Language Reference ¶
Object Definition ¶
Icinga 2 features an object-based configuration format. You can define new
objects using the object keyword:
object Host "host1.example.org" {
display_name = "host1"
address = "192.168.0.1"
address6 = "2001:db8:1234::42"
In general you need to write each statement on a new line. Expressions started
with {, ( and [ extend until the matching closing character and can be broken
up into multiple lines.
Alternatively you can write multiple statements on a single line by separating them with a semicolon:
address = "192.168.0.1"; address6 = "2001:db8:1234::42"
Each object is uniquely identified by its type (Host) and name
(host1.example.org). Some types have composite names, e.g. the
Service type which uses the host_name attribute and the name
you specified to generate its object name.
Exclamation marks (!) are not permitted in object names.
Objects can contain a comma-separated list of property declarations. Instead of commas semicolons may also be used. The following data types are available for property values:
All objects have at least the following attributes:
| Attribute | Description |
| name | The name of the object. This attribute can be modified in the object definition to override the name specified with the object directive. |
| type | The type of the object. |
Expressions ¶
The following expressions can be used on the right-hand side of assignments.
Numeric Literals ¶
A floating-point number.
Example:
27.3
Duration Literals ¶
Similar to floating-point numbers except for the fact that they support suffixes to help with specifying time durations.
Example:
2.5m
Supported suffixes include ms (milliseconds), s (seconds), m (minutes), h (hours) and d (days).
Duration literals are converted to seconds by the config parser and are treated like numeric literals.
String Literals ¶
A string.
Example:
"Hello World!"
String Literals Escape Sequences ¶
Certain characters need to be escaped. The following escape sequences are supported:
| Character | Escape sequence |
| <TAB> | \t |
| <CARRIAGE-RETURN> | \r |
| <LINE-FEED> | \n |
| <BEL> | \b |
| <FORM-FEED> | \f |
In addition to these pre-defined escape sequences you can specify arbitrary ASCII characters using the backslash character (\) followed by an ASCII character in octal encoding.
Multi-line String Literals ¶
Strings spanning multiple lines can be specified by enclosing them in {{{ and }}}.
Example:
{{{This
is
a multi-line
string.}}}
Unlike in ordinary strings special characters do not have to be escaped in multi-line string literals.
Boolean Literals ¶
The keywords true and false are used to denote truth values.
Null Value ¶
The null keyword can be used to specify an empty value.
Dictionary ¶
An unordered list of key-value pairs. Keys must be unique and are compared in a case-sensitive manner.
Individual key-value pairs must either be comma-separated or on separate lines. The comma after the last key-value pair is optional.
Example:
port = 443
Identifiers may not contain certain characters (e.g. space) or start with certain characters (e.g. digits). If you want to use a dictionary key that is not a valid identifier, you can enclose the key in double quotes.
Array ¶
An ordered list of values.
Individual array elements must be comma-separated. The comma after the last element is optional.
Example:
[ "hello", 42 ]
An array may simultaneously contain values of different types, such as strings and numbers.
Operators ¶
The following operators are supported in expressions. The operators are sorted by descending precedence.
| Operator | Precedence | Examples (Result) | Description |
1 | (3 + 3) * 5 | Groups sub-expressions |
1 | Math.random() | Calls a function |
1 | a[3] | Array subscript |
1 | a.b | Element access |
2 | !”Hello” (false), !false (true) | Logical negation of the operand |
2 | ~true (false) | Bitwise negation of the operand |
2 | +3 | Unary plus |
2 | -3 | Unary minus |
2 | &var (reference to ‘var’) | Reference operator |
2 | *var | Indirection operator |
3 | 5m * 10 (3000) | Multiplies two numbers |
3 | 5m / 5 (60) | Divides two numbers |
3 | 17 % 12 (5) | Remainder after division |
4 | 1 + 3 (4), “hello ” + “world” (“hello world”) | Adds two numbers; concatenates strings |
4 | 3 - 1 (2) | Subtracts two numbers |
5 | 4 << 8 (1024) | Left shift |
5 | 1024 >> 4 (64) | Right shift |
6 | 3 < 5 (true) | Less than |
6 | 3 > 5 (false) | Greater than |
6 | 3 <= 3 (true) | Less than or equal |
6 | 3 >= 3 (true) | Greater than or equal |
in |
7 | “foo” in [ “foo”, “bar” ] (true) | Element contained in array |
!in |
7 | “foo” !in [ “bar”, “baz” ] (true) | Element not contained in array |
8 | “hello” == “hello” (true), 3 == 5 (false) | Equal to |
8 | “hello” != “world” (true), 3 != 3 (false) | Not equal to |
9 | 7 & 3 (3) | Binary AND |
10 | 17 ^ 12 (29) | Bitwise XOR |
11 | 2 | 3 (3) | Binary OR |
12 | true || false (true), 0 || 7 (7) | Logical OR |
13 | true && false (false), 3 && 7 (7), 0 && 7 (0) | Logical AND |
14 | a = 3 | Assignment |
15 | x => x * x (function with arg x) | Lambda, for loop |
References ¶
A reference to a value can be obtained using the & operator. The * operator can be used
to dereference a reference:
var value = "Hello!"
var p = &value /* p refers to value */
*p = "Hi!"
log(value) // Prints "Hi!" because the variable was changed
Namespaces ¶
Namespaces can be used to organize variables and functions. They are used to avoid name conflicts. The namespace
keyword is used to create a new namespace:
namespace Utils {
function calculate() {
return 2 + 2
The namespace is made available as a global variable which has the namespace’s name (e.g. Utils):
Utils.calculate()
The using keyword can be used to make all attributes in a namespace available to a script without having to
explicitly specify the namespace’s name for each access:
using Utils
calculate()
The using keyword only has an effect for the current file and only for code that follows the keyword:
calculate() // This will not work.
using Utils
The following namespaces are automatically imported as if by using the using keyword:
- System
- System.Configuration
- Types
- Icinga
Function Calls ¶
Functions can be called using the () operator:
const MyGroups = [ "test1", "test" ]
check_interval = len(MyGroups) * 1m
A list of available functions is available in the Library Reference chapter.
Assignments ¶
In addition to the = operator shown above a number of other operators
to manipulate attributes are supported. Here’s a list of all
available operators (the outermost { } stand for a local variable scope):
Operator = ¶
Sets an attribute to the specified value.
Example:
a = 5
a = 7
In this example a has the value 7 after both instructions are executed.
Operator += ¶
The += operator is a shortcut. The following expression:
a = [ "hello" ]
a += [ "world" ]
is equivalent to:
a = [ "hello" ]
a = a + [ "world" ]
Operator -= ¶
The -= operator is a shortcut. The following expression:
a = 10
a -= 5
is equivalent to:
a = 10
a = a - 5
Operator *= ¶
The *= operator is a shortcut. The following expression:
a = 60
a *= 5
is equivalent to:
a = 60
a = a * 5
Operator /= ¶
The /= operator is a shortcut. The following expression:
a = 300
a /= 5
is equivalent to:
a = 300
a = a / 5
Indexer ¶
The indexer syntax provides a convenient way to set dictionary elements.
Example:
hello.key = "world"
Example (alternative syntax):
hello["key"] = "world"
This is equivalent to writing:
hello += {
key = "world"
If the hello attribute does not already have a value, it is automatically initialized to an empty dictionary.
Template Imports ¶
Objects can import attributes from other objects.
Example:
template Host "default-host" {
vars.colour = "red"
template Host "test-host" {
import "default-host"
vars.colour = "blue"
object Host "localhost" {
import "test-host"
address = "127.0.0.1"
address6 = "::1"
The default-host and test-host objects are marked as templates
using the template keyword. Unlike ordinary objects templates are not
instantiated at run-time. Parent objects do not necessarily have to be
templates, however in general they are.
The vars dictionary for the localhost object contains all three
custom variables and the custom variable colour has the value "blue".
Parent objects are resolved in the order they’re specified using the
import keyword.
Default templates which are automatically imported into all object definitions
can be specified using the default keyword:
template CheckCommand "plugin-check-command" default {
Default templates are imported before any other user-specified statement in an object definition is evaluated.
If there are multiple default templates the order in which they are imported is unspecified.
Constants ¶
Global constants can be set using the const keyword:
const VarName = "some value"
Once defined a constant can be accessed from any file. Constants cannot be changed once they are set.
Tip
Best practice is to manage constants in the constants.conf file.
Icinga 2 Specific Constants ¶
Icinga 2 provides a number of special global constants. These include directory paths, global configuration and runtime parameters for the application version and (build) platform.
Directory Path Constants ¶
| Constant | Description |
| ConfigDir | Read-only. Main configuration directory. Usually set to /etc/icinga2. |
| DataDir | Read-only. Runtime data for the Icinga daemon. Usually set to /var/lib/icinga2. |
| LogDir | Read-only. Logfiles from the daemon. Usually set to /var/log/icinga2. |
| CacheDir | Read-only. Cached status information of the daemon. Usually set to /var/cache/icinga2. |
| SpoolDir | Read-only. Spool directory for certain data outputs. Usually set to /var/spool/icinga2. |
| InitRunDir | Read-only. Directory for PID files and sockets in daemon mode. Usually set to /run/icinga2. |
| ZonesDir | Read-only. Contains the path of the zones.d directory. Defaults to ConfigDir + "/zones.d". |
Global Configuration Constants ¶
| Vars | Read-write. Contains a dictionary with global custom variables. Not set by default. |
| NodeName | Read-write. Contains the cluster node name. Set to the local hostname by default. |
| ReloadTimeout | Read-write. Defines the reload timeout for child processes. Defaults to 300s. |
| Environment | Read-write. The name of the Icinga environment. Included in the SNI host name for outbound connections. Not set by default. |
| RunAsUser | Read-write. Defines the user the Icinga 2 daemon is running as. Set in the Icinga 2 sysconfig. |
| RunAsGroup | Read-write. Defines the group the Icinga 2 daemon is running as. Set in the Icinga 2 sysconfig. |
| MaxConcurrentChecks | Read-write. The number of max checks run simultaneously. Defaults to 512. |
| ApiBindHost | Read-write. Overrides the default value for the ApiListener bind_host attribute. Not set by default. |
| ApiBindPort | Read-write. Overrides the default value for the ApiListener bind_port attribute. Not set by default. |
Application Runtime Constants ¶
| PlatformName | Read-only. The name of the operating system, e.g. Ubuntu. |
| PlatformVersion | Read-only. The version of the operating system, e.g. 14.04.3 LTS. |
| PlatformKernel | Read-only. The name of the operating system kernel, e.g. Linux. |
| PlatformKernelVersion | Read-only. The version of the operating system kernel, e.g. 3.13.0-63-generic. |
| BuildCompilerName | Read-only. The name of the compiler Icinga was built with, e.g. Clang. |
| BuildCompilerVersion | Read-only. The version of the compiler Icinga was built with, e.g. 7.3.0.7030031. |
| BuildHostName | Read-only. The name of the host Icinga was built on, e.g. acheron. |
| ApplicationVersion | Read-only. The application version, e.g. 2.9.0. |
Additional Constants ¶
Writable constants can be specified on the CLI using the --define/-D parameter.
Note for v2.10+
Default paths which include
/etcand/varas base directory continue to work based on theSysconfDirandLocalStateDirconstants respectively.
In addition to that, the constants below are used to define specific file paths. You should never need to change them, as they are pre-compiled based on the constants above.
| Variable | Description |
| StatePath | Read-write. Contains the path of the Icinga 2 state file. Defaults to DataDir + "/icinga2.state". |
| ObjectsPath | Read-write. Contains the path of the Icinga 2 objects file. Defaults to CacheDir + "/icinga2.debug". |
| PidPath | Read-write. Contains the path of the Icinga 2 PID file. Defaults to InitRunDir + "/icinga2.pid". |
| PkgDataDir | Read-only. Contains the path of the package data directory. Defaults to PrefixDir + "/share/icinga2". |
The constants below have been used until Icinga v2.10, and are still intact. You don’t need them for future builds and configuration based on the newly available constants above.
| PrefixDir | Read-only. Contains the installation prefix that was specified with cmake -DCMAKE_INSTALL_PREFIX. Defaults to "/usr/local". |
| SysconfDir | Read-only. Contains the path of the sysconf directory. Defaults to PrefixDir + "/etc". |
| LocalStateDir | Read-only. Contains the path of the local state directory. Defaults to PrefixDir + "/var". |
| RunDir | Read-only. Contains the path of the run directory. Defaults to LocalStateDir + "/run". |
Advanced Constants and Variables ¶
Advanced runtime constants. Please only use them if advised by support or developers.
| EventEngine | Read-write. The name of the socket event engine, can be poll or epoll. The epoll interface is only supported on Linux. |
| AttachDebugger | Read-write. Whether to attach a debugger when Icinga 2 crashes. Defaults to false. |
Advanced sysconfig environment variables, defined in /etc/sysconfig/icinga2 (RHEL/SLES) or /etc/default/icinga2 (Debian/Ubuntu).
| ICINGA2_RLIMIT_FILES | Read-write. Defines the resource limit for RLIMIT_NOFILE that should be set at start-up. Value cannot be set lower than the default 16 * 1024. 0 disables the setting. Set in Icinga 2 sysconfig. |
| ICINGA2_RLIMIT_PROCESSES | Read-write. Defines the resource limit for RLIMIT_NPROC that should be set at start-up. Value cannot be set lower than the default 16 * 1024. 0 disables the setting. Set in Icinga 2 sysconfig. |
| ICINGA2_RLIMIT_STACK | Read-write. Defines the resource limit for RLIMIT_STACK that should be set at start-up. Value cannot be set lower than the default 256 * 1024. 0 disables the setting. Set in Icinga 2 sysconfig. |
Apply ¶
The apply keyword can be used to create new objects which are associated with
another group of objects.
apply Service "ping" to Host {
import "generic-service"
check_command = "ping4"
assign where host.name == "localhost"
In this example the assign where condition is a boolean expression which is
evaluated for all objects of type Host and a new service with name “ping”
is created for each matching host. Expression operators
may be used in assign where conditions.
The to keyword and the target type may be omitted if there is only one target
type, e.g. for the Service type.
Depending on the object type used in the apply expression additional local
variables may be available for use in the where condition:
| Source Type | Target Type | Variables |
| Service | Host | host |
| Dependency | Host | host |
| Dependency | Service | host, service |
| Notification | Host | host |
| Notification | Service | host, service |
| ScheduledDowntime | Host | host |
| ScheduledDowntime | Service | host, service |
Any valid config attribute can be accessed using the host and service
variables. For example, host.address would return the value of the host’s
“address” attribute – or null if that attribute isn’t set.
More usage examples are documented in the monitoring basics chapter.
Apply For ¶
Apply rules can be extended with the for loop keyword.
apply Service "prefix-" for (key => value in host.vars.dictionary) to Host {
vars.host_value = value
variables. The attribute must be of the Array or Dictionary type. In this example
host.vars.dictionary is of the Dictionary type which needs a key-value-pair
as iterator.
In this example all generated service object names consist of prefix- and
the value of the key iterator. The prefix string can be omitted if not required.
The key and value variables can be used for object attribute assignment, e.g. for
setting the check_command attribute or custom variables as command parameters.
apply for rules are first evaluated against all objects matching the for loop list
and afterwards the assign where and ignore where conditions are evaluated.
It is not necessary to check attributes referenced in the for loop expression
for their existance using an additional assign where condition.
Group Assign ¶
Group objects can be assigned to specific member objects using the assign where
and ignore where conditions.
object HostGroup "linux-servers" {
display_name = "Linux Servers"
assign where host.vars.os == "Linux"
In this example the assign where condition is a boolean expression which is evaluated
for all objects of the type Host. Each matching host is added as member to the host group
with the name “linux-servers”. Membership exclusion can be controlled using the ignore where
condition. Expression operators may be used in assign where and
| Source Type | Variables |
| HostGroup | host |
| ServiceGroup | host, service |
| UserGroup | user |
Boolean Values ¶
The assign where, ignore where, if and while statements, the ! operator as
well as the bool() function convert their arguments to a boolean value based on the
following rules:
| Description | Example Value | Boolean Value |
| Empty value | null | false |
| Zero | 0 | false |
| Non-zero integer | -23945 | true |
| Empty string | ”“ | false |
| Non-empty string | “Hello” | true |
| Empty array | [] | false |
| Non-empty array | [ “Hello” ] | true |
| Empty dictionary | {} | false |
| Non-empty dictionary | { key = “value” } | true |
For a list of supported expression operators for assign where and ignore where
statements, see expression operators.
Comments ¶
The Icinga 2 configuration format supports C/C++-style and shell-style comments.
Example:
This is a comment.
check_interval = 30 // this is also a comment.
retry_interval = 15 # yet another comment
Includes ¶
Other configuration files can be included using the include directive.
Paths must be relative to the configuration file that contains the
include directive.
Example:
include "some/other/file.conf"
include "conf.d/*.conf"
Wildcard includes are not recursive.
Icinga also supports include search paths similar to how they work in a C/C++ compiler:
include <itl>
Note the use of angle brackets instead of double quotes. This causes the config compiler to search the include search paths for the specified file. By default $PREFIX/share/icinga2/include is included in the list of search paths. Additional include search paths can be added using command-line options.
Wildcards are not permitted when using angle brackets.
Recursive Includes ¶
The include_recursive directive can be used to recursively include all
files in a directory which match a certain pattern.
Example:
include_recursive "conf.d", "*.conf"
include_recursive "templates"
The first parameter specifies the directory from which files should be recursively included.
The file names need to match the pattern given in the second parameter. When no pattern is specified the default pattern “*.conf” is used.
Zone Includes ¶
Note
This is an internal functionality consumed by Icinga itself.
The preferred way for users managing configuration files in zones is to use the cluster config sync or REST API config packages.
The include_zones recursively includes all subdirectories for the
given path.
In addition to that it sets the zone attribute for all objects created
in these subdirectories to the name of the subdirectory.
Example:
include_zones "etc", "zones.d", "*.conf"
include_zones "puppet", "puppet-zones"
The first parameter specifies a tag name for this directive. Each include_zones
invocation should use a unique tag name. When copying the zones’ configuration
files Icinga uses the tag name as the name for the destination directory in
/var/lib/icinga2/api/config.
The second parameter specifies the directory which contains the subdirectories.
The file names need to match the pattern given in the third parameter. When no pattern is specified the default pattern “*.conf” is used.
Library directive ¶
The library directive was used to manually load additional
libraries. Starting with version 2.9 it is no longer necessary to explicitly load
libraries and this directive has no effect.
Functions ¶
Functions can be defined using the function keyword.
Example:
function multiply(a, b) {
return a * b
When encountering the return keyword further execution of the function is terminated and
the specified value is supplied to the caller of the function:
log(multiply(3, 5))
In this example the multiply function we declared earlier is invoked with two arguments (3 and 5).
The function computes the product of those arguments and makes the result available to the
function’s caller.
When no value is supplied for the return statement the function returns null.
Functions which do not have a return statement have their return value set to the value of the
last expression which was performed by the function. For example, we could have also written our
multiply function like this:
a * b
Anonymous functions can be created by omitting the name in the function definition. The resulting function object can be used like any other value:
var fn = function() { 3 }
fn() /* Returns 3 */
Lambda Expressions ¶
Functions can also be declared using the alternative lambda syntax.
Example:
f = (x) => x * x
Multiple statements can be used by putting the function body into braces:
f = (x) => {
log("Lambda called")
x * x
Just like with ordinary functions the return value is the value of the last statement.
For lambdas which take exactly one argument the braces around the arguments can be omitted:
f = x => x * x
Abbreviated Lambda Syntax ¶
Lambdas which take no arguments can also be written using the abbreviated lambda syntax.
Example:
f = {{ 3 }}
This creates a new function which returns the value 3.
Variable Scopes ¶
When setting a variable Icinga checks the following scopes in this order whether the variable already exists there:
- Local Scope
thisScope- Global Scope
The local scope contains variables which only exist during the invocation of the current function,
object or apply statement. Local variables can be declared using the var keyword:
var temp = a * b
return temp
Each time the multiply function is invoked a new temp variable is used which is in no way
related to previous invocations of the function.
When setting a variable which has not previously been declared as local using the var keyword
the this scope is used.
The this scope refers to the current object which the function or object/apply statement
operates on.
check_interval = 5m
In this example the this scope refers to the “localhost” object. The check_interval attribute
is set for this particular host.
You can explicitly access the this scope using the this keyword:
var check_interval = 5m
/* This explicitly specifies that the attribute should be set
* for the host, if we had omitted `this.` the (poorly named)
* local variable `check_interval` would have been modified instead.
this.check_interval = 1m
locals and globals are available to access the local and global scope.
Functions also have a this scope. However unlike for object/apply statements the this scope for
a function is set to whichever object was used to invoke the function. Here’s an example:
hm = {
h_word = null
function init(word) {
h_word = word
/* Let's invoke the init() function */
hm.init("hello")
We’re using hm.init to invoke the function which causes the value of hm to become the this
scope for this function call.
Closures ¶
By default functions, objects and apply rules do not have access to variables declared
outside of their scope (except for global variables).
In order to access variables which are defined in the outer scope the use keyword can be used:
function MakeHelloFunction(name) {
return function() use(name) {
log("Hello, " + name)
In this case a new variable name is created inside the inner function’s scope which has the
value of the name function argument.
Alternatively a different value for the inner variable can be specified:
return function() use (greeting = "Hello, " + name) {
log(greeting)
Conditional Statements ¶
Sometimes it can be desirable to only evaluate statements when certain conditions are met. The if/else construct can be used to accomplish this.
Example:
a = 3
if (a < 5) {
a *= 7
} else if (a > 10) {
a *= 5
} else {
a *= 2
An if/else construct can also be used in place of any other value. The value of an if/else statement is the value of the last statement which was evaluated for the branch which was taken:
a = if (true) {
log("Taking the 'true' branch")
7 * 3
} else {
log("Taking the 'false' branch")
9
This example prints the log message “Taking the ‘true’ branch” and the a variable is set to 21 (7 * 3).
The value of an if/else construct is null if the condition evaluates to false and no else branch is given.
While Loops ¶
The while statement checks a condition and executes the loop body when the condition evaluates to true.
This is repeated until the condition is no longer true.
Example:
var num = 5
while (num > 5) {
log("Test")
num -= 1
The continue and break keywords can be used to control how the loop is executed: The continue keyword
skips over the remaining expressions for the loop body and begins the next loop evaluation. The break keyword
breaks out of the loop.
For Loops ¶
The for statement can be used to iterate over arrays and dictionaries.
Example:
var list = [ "a", "b", "c" ]
for (var item in list) {
log("Item: " + item)
The loop body is evaluated once for each item in the array. The variable item is declared as a local
variable just as if the var keyword had been used.
Iterating over dictionaries can be accomplished in a similar manner:
var dict = { a = 3, b = 7 }
for (var key => var value in dict) {
log("Key: " + key + ", Value: " + value)
The var keyword is optional when declaring variables in the loop’s header. Variables declared without the var
keyword are nonetheless local to the function.
Constructors ¶
In order to create a new value of a specific type constructor calls may be used.
Example:
var pd = PerfdataValue()
pd.label = "test"
pd.value = 10
You can also try to convert an existing value to another type by specifying it as an argument for the constructor call.
Example:
var s = String(3) /* Sets s to "3". */
Throwing Exceptions ¶
Built-in commands may throw exceptions to signal errors such as invalid arguments. User scripts can throw exceptions
using the throw keyword.
Example:
throw "An error occurred."
Handling Exceptions ¶
Exceptions can be handled using the try and except keywords. When an exception occurs while executing code in the
try clause no further statements in the try clause are evaluated and the except clause is executed instead.
Example:
try {
throw "Test"
log("This statement won't get executed.")
} except {
log("An error occurred in the try clause.")
Breakpoints ¶
The debugger keyword can be used to insert a breakpoint. It may be used at any place where an assignment would also be a valid expression.
By default breakpoints have no effect unless Icinga is started with the --script-debugger command-line option. When the script debugger is enabled Icinga stops execution of the script when it encounters a breakpoint and spawns a console which lets the user inspect the current state of the execution environment.
Types ¶
All values have a static type. The typeof function can be used to determine the type of a value:
typeof(3) /* Returns an object which represents the type for numbers */
The following built-in types are available:
| Type | Examples | Description |
| Number | 3.7 | A numerical value. |
| Boolean | true, false | A boolean value. |
| String | “hello” | A string. |
| Array | [ “a”, “b” ] | An array. |
| Dictionary | { a = 3 } | A dictionary. |
Depending on which libraries are loaded additional types may become available. The icinga
library implements a whole bunch of other object types,
e.g. Host, Service, CheckCommand, etc.
Each type has an associated type object which describes the type’s semantics. These type objects are made available using global variables which match the type’s name:
/* This logs 'true' */
log(typeof(3) == Number)
The type object’s prototype property can be used to find out which methods a certain type
supports:
/* This returns: ["contains","find","len","lower","replace","reverse","split","substr","to_string","trim","upper"] */
keys(String.prototype)
Additional documentation on type methods is available in the library reference.
Location Information ¶
The location of the currently executing script can be obtained using the
current_filename and current_line keywords.
Example:
log("Hello from '" + current_filename + "' in line " + current_line)
Reserved Keywords ¶
These keywords are reserved and must not be used as constants or custom variables.
object
template
include
include_recursive
include_zones
library
null
true
false
const
var
this
globals
locals
use
default
ignore_on_error
current_filename
current_line
apply
to
where
import
assign
ignore
function
return
break
continue
for
if
else
while
throw
try
except
in
using
namespace
@ character. The following example
tries to set vars.include which references a reserved keyword and generates
an error:
[2014-09-15 17:24:00 +0200] critical/config: Location:
/etc/icinga2/conf.d/hosts/localhost.conf(13): vars.sla = "24x7"
/etc/icinga2/conf.d/hosts/localhost.conf(14):
/etc/icinga2/conf.d/hosts/localhost.conf(15): vars.include = "some cmdb export field"
/etc/icinga2/conf.d/hosts/localhost.conf(16): }
/etc/icinga2/conf.d/hosts/localhost.conf(17):
Config error: in /etc/icinga2/conf.d/hosts/localhost.conf: 15:8-15:14: syntax error, unexpected include (T_INCLUDE), expecting T_IDENTIFIER
[2014-09-15 17:24:00 +0200] critical/config: 1 errors, 0 warnings.
You can escape the include keyword by prefixing it with an additional @ character:
import "generic-host"
address6 = "::1"
vars.os = "Linux"
vars.sla = "24x7"
vars.@include = "some cmdb export field"
