retrieves the element at the specified zero-based index.
Array#sort ¶
Signature:
function sort(less_cmp);
Returns a copy of the array where all items are sorted. The items are
compared using the < (less-than) operator. A custom comparator function
can be specified with the less_cmp argument.
Array#join ¶
Signature:
function join(separator);
Joins all elements of the array using the specified separator.
Array#reverse ¶
Signature:
function reverse();
Returns a new array with all elements of the current array in reverse order.
Array#map ¶
Signature:
function map(func);
Calls func(element) for each of the elements in the array and returns
a new array containing the return values of these function calls.
Array#reduce ¶
Signature:
function reduce(func);
Reduces the elements of the array into a single value by calling the provided
function func as func(a, b) repeatedly where a and b are elements of the array
or results from previous function calls.
Array#filter ¶
Signature:
function filter(func);
Returns a copy of the array containing only the elements for which func(element)
is true.
Array#any ¶
Signature:
function any(func);
Returns true if the array contains at least one element for which func(element)
is true, false otherwise.
Array#all ¶
Signature:
function all(func);
Returns true if the array contains only elements for which func(element)
Array#unique ¶
Signature:
function unique();
Returns a copy of the array with all duplicate elements removed. The original order of the array is not preserved.
Dictionary type ¶
Dictionary#shallow_clone ¶
Signature:
Returns a copy of the dictionary. Note that for elements which are reference values (e.g. objects such as arrays and dictionaries) only the references are copied.
Dictionary#contains ¶
Signature:
function contains(key);
Returns true if a dictionary item with the specified key exists, false otherwise.
Dictionary#freeze ¶
Signature:
function freeze()
Disallows further modifications to this dictionary. Trying to modify the dictionary will result in an exception.
Dictionary#len ¶
Signature:
function len();
Returns the number of items contained in the dictionary.
Dictionary#remove ¶
Signature:
function remove(key);
Removes the item with the specified key. Trying to remove an item which does not exist
is a no-op.
Dictionary#clear ¶
Signature:
function clear();
Removes all items from the dictionary.
Dictionary#set ¶
Signature:
function set(key, value);
Creates or updates an item with the specified key and value.
Dictionary#get ¶
Signature:
function get(key);
Retrieves the value for the specified key. Returns null if they key does not exist
in the dictionary.
Dictionary#keys ¶
Signature:
function keys();
Returns a list of keys for all items that are currently in the dictionary.
Dictionary#values ¶
Signature:
function values();
Returns a list of values for all items that are currently in the dictionary.
Function type ¶
Function#call ¶
Signature:
function call(thisArg, ...);
Invokes the function using an alternative this scope. The thisArg argument specifies the this
scope for the function. All other arguments are passed directly to the function.
Example:
function set_x(val) {
this.x = val
dict = {}
set_x.call(dict, 7) /* Invokes set_x using `dict` as `this` */
Function#callv ¶
Signature:
function callv(thisArg, args);
scope for the function. The items in the args array are passed to the function as individual arguments.
Example:
this.x = val
var dict = {}
var args = [ 7 ]
set_x.callv(dict, args) /* Invokes set_x using `dict` as `this` */
DateTime type ¶
DateTime constructor ¶
Signature:
function DateTime()
function DateTime(unixTimestamp)
function DateTime(year, month, day)
function DateTime(year, month, day, hours, minutes, seconds)
Constructs a new DateTime object. When no arguments are specified for the constructor a new DateTime object representing the current time is created.
Example:
var d1 = DateTime() /* current time */
var d2 = DateTime(2016, 5, 21) /* midnight April 21st, 2016 (local time) */
DateTime arithmetic ¶
Subtracting two DateTime objects yields the interval between them, in seconds.
Example:
var delta = DateTime() - DateTime(2016, 5, 21) /* seconds since midnight April 21st, 2016 */
Subtracting a number from a DateTime object yields a new DateTime object that is further in the past:
Example:
var dt = DateTime() - 2 * 60 * 60 /* Current time minus 2 hours */
Adding a number to a DateTime object yields a new DateTime object that is in the future:
Example:
var dt = DateTime() + 24 * 60 * 60 /* Current time plus 24 hours */
DateTime#format ¶
Signature:
function format(fmt)
Returns a string representation for the DateTime object using the specified format string. The format string may contain format conversion placeholders as specified in strftime(3).
Example:
var s = DateTime(2016, 4, 21).format("%A") /* Sets s to "Thursday". */
DateTime#to_string ¶
Signature:
Returns a string representation for the DateTime object. Uses a suitable default format.
Example:
var s = DateTime(2016, 4, 21).to_string() /* Sets s to "2016-04-21 00:00:00 +0200". */
