Icinga 2 CLI Commands ¶
Icinga 2 comes with a number of CLI commands which support bash autocompletion.
These CLI commands will allow you to use certain functionality provided by and around Icinga 2.
Each CLI command provides its own help and usage information, so please
make sure to always run them with the --help parameter.
Run icinga2 without any arguments to get a list of all available global
options.
# icinga2
icinga2 - The Icinga 2 network monitoring daemon (version: v2.8.0)
Usage:
icinga2 <command> [<arguments>]
Supported commands:
* api setup (setup for API)
* ca list (lists all certificate signing requests)
* ca sign (signs an outstanding certificate request)
* console (Icinga debug console)
* daemon (starts Icinga 2)
* feature disable (disables specified feature)
* feature enable (enables specified feature)
* feature list (lists all available features)
* node setup (set up node)
* node wizard (wizard for node setup)
* object list (lists all objects)
* pki new-ca (sets up a new CA)
* pki new-cert (creates a new CSR)
* pki request (requests a certificate)
* pki save-cert (saves another Icinga 2 instance's certificate)
* pki sign-csr (signs a CSR)
* pki ticket (generates a ticket)
* troubleshoot (collect information for troubleshooting)
* variable get (gets a variable)
* variable list (lists all variables)
Global options:
-h [ --help ] show this help message
-V [ --version ] show version information
--color use VT100 color codes even when stdout is not a
terminal
-D [ --define ] arg define a constant
-a [ --app ] arg application library name (default: icinga)
-l [ --library ] arg load a library
-I [ --include ] arg add include search directory
-x [ --log-level ] arg specify the log level for the console log.
The valid value is either debug, notice,
information (default), warning, or critical
-X [ --script-debugger ] whether to enable the script debugger
Report bugs at <https://github.com/Icinga/icinga2>
Icinga home page: <https://icinga.com/>
Icinga 2 CLI Bash Autocompletion ¶
Bash Auto-Completion (pressing <TAB>) is provided only for the corresponding context.
While --config suggests and auto-completes files and directories on disk,
feature enable only suggests disabled features.
RPM and Debian packages install the bash completion files into
/etc/bash_completion.d/icinga2.
You need to install the bash-completion package if not already installed.
RHEL/CentOS/Fedora:
# yum install bash-completion
SUSE:
# zypper install bash-completion
Debian/Ubuntu:
# apt-get install bash-completion
Ensure that the bash-completion.d directory is added to your shell
environment. You can manually source the icinga2 bash-completion file
into your current session and test it:
# source /etc/bash-completion.d/icinga2
Icinga 2 CLI Global Options ¶
Application Type¶
By default the icinga2 binary loads the icinga library. A different application type
can be specified with the --app command-line option.
Note: This is not needed by the average Icinga user, only developers.
Libraries¶
Instead of loading libraries using the library config directive
you can also use the --library command-line option.
Constants¶
Global constants can be set using the --define command-line option.
Config Include Path ¶
When including files you can specify that the include search path should be checked. You can do this by putting your configuration file name in angle brackets like this:
include <test.conf>
This causes Icinga 2 to search its include path for the configuration file
test.conf. By default the installation path for the Icinga Template Library
is the only search directory.
Using the --include command-line option additional search directories can be
added.
CLI command: Api ¶
Provides the helper functions api setup and api user. The first to enable the REST API, the second to create
ApiUser objects with hashed password strings.
More details in the Icinga 2 API chapter.
# icinga2 api --help
Usage:
Supported commands:
* api user (API user creation helper)
Global options:
terminal
CLI command: Ca ¶
List and manage incoming certificate signing requests. More details can be found in the signing methods chapter. This CLI command is available since v2.8.
# icinga2 ca --help
Usage:
Supported commands:
Global options:
terminal
CLI command: Console ¶
The CLI command console can be used to debug and evaluate Icinga 2 config expressions,
e.g. to test functions in your local sandbox.
$ icinga2 console
Icinga 2 (version: v2.8.0)
<1> => function test(name) {
<1> .. log("Hello " + name)
<1> .. }
null
<2> => test("World")
information/config: Hello World
null
<3> =>
Further usage examples can be found in the library reference chapter.
# icinga2 console --help
Usage:
icinga2 console [<arguments>]
Interprets Icinga script expressions.
Global options:
terminal
Command options:
-c [ --connect ] arg connect to an Icinga 2 instance
-e [ --eval ] arg evaluate expression and terminate
-r [ --file ] arg evaluate a file and terminate
--syntax-only only validate syntax (requires --eval or --file)
--sandbox enable sandbox mode
On operating systems without the libedit library installed there is no
support for line-editing or a command history. However you can
use the rlwrap program if you require those features:
$ rlwrap icinga2 console
The debug console can be used to connect to a running Icinga 2 instance using the REST API. API permissions are required for executing config expressions and auto-completion.
Note
The debug console does not currently support TLS certificate verification.
Runtime modifications are not validated and might cause the Icinga 2 daemon to crash or behave in an unexpected way. Use these runtime changes at your own risk and rather inspect and debug objects read-only.
You can specify the API URL using the --connect parameter.
Although the password can be specified there process arguments on UNIX platforms are
usually visible to other users (e.g. through ps). In order to securely specify the
user credentials the debug console supports two environment variables:
| Environment variable | Description |
| ICINGA2_API_USERNAME | The API username. |
| ICINGA2_API_PASSWORD | The API password. |
Here’s an example:
$ ICINGA2_API_PASSWORD=icinga icinga2 console --connect 'https://root@localhost:5665/'
<1> =>
Once connected you can inspect variables and execute other expressions by entering them at the prompt:
<1> => var h = get_host("icinga2-client1.localdomain")
null
<2> => h.last_check_result
active = true
check_source = "icinga2-client1.localdomain"
command = [ "/usr/local/sbin/check_ping", "-H", "127.0.0.1", "-c", "5000,100%", "-w", "3000,80%" ]
execution_end = 1446653527.174983
execution_start = 1446653523.152673
exit_status = 0.000000
output = "PING OK - Packet loss = 0%, RTA = 0.11 ms"
performance_data = [ "rta=0.114000ms;3000.000000;5000.000000;0.000000", "pl=0%;80;100;0" ]
schedule_end = 1446653527.175133
schedule_start = 1446653583.150000
state = 0.000000
type = "CheckResult"
vars_after = {
attempt = 1.000000
reachable = true
state = 0.000000
state_type = 1.000000
vars_before = {
attempt = 1.000000
reachable = true
state = 0.000000
<3> =>
You can use the --eval parameter to evaluate a single expression in batch mode.
Using the --file option you can specify a file which should be evaluated.
The output format for batch mode is JSON.
The --syntax-only option can be used in combination with --eval or --file
to check a script for syntax errors. In this mode the script is parsed to identify
syntax errors but not evaluated.
Here’s an example that retrieves the command that was used by Icinga to check the icinga2-client1.localdomain host:
$ ICINGA2_API_PASSWORD=icinga icinga2 console --connect 'https://root@localhost:5665/' --eval 'get_host("icinga2-client1.localdomain").last_check_result.command' | python -m json.tool
"-H",
"127.0.0.1",
"-c",
"5000,100%",
"-w",
"3000,80%"
CLI command: Daemon ¶
The CLI command daemon provides the functionality to start/stop Icinga 2.
Furthermore it allows to run the configuration validation.
# icinga2 daemon --help
Usage:
icinga2 daemon [<arguments>]
Starts Icinga 2.
Global options:
terminal
Command options:
-c [ --config ] arg parse a configuration file
-z [ --no-config ] start without a configuration file
-C [ --validate ] exit after validating the configuration
-e [ --errorlog ] arg log fatal errors to the specified log file (only
works in combination with --daemonize or
--close-stdio)
-d [ --daemonize ] detach from the controlling terminal
--close-stdio do not log to stdout (or stderr) after startup
Config Files ¶
You can specify one or more configuration files with the --config option.
Configuration files are processed in the order they’re specified on the command-line.
When no configuration file is specified and the --no-config is not used
Icinga 2 automatically falls back to using the configuration file
ConfigDir + "/icinga2.conf" (where ConfigDir is usually /etc/icinga2).
Validation ¶
The --validate option can be used to check if configuration files
contain errors. If any errors are found, the exit status is 1, otherwise 0
is returned. More details in the configuration validation chapter.
CLI command: Feature ¶
The feature enable and feature disable commands can be used to enable and disable features:
# icinga2 feature disable <tab>
--app --define --include --log-level --version checker graphite mainlog
--color --help --library --script-debugger api command ido-mysql notification
# icinga2 feature enable <tab>
--app --define --include --log-level --version debuglog ido-pgsql livestatus perfdata syslog
--color --help --library --script-debugger compatlog gelf influxdb opentsdb statusdata
The feature list command shows which features are currently enabled:
# icinga2 feature list
Disabled features: compatlog debuglog gelf ido-pgsql influxdb livestatus opentsdb perfdata statusdata syslog
Enabled features: api checker command graphite ido-mysql mainlog notification
CLI command: Node ¶
Provides the functionality to setup master and client nodes in a distributed monitoring scenario.
# icinga2 node --help
Usage:
Supported commands:
Global options:
terminal
CLI command: Object ¶
The object CLI command can be used to list all configuration objects and their
attributes. The command also shows where each of the attributes was modified and as such
provides debug information for further configuration problem analysis.
That way you can also identify which objects have been created from your apply rules.
Runtime modifications via the REST API
are not immediately updated. Furthermore there is a known issue with
group assign expressions which are not reflected in the host object output.
You need to restart Icinga 2 in order to update the icinga2.debug cache file.
More information can be found in the troubleshooting section.
# icinga2 object --help
icinga2 - The Icinga 2 network monitoring daemon (version: v2.7.1-196-g23e8a6253; debug)
Usage:
Supported commands:
Global options:
terminal
CLI command: Pki ¶
Provides the CLI commands to
- generate a new certificate authority (CA)
- generate a new CSR or self-signed certificate
- sign a CSR and return a certificate
- save a master certificate manually
- request a signed certificate from the master
- generate a new ticket for the client setup
This functionality is used by the node setup/wizard CLI commands. You will need them in the distributed monitoring chapter.
# icinga2 pki --help
Usage:
Supported commands:
Global options:
terminal
CLI command: Troubleshoot ¶
Collects basic information like version, paths, log files and crash reports for troubleshooting purposes and prints them to a file or the console. See troubleshooting.
Its output defaults to a file named troubleshooting-[TIMESTAMP].log so it won’t overwrite older troubleshooting files.
Keep in mind that this tool can not collect information from other icinga2 nodes, you will have to run it on each of one of you instances. This is only a tool to collect information to help others help you, it will not attempt to fix anything.
# icinga2 troubleshoot --help
Usage:
icinga2 troubleshoot [<arguments>]
Collect logs and other relevant information for troubleshooting purposes.
Global options:
terminal
Command options:
-c [ --console ] print to console instead of file
-o [ --output ] arg path to output file
--include-objects Print the whole objectfile (like `object list`)
--include-vars Print all Variables (like `variable list`)
CLI command: Variable ¶
Lists all configured variables (constants) in a similar fashion like object list.
# icinga2 variable --help
icinga2 - The Icinga 2 network monitoring daemon (version: v2.8.0; debug)
Usage:
Supported commands:
Global options:
terminal
Enabling/Disabling Features ¶
Icinga 2 provides configuration files for some commonly used features. These
are installed in the /etc/icinga2/features-available directory and can be
enabled and disabled using the icinga2 feature enable and icinga2 feature disable
CLI commands, respectively.
The icinga2 feature enable CLI command creates symlinks in the
/etc/icinga2/features-enabled directory which is included by default
in the example configuration file.
You can view a list of enabled and disabled features:
Disabled features: api command compatlog debuglog graphite icingastatus ido-mysql ido-pgsql livestatus notification perfdata statusdata syslog
Enabled features: checker mainlog notification
Using the icinga2 feature enable command you can enable features:
# icinga2 feature enable graphite
Enabling feature graphite. Make sure to restart Icinga 2 for these changes to take effect.
You can disable features using the icinga2 feature disable command:
# icinga2 feature disable ido-mysql livestatus
Disabling feature ido-mysql. Make sure to restart Icinga 2 for these changes to take effect.
Disabling feature livestatus. Make sure to restart Icinga 2 for these changes to take effect.
The icinga2 feature enable and icinga2 feature disable commands do not
restart Icinga 2. You will need to restart Icinga 2 using the init script
after enabling or disabling features.
Configuration Validation ¶
Once you’ve edited the configuration files make sure to tell Icinga 2 to validate the configuration changes. Icinga 2 will log any configuration error including a hint on the file, the line number and the affected configuration line itself.
The following example creates an apply rule without any assign condition.
apply Service "my-ping4" {
import "generic-service"
check_command = "ping4"
//assign where host.address
Validate the configuration:
# icinga2 daemon -C
[2014-05-22 17:07:25 +0200] critical/ConfigItem: Location:
/etc/icinga2/conf.d/tests/my.conf(5): }
/etc/icinga2/conf.d/tests/my.conf(6):
/etc/icinga2/conf.d/tests/my.conf(7): apply Service "my-ping4" {
/etc/icinga2/conf.d/tests/my.conf(8): import "test-generic-service"
/etc/icinga2/conf.d/tests/my.conf(9): check_command = "ping4"
Config error: 'apply' is missing 'assign'
[2014-05-22 17:07:25 +0200] critical/ConfigItem: 1 errors, 0 warnings.
Icinga 2 detected configuration errors.
If you encounter errors during configuration validation, please make sure to read the troubleshooting chapter.
You can also use the CLI command icinga2 object list
after validation passes to analyze object attributes, inheritance or created
objects by apply rules.
Find more on troubleshooting with object list in this chapter.
Reload on Configuration Changes ¶
Every time you have changed your configuration you should first tell Icinga 2 to validate. If there are no validation errors, you can safely reload the Icinga 2 daemon.
# systemctl reload icinga2
The reload action will send the SIGHUP signal to the Icinga 2 daemon
which will validate the configuration in a separate process and not stop
the other events like check execution, notifications, etc.
