Appendix ¶
External Commands List ¶
Additional details can be found in the Icinga 1.x Documentation
| Command name | Parameters | Description |
| PROCESS_HOST_CHECK_RESULT | ;<host_name>;<status_code>;<plugin_output> (3) | - |
| PROCESS_SERVICE_CHECK_RESULT | ;<host_name>;<service_name>;<return_code>;<plugin_output> (4) | - |
| SCHEDULE_HOST_CHECK | ;<host_name>;<check_time> (2) | - |
| SCHEDULE_FORCED_HOST_CHECK | ;<host_name>;<check_time> (2) | - |
| SCHEDULE_SVC_CHECK | ;<host_name>;<service_name>;<check_time> (3) | - |
| SCHEDULE_FORCED_SVC_CHECK | ;<host_name>;<service_name>;<check_time> (3) | - |
| ENABLE_HOST_CHECK | ;<host_name> (1) | - |
| DISABLE_HOST_CHECK | ;<host_name> (1) | - |
| ENABLE_SVC_CHECK | ;<host_name>;<service_name> (2) | - |
| DISABLE_SVC_CHECK | ;<host_name>;<service_name> (2) | - |
| SHUTDOWN_PROCESS | - | - |
| RESTART_PROCESS | - | - |
| SCHEDULE_FORCED_HOST_SVC_CHECKS | ;<host_name>;<check_time> (2) | - |
| SCHEDULE_HOST_SVC_CHECKS | ;<host_name>;<check_time> (2) | - |
| ENABLE_HOST_SVC_CHECKS | ;<host_name> (1) | - |
| DISABLE_HOST_SVC_CHECKS | ;<host_name> (1) | - |
| ACKNOWLEDGE_SVC_PROBLEM | ;<host_name>;<service_name>;<sticky>;<notify>;<persistent>;<author>;<comment> (7) | Note: Icinga 2 treats all comments as persistent. |
| ACKNOWLEDGE_SVC_PROBLEM_EXPIRE | ;<host_name>;<service_name>;<sticky>;<notify>;<persistent>;<timestamp>;<author>;<comment> (8) | Note: Icinga 2 treats all comments as persistent. |
| REMOVE_SVC_ACKNOWLEDGEMENT | ;<host_name>;<service_name> (2) | - |
| ACKNOWLEDGE_HOST_PROBLEM | ;<host_name>;<sticky>;<notify>;<persistent>;<author>;<comment> (6) | Note: Icinga 2 treats all comments as persistent. |
| ACKNOWLEDGE_HOST_PROBLEM_EXPIRE | ;<host_name>;<sticky>;<notify>;<persistent>;<timestamp>;<author>;<comment> (7) | Note: Icinga 2 treats all comments as persistent. |
| REMOVE_HOST_ACKNOWLEDGEMENT | ;<host_name> (1) | - |
| DISABLE_HOST_FLAP_DETECTION | ;<host_name> (1) | - |
| ENABLE_HOST_FLAP_DETECTION | ;<host_name> (1) | - |
| DISABLE_SVC_FLAP_DETECTION | ;<host_name>;<service_name> (2) | - |
| ENABLE_SVC_FLAP_DETECTION | ;<host_name>;<service_name> (2) | - |
| ENABLE_HOSTGROUP_SVC_CHECKS | ;<hostgroup_name> (1) | - |
| DISABLE_HOSTGROUP_SVC_CHECKS | ;<hostgroup_name> (1) | - |
| ENABLE_SERVICEGROUP_SVC_CHECKS | ;<servicegroup_name> (1) | - |
| DISABLE_SERVICEGROUP_SVC_CHECKS | ;<servicegroup_name> (1) | - |
| ENABLE_PASSIVE_HOST_CHECKS | ;<host_name> (1) | - |
| DISABLE_PASSIVE_HOST_CHECKS | ;<host_name> (1) | - |
| ENABLE_PASSIVE_SVC_CHECKS | ;<host_name>;<service_name> (2) | - |
| DISABLE_PASSIVE_SVC_CHECKS | ;<host_name>;<service_name> (2) | - |
| ENABLE_SERVICEGROUP_PASSIVE_SVC_CHECKS | ;<servicegroup_name> (1) | - |
| DISABLE_SERVICEGROUP_PASSIVE_SVC_CHECKS | ;<servicegroup_name> (1) | - |
| ENABLE_HOSTGROUP_PASSIVE_SVC_CHECKS | ;<hostgroup_name> (1) | - |
| DISABLE_HOSTGROUP_PASSIVE_SVC_CHECKS | ;<hostgroup_name> (1) | - |
| PROCESS_FILE | ;<file_name>;<delete> (2) | - |
| SCHEDULE_SVC_DOWNTIME | ;<host_name>;<service_name>;<start_time>;<end_time>;<fixed>;<trigger_id>;<duration>;<author>;<comment> (9) | - |
| DEL_SVC_DOWNTIME | ;<downtime_id> (1) | - |
| SCHEDULE_AND_PROPAGATE_HOST_DOWNTIME | ;<host_name>;<start_time>;<end_time>;<fixed>;<trigger_id>;<duration>;<author>;<comment> (8) | - |
| SCHEDULE_AND_PROPAGATE_TRIGGERED_HOST_DOWNTIME | ;<host_name>;<start_time>;<end_time>;<fixed>;<trigger_id>;<duration>;<author>;<comment> (8) | - |
| SCHEDULE_HOST_DOWNTIME | ;<host_name>;<start_time>;<end_time>;<fixed>;<trigger_id>;<duration>;<author>;<comment> (8) | - |
| DEL_HOST_DOWNTIME | ;<downtime_id> (1) | - |
| DEL_DOWNTIME_BY_HOST_NAME | ;<host_name>[;<service_name;>[;<start_time;>[;<comment_text;>]]] (1) | - |
| SCHEDULE_HOST_SVC_DOWNTIME | ;<host_name>;<start_time>;<end_time>;<fixed>;<trigger_id>;<duration>;<author>;<comment> (8) | - |
| SCHEDULE_HOSTGROUP_HOST_DOWNTIME | ;<hostgroup_name>;<start_time>;<end_time>;<fixed>;<trigger_id>;<duration>;<author>;<comment> (8) | - |
| SCHEDULE_HOSTGROUP_SVC_DOWNTIME | ;<hostgroup_name>;<start_time>;<end_time>;<fixed>;<trigger_id>;<duration>;<author>;<comment> (8) | - |
| SCHEDULE_SERVICEGROUP_HOST_DOWNTIME | ;<servicegroup_name>;<start_time>;<end_time>;<fixed>;<trigger_id>;<duration>;<author>;<comment> (8) | - |
| SCHEDULE_SERVICEGROUP_SVC_DOWNTIME | ;<servicegroup_name>;<start_time>;<end_time>;<fixed>;<trigger_id>;<duration>;<author>;<comment> (8) | - |
| ADD_HOST_COMMENT | ;<host_name>;<persistent>;<author>;<comment> (4) | Note: Icinga 2 treats all comments as persistent. |
| DEL_HOST_COMMENT | ;<comment_id> (1) | - |
| ADD_SVC_COMMENT | ;<host_name>;<service_name>;<persistent>;<author>;<comment> (5) | Note: Icinga 2 treats all comments as persistent. |
| DEL_SVC_COMMENT | ;<comment_id> (1) | - |
| DEL_ALL_HOST_COMMENTS | ;<host_name> (1) | - |
| DEL_ALL_SVC_COMMENTS | ;<host_name>;<service_name> (2) | - |
| SEND_CUSTOM_HOST_NOTIFICATION | ;<host_name>;<options>;<author>;<comment> (4) | - |
| SEND_CUSTOM_SVC_NOTIFICATION | ;<host_name>;<service_name>;<options>;<author>;<comment> (5) | - |
| DELAY_HOST_NOTIFICATION | ;<host_name>;<notification_time> (2) | - |
| DELAY_SVC_NOTIFICATION | ;<host_name>;<service_name>;<notification_time> (3) | - |
| ENABLE_HOST_NOTIFICATIONS | ;<host_name> (1) | - |
| DISABLE_HOST_NOTIFICATIONS | ;<host_name> (1) | - |
| ENABLE_SVC_NOTIFICATIONS | ;<host_name>;<service_name> (2) | - |
| DISABLE_SVC_NOTIFICATIONS | ;<host_name>;<service_name> (2) | - |
| ENABLE_HOST_SVC_NOTIFICATIONS | ;<host_name> (1) | - |
| DISABLE_HOST_SVC_NOTIFICATIONS | ;<host_name> (1) | - |
| DISABLE_HOSTGROUP_HOST_CHECKS | ;<hostgroup_name> (1) | - |
| DISABLE_HOSTGROUP_PASSIVE_HOST_CHECKS | ;<hostgroup_name> (1) | - |
| DISABLE_SERVICEGROUP_HOST_CHECKS | ;<servicegroup_name> (1) | - |
| DISABLE_SERVICEGROUP_PASSIVE_HOST_CHECKS | ;<servicegroup_name> (1) | - |
| ENABLE_HOSTGROUP_HOST_CHECKS | ;<hostgroup_name> (1) | - |
| ENABLE_HOSTGROUP_PASSIVE_HOST_CHECKS | ;<hostgroup_name> (1) | - |
| ENABLE_SERVICEGROUP_HOST_CHECKS | ;<servicegroup_name> (1) | - |
| ENABLE_SERVICEGROUP_PASSIVE_HOST_CHECKS | ;<servicegroup_name> (1) | - |
| ENABLE_NOTIFICATIONS | - | - |
| DISABLE_NOTIFICATIONS | - | - |
| ENABLE_FLAP_DETECTION | - | - |
| DISABLE_FLAP_DETECTION | - | - |
| ENABLE_EVENT_HANDLERS | - | - |
| DISABLE_EVENT_HANDLERS | - | - |
| ENABLE_PERFORMANCE_DATA | - | - |
| DISABLE_PERFORMANCE_DATA | - | - |
| START_EXECUTING_HOST_CHECKS | - | - |
| STOP_EXECUTING_HOST_CHECKS | - | - |
| START_EXECUTING_SVC_CHECKS | - | - |
| STOP_EXECUTING_SVC_CHECKS | - | - |
| CHANGE_NORMAL_SVC_CHECK_INTERVAL | ;<host_name>;<service_name>;<check_interval> (3) | - |
| CHANGE_NORMAL_HOST_CHECK_INTERVAL | ;<host_name>;<check_interval> (2) | - |
| CHANGE_RETRY_SVC_CHECK_INTERVAL | ;<host_name>;<service_name>;<check_interval> (3) | - |
| CHANGE_RETRY_HOST_CHECK_INTERVAL | ;<host_name>;<check_interval> (2) | - |
| ENABLE_HOST_EVENT_HANDLER | ;<host_name> (1) | - |
| DISABLE_HOST_EVENT_HANDLER | ;<host_name> (1) | - |
| ENABLE_SVC_EVENT_HANDLER | ;<host_name>;<service_name> (2) | - |
| DISABLE_SVC_EVENT_HANDLER | ;<host_name>;<service_name> (2) | - |
| CHANGE_HOST_EVENT_HANDLER | ;<host_name>;<event_command_name> (2) | - |
| CHANGE_SVC_EVENT_HANDLER | ;<host_name>;<service_name>;<event_command_name> (3) | - |
| CHANGE_HOST_CHECK_COMMAND | ;<host_name>;<check_command_name> (2) | - |
| CHANGE_SVC_CHECK_COMMAND | ;<host_name>;<service_name>;<check_command_name> (3) | - |
| CHANGE_MAX_HOST_CHECK_ATTEMPTS | ;<host_name>;<check_attempts> (2) | - |
| CHANGE_MAX_SVC_CHECK_ATTEMPTS | ;<host_name>;<service_name>;<check_attempts> (3) | - |
| CHANGE_HOST_CHECK_TIMEPERIOD | ;<host_name>;<timeperiod_name> (2) | - |
| CHANGE_SVC_CHECK_TIMEPERIOD | ;<host_name>;<service_name>;<timeperiod_name> | - |
| CHANGE_CUSTOM_HOST_VAR | ;<host_name>;<var_name>;<var_value> (3) | - |
| CHANGE_CUSTOM_SVC_VAR | ;<host_name>;<service_name>;<var_name>;<var_value> (4) | - |
| CHANGE_CUSTOM_USER_VAR | ;<user_name>;<var_name>;<var_value> (3) | - |
| CHANGE_CUSTOM_CHECKCOMMAND_VAR | ;<check_command_name>;<var_name>;<var_value> (3) | - |
| CHANGE_CUSTOM_EVENTCOMMAND_VAR | ;<event_command_name>;<var_name>;<var_value> (3) | - |
| CHANGE_CUSTOM_NOTIFICATIONCOMMAND_VAR | ;<notification_command_name>;<var_name>;<var_value> (3) | - |
| ENABLE_HOSTGROUP_HOST_NOTIFICATIONS | ;<hostgroup_name> (1) | - |
| ENABLE_HOSTGROUP_SVC_NOTIFICATIONS | ;<hostgroup_name> (1) | - |
| DISABLE_HOSTGROUP_HOST_NOTIFICATIONS | ;<hostgroup_name> (1) | - |
| DISABLE_HOSTGROUP_SVC_NOTIFICATIONS | ;<hostgroup_name> (1) | - |
| ENABLE_SERVICEGROUP_HOST_NOTIFICATIONS | ;<servicegroup_name> (1) | - |
| DISABLE_SERVICEGROUP_HOST_NOTIFICATIONS | ;<servicegroup_name> (1) | - |
| ENABLE_SERVICEGROUP_SVC_NOTIFICATIONS | ;<servicegroup_name> (1) | - |
| DISABLE_SERVICEGROUP_SVC_NOTIFICATIONS | ;<servicegroup_name> (1) | - |
Schemas ¶
By convention CheckCommand, EventCommand, and NotificationCommand objects
are exported using a prefix. This is mandatory for unique objects in the
command tables.
| Object | Prefix |
| CheckCommand | check_ |
| EventCommand | event_ |
| NotificationCommand | notification_ |
DB IDO Schema ¶
There is a detailed documentation for the Icinga IDOUtils 1.x database schema available on [https://docs.icinga.com/latest/en/db_model.html]
DB IDO Schema Extensions ¶
Icinga 2 specific extensions are shown below:
New table: endpointstatus
| Table | Column | Type | Default | Description |
| endpoints | endpoint_object_id | bigint | NULL | FK: objects table |
| endpoints | identity | TEXT | NULL | endpoint name |
| endpoints | node | TEXT | NULL | local node name |
| endpoints | zone_object_id | bigint | NULL | zone object where this endpoint is a member of |
| endpointstatus | endpoint_object_id | bigint | NULL | FK: objects table |
| endpointstatus | identity | TEXT | NULL | endpoint name |
| endpointstatus | node | TEXT | NULL | local node name |
| endpointstatus | is_connected | smallint | 0 | update on endpoint connect/disconnect |
| endpointstatus | zone_object_id | bigint | NULL | zone object where this endpoint is a member of |
New tables: zones and zonestatus:
| zones | zone_object_id | bigint | NULL | FK: objects table |
| zones | parent_zone_object_id | bigint | NULL | FK: zones table |
| zones | is_global | smallint | 0 | zone is global |
New columns:
| all status/history | endpoint_object_id | bigint | NULL | FK: objects table |
| servicestatus | check_source | TEXT | NULL | node name where check was executed |
| hoststatus | check_source | TEXT | NULL | node name where check was executed |
| statehistory | check_source | TEXT | NULL | node name where check was executed |
| servicestatus | is_reachable | integer | NULL | object reachability |
| hoststatus | is_reachable | integer | NULL | object reachability |
| logentries | object_id | bigint | NULL | FK: objects table (service associated with column) |
| {host,service}group | notes | TEXT | NULL | - |
| {host,service}group | notes_url | TEXT | NULL | - |
| {host,service}group | action_url | TEXT | NULL | - |
| customvariable* | is_json | integer | 0 | Defines whether varvalue is a json encoded string from custom attributes, or not |
| servicestatus | original_attributes | TEXT | NULL | JSON encoded dictionary of original attributes if modified at runtime. |
| hoststatus | original_attributes | TEXT | NULL | JSON encoded dictionary of original attributes if modified at runtime. |
Additional command custom variables populated from ‘vars’ dictionary. Additional global custom variables populated from ‘Vars’ constant (object_id is NULL).
Livestatus Schema ¶
Livestatus Schema Extensions ¶
New table: endpoints:
| Table | Column |
| endpoints | name |
| endpoints | node |
| endpoints | is_connected |
| endpoints | zone |
New table: zones:
| Table | Column |
| zone | name |
| zone | endpoints |
| zone | parent |
| zone | global |
New columns:
| Table | Column |
| hosts | is_reachable |
| services | is_reachable |
| hosts | cv_is_json |
| services | cv_is_json |
| contacts | cv_is_json |
| hosts | check_source |
| services | check_source |
| downtimes | triggers |
| downtimes | trigger_time |
| commands | custom_variable_names |
| commands | custom_variable_values |
| commands | custom_variables |
| commands | modified_attributes |
| commands | modified_attributes_list |
| status | custom_variable_names |
| status | custom_variable_values |
| status | custom_variables |
| hosts | original_attributes |
| services | original_attributes |
Command custom variables reflect the local ‘vars’ dictionary. Status custom variables reflect the global ‘Vars’ constant.
Livestatus Hosts Table Attributes ¶
| Key | Type | Note |
| name | string | . |
| display_name | string | . |
| alias | string | same as display_name. |
| address | string | . |
| address6 | string | NEW in Icinga. |
| check_command | string | . |
| check_command_expanded | string | . |
| event_handler | string | . |
| notification_period | string | host with notifications: period. |
| check_period | string | . |
| notes | string | . |
| notes_expanded | string | . |
| notes_url | string | . |
| notes_url_expanded | string | . |
| action_url | string | . |
| action_url_expanded | string | . |
| plugin_output | string | . |
| perf_data | string | . |
| icon_image | string | . |
| icon_image_expanded | string | . |
| icon_image_alt | stirng | . |
| statusmap_image | string | . |
| long_plugin_output | string | . |
| max_check_attempts | int | . |
| flap_detection_enabled | int | . |
| check_freshness | int | . |
| process_performance_data | int | . |
| accept_passive_checks | int | . |
| event_handler_enabled | int | . |
| acknowledgement_type | int | Only 0 or 1. |
| check_type | int | . |
| last_state | int | . |
| last_hard_state | int | . |
| current_attempt | int | . |
| last_notification | int | host with notifications: last notification. |
| next_notification | int | host with notifications: next notification. |
| next_check | int | . |
| last_hard_state_change | int | . |
| has_been_checked | int | . |
| current_notification_number | int | host with notifications: number. |
| total_services | int | . |
| checks_enabled | int | . |
| notifications_enabled | int | . |
| acknowledged | int | . |
| state | int | . |
| state_type | int | . |
| no_more_notifications | int | notification_interval == 0 && volatile == false. |
| last_check | int | . |
| last_state_change | int | . |
| last_time_up | int | . |
| last_time_down | int | . |
| last_time_unreachable | int | . |
| is_flapping | int | . |
| scheduled_downtime_depth | int | . |
| active_checks_enabled | int | . |
| modified_attributes | array | . |
| modified_attributes_list | array | . |
| check_interval | double | . |
| retry_interval | double | . |
| notification_interval | double | host with notifications: smallest interval. |
| low_flap_threshold | double | flapping_threshold |
| high_flap_threshold | double | flapping_threshold |
| latency | double | . |
| execution_time | double | . |
| percent_state_change | double | flapping. |
| in_notification_period | int | host with notifications: matching period. |
| in_check_period | int | . |
| contacts | array | host with notifications, users and user groups. |
| downtimes | array | id. |
| downtimes_with_info | array | id+author+comment. |
| comments | array | id. |
| comments_with_info | array | id+author+comment. |
| comments_with_extra_info | array | id+author+comment+entry_type+entry_time. |
| custom_variable_names | array | . |
| custom_variable_values | array | . |
| custom_variables | array | Array of custom variable array pair. |
| parents | array | Direct host parents. |
| childs | array | Direct host children (Note: childs is inherited from the origin MK_Livestatus protocol). |
| num_services | int | . |
| worst_service_state | int | All services and their worst state. |
| num_services_ok | int | All services with Ok state. |
| num_services_warn | int | All services with Warning state. |
| num_services_crit | int | All services with Critical state. |
| num_services_unknown | int | All services with Unknown state. |
| worst_service_hard_state | int | All services and their worst hard state. |
| num_services_hard_ok | int | All services in a hard state with Ok state. |
| num_services_hard_warn | int | All services in a hard state with Warning state. |
| num_services_hard_crit | int | All services in a hard state with Critical state. |
| num_services_hard_unknown | int | All services in a hard state with Unknown state. |
| hard_state | int | Returns OK if state is OK. Returns current state if now a hard state type. Returns last hard state otherwise. |
| staleness | int | Indicates time since last check normalized onto the check_interval. |
| groups | array | All hostgroups this host is a member of. |
| contact_groups | array | All usergroups associated with this host through notifications. |
| services | array | All services associated with this host. |
| services_with_state | array | All services associated with this host with state and hasbeenchecked. |
| services_with_info | array | All services associated with this host with state, hasbeenchecked and output. |
Not supported: initial_state, pending_flex_downtime, check_flapping_recovery_notification,
is_executing, check_options, obsess_over_host, first_notification_delay, x_3d, y_3d, z_3d,
x_2d, y_2d, filename, pnpgraph_present.
Livestatus Hostgroups Table Attributes ¶
| Key | Type | Note |
| name | string | . |
| alias | string | display_name attribute. |
| members | array | . |
| members_with_state | array | Host name and state. |
| worst_host_state | int | Of all group members. |
| num_hosts | int | In this group. |
| num_hosts_pending | int | . |
| num_hosts_up | int | . |
| num_hosts_down | int | . |
| num_hosts_unreach | int | . |
| num_services | int | Number of services associated with hosts in this hostgroup. |
| worst_services_state | int | . |
| num_services_pending | int | . |
| num_services_ok | int | . |
| num_services_warn | int | . |
| num_services_crit | int | . |
| num_services_unknown | int | . |
| worst_service_hard_state | int | . |
| num_services_hard_ok | int | . |
| num_services_hard_warn | int | . |
| num_services_hard_crit | int | . |
| num_services_hard_unknown | int | . |
Livestatus Services Table Attributes ¶
| Key | Type | Note |
| description | string | . |
| last_notification | int | service with notifications: last notification. |
| next_notification | int | service with notifications: next notification. |
| current_notification_number | int | service with notifications: number. |
| state | int | . |
| last_time_ok | int | . |
| last_time_warning | int | . |
| last_time_critical | int | . |
| last_time_unknown | int | . |
| notification_interval | double | service with notifications: smallest interval. |
| in_notification_period | int | service with notifications: matching period. |
| contacts | array | service with notifications, users and user groups. |
| host_ | join | Prefix for attributes from implicit join with hosts table. |
Not supported: initial_state, is_executing, check_options, obsess_over_service, first_notification_delay,
pnpgraph_present.
Livestatus Servicegroups Table Attributes ¶
| Key | Type | Note |
| name | string | . |
| members | array | CSV format uses host|service syntax. |
| members_with_state | array | Host, service, hoststate, servicestate. |
| worst_service_state | int | . |
Livestatus Contacts Table Attributes ¶
| Key | Type | Note |
| name | string | . |
| string | . | |
| pager | string | . |
| host_notification_period | string | . |
| service_notification_period | string | . |
| host_notifications_enabled | int | . |
| service_notifications_enabled | int | . |
| in_host_notification_period | int | . |
| in_service_notification_period | int | . |
| custom_variables | array | Array of customvariable array pairs. |
Not supported: can_submit_commands.
Livestatus Contactgroups Table Attributes ¶
| Key | Type | Note |
| name | string | . |
Livestatus Commands Table Attributes ¶
| Key | Type | Note |
| name | string | 3 types of commands in Icinga 2. |
| line | string | . |
Livestatus Status Table Attributes ¶
| Key | Type | Note |
| connections | int | Since application start. |
| connections_rate | double | . |
| service_checks | int | Since application start. |
| service_checks_rate | double | . |
| host_checks | int | Since application start. |
| host_checks_rate | double | . |
| external_commands | int | Since application start. |
| external_commands_rate | double | . |
| nagios_pid | string | Application PID. |
| enable_notifications | int | . |
| execute_service_checks | int | . |
| accept_passive_service_checks | int | . |
| execute_host_checks | int | . |
| accept_passive_host_checks | int | . |
| enable_event_handlers | int | . |
| check_service_freshness | int | . |
| check_host_freshness | int | . |
| enable_flap_detection | int | . |
| check_external_commands | int | Always enabled. |
| program_start | int | In seconds. |
| last_command_check | int | Always. |
| interval_length | int | Compatibility mode: 60. |
| num_hosts | int | . |
| program_version | string | 2.0. |
| livestatus_active_connections | string | . |
Not supported: neb_callbacks, neb_callbacks_rate, requests, requests_rate, forks, forks_rate,
log_messages, log_messages_rate, livechecks, livechecks_rate, livecheck_overflows,
livecheck_overflows_rate, obsess_over_services, obsess_over_hosts, last_log_rotation,
external_command_buffer_slots, external_command_buffer_usage, external_command_buffer_max,
cached_log_messages, livestatus_queued_connections, livestatus_threads.
Livestatus Comments Table Attributes ¶
| Key | Type | Note |
| author | string | . |
| comment | string | . |
| id | int | legacy_id. |
| entry_time | string | Seconds. |
| type | int | 1=host, 2=service. |
| is_service | int | . |
| persistent | int | Always. |
| source | string | Always external (1). |
| entry_type | int | . |
| expires | int | . |
| expire_time | string | Seconds. |
| service_ | join | Prefix for attributes from implicit join with services table. |
Livestatus Downtimes Table Attributes ¶
| Key | Type | Note |
| type | int | 1=active, 0=pending. |
| start_time | string | Seconds. |
| end_time | string | Seconds. |
| fixed | int | 0=flexible, 1=fixed. |
| duration | int | . |
| triggered_by | int | legacy_id. |
| triggers | int | NEW in Icinga 2. |
| trigger_time | string | NEW in Icinga 2. |
Livestatus Timeperiod Table Attributes ¶
| Key | Type | Note |
| name | string | . |
| in | int | Current time is in timeperiod or not. |
Livestatus Log Table Attributes ¶
| Key | Type | Note |
| time | int | Time of log event (unix timestamp). |
| lineno | int | Line number in CompatLogger log file. |
| class | int | Log message class: 0=info, 1=state, 2=program, 3=notification, 4=passive, 5=command. |
| message | string | Complete message line. |
| type | string | Text before the colon :. |
| options | string | Text after the colon :. |
| comment | string | Comment if available. |
| plugin_output | string | Check output if available. |
| state | int | Host or service state. |
| state_type | int | State type if available. |
| attempt | int | Current check attempt. |
| service_description | string | . |
| host_name | string | . |
| contact_name | string | . |
| command_name | string | . |
| current_service_ | join | Prefix for attributes from implicit join with services table. |
| current_host_ | join | Prefix for attributes from implicit join with hosts table. |
| current_contact_ | join | Prefix for attributes from implicit join with contacts table. |
| current_command_ | join | Prefix for attributes from implicit join with commands table. |
Livestatus Statehist Table Attributes ¶
| Key | Type | Note |
| from | int | Start timestamp (unix timestamp). |
| until | int | End timestamp (unix timestamp). |
| duration | int | until-from. |
| duration_part | double | duration / query_part. |
| state | int | State: 0=ok, 1=warn, 2=crit, 3=unknown, -1=notmonitored. |
| host_down | int | Host associated with the service is down or not. |
| in_downtime | int | Host/service is in downtime. |
| in_host_downtime | int | Host associated with the service is in a downtime or not. |
| is_flapping | int | Host/service is flapping. |
| in_notification_period | int | Host/service notification periods match or not. |
| notification_period | string | Host/service notification period. |
| log_output | string | Log file output for this state. |
| duration_ok | int | until-from for OK state. |
| duration_part_ok | double | . |
| duration_warning | int | until-from for Warning state. |
| duration_part_warning | double | . |
| duration_critical | int | until-from for Critical state. |
| duration_part_critical | double | . |
| duration_unknown | int | until-from for Unknown state. |
| duration_part_unknown | double | . |
| duration_unmonitored | int | until-from for Not-Monitored state. |
| duration_part_unmonitored | double | . |
Not supported: debug_info.
Livestatus Hostsbygroup Table Attributes ¶
All hosts table attributes grouped with
the hostgroups table prefixed with hostgroup_.
Livestatus Servicesbygroup Table Attributes ¶
All services table attributes grouped with
the servicegroups table prefixed with servicegroup_.
Livestatus Servicesbyhostgroup Table Attributes ¶
