Icinga Template Library ¶
The Icinga Template Library (ITL) implements standard templates and object definitions.
There is a subset of templates and object definitions available:
- Generic ITL templates
- CheckCommand definitions for Icinga 2 (this includes icinga, cluster, cluster-zone, ido, etc.)
- CheckCommand definitions for Monitoring Plugins
- CheckCommand definitions for Icinga 2 Windows Plugins
- CheckCommand definitions for NSClient++
- CheckCommand definitions for Manubulon SNMP
- Contributed CheckCommand definitions
The ITL content is updated with new releases. Please do not modify templates and/or objects as changes will be overridden without further notice.
You are advised to create your own CheckCommand definitions in
/etc/icinga2.
Generic Templates ¶
By default the generic templates are included in the icinga2.conf configuration file:
include <itl>
These templates are imported by the provided example configuration.
Note:
These templates are built into the binaries. By convention all command and timeperiod objects should import these templates.
plugin-check-command ¶
Command template for check plugins executed by Icinga 2.
The plugin-check-command command does not support any vars.
By default this template is automatically imported into all CheckCommand definitions.
plugin-notification-command ¶
Command template for notification scripts executed by Icinga 2.
The plugin-notification-command command does not support any vars.
By default this template is automatically imported into all NotificationCommand definitions.
plugin-event-command ¶
Command template for event handler scripts executed by Icinga 2.
The plugin-event-command command does not support any vars.
By default this template is automatically imported into all EventCommand definitions.
legacy-timeperiod ¶
Timeperiod template for Timeperiod objects.
The legacy-timeperiod timeperiod does not support any vars.
By default this template is automatically imported into all TimePeriod definitions.
Check Commands ¶
These check commands are embedded into Icinga 2 and do not require any external plugin scripts.
icinga ¶
Check command for the built-in icinga check. This check returns performance
data for the current Icinga instance and optionally allows for minimum version checks.
Custom attributes passed as command parameters:
| Name | Description |
| icinga_min_version | Optional. Required minimum Icinga 2 version, e.g. 2.8.0. If not satisfied, the state changes to Critical. Release packages only. |
cluster ¶
Check command for the built-in cluster check. This check returns performance
data for the current Icinga instance and connected endpoints.
The cluster check command does not support any vars.
cluster-zone ¶
Check command for the built-in cluster-zone check.
| cluster_zone | Required. The zone name. Defaults to $host.name$. |
| cluster_lag_warning | Optional. Warning threshold for log lag in seconds. Applies if the log lag is greater than the threshold. |
| cluster_lag_critical | Optional. Critical threshold for log lag in seconds. Applies if the log lag is greater than the threshold. |
ido ¶
Check command for the built-in ido check.
| ido_type | Required. The type of the IDO connection object. Can be either “IdoMysqlConnection” or “IdoPgsqlConnection”. |
| ido_name | Required. The name of the IDO connection object. |
| ido_queries_warning | Optional. Warning threshold for queries/s. Applies if the rate is lower than the threshold. |
| ido_queries_critical | Optional. Critical threshold for queries/s. Applies if the rate is lower than the threshold. |
| ido_pending_queries_warning | Optional. Warning threshold for pending queries. Applies if pending queries are higher than the threshold. Supersedes the ido_queries thresholds above. |
| ido_pending_queries_critical | Optional. Critical threshold for pending queries. Applies if pending queries are higher than the threshold. Supersedes the ido_queries thresholds above. |
dummy ¶
Check command for the built-in dummy check. This allows to set
a check result state and output and can be used in freshness checks
or runtime object checks.
In contrast to the check_dummy
plugin, Icinga 2 implements a light-weight in memory check with 2.9+.
| dummy_state | Optional. The state. Can be one of 0 (ok), 1 (warning), 2 (critical) and 3 (unknown). Defaults to 0. |
| dummy_text | Optional. Plugin output. Defaults to “Check was successful.”. |
passive ¶
Specialised check command object for passive checks which uses the functionality of the “dummy” check command with appropriate default values.
| dummy_state | Optional. The state. Can be one of 0 (ok), 1 (warning), 2 (critical) and 3 (unknown). Defaults to 3. |
| dummy_text | Optional. Plugin output. Defaults to “No Passive Check Result Received.”. |
random ¶
Check command for the built-in random check. This check returns random states
and adds the check source to the check output.
For test and demo purposes only. The random check command does not support
any vars.
exception ¶
Check command for the built-in exception check. This check throws an exception.
For test and demo purposes only. The exception check command does not support
any vars.
Plugin Check Commands for Monitoring Plugins ¶
The Plugin Check Commands provides example configuration for plugin check commands provided by the Monitoring Plugins project.
By default the Plugin Check Commands are included in the icinga2.conf configuration file:
include <plugins>
The plugin check commands assume that there’s a global constant named PluginDir
which contains the path of the plugins from the Monitoring Plugins project.
Note:
Please be aware that the CheckCommand definitions are based on the Monitoring Plugins, other Plugin collections might not support all parameters. If there are command parameters missing for the provided CheckCommand definitions please kindly send a patch upstream. This should include an update for the ITL CheckCommand itself and this documentation section.
apt ¶
The plugin apt checks for software updates on systems that use package management systems based on the apt-get(8) command found in Debian based systems.
| apt_extra_opts | Optional. Read options from an ini file. |
| apt_upgrade | Optional. [Default] Perform an upgrade. If an optional OPTS argument is provided, apt-get will be run with these command line options instead of the default. |
| apt_dist_upgrade | Optional. Perform a dist-upgrade instead of normal upgrade. Like with -U OPTS can be provided to override the default options. |
| apt_include | Optional. Include only packages matching REGEXP. Can be specified multiple times the values will be combined together. |
| apt_exclude | Optional. Exclude packages matching REGEXP from the list of packages that would otherwise be included. Can be specified multiple times. |
| apt_critical | Optional. If the full package information of any of the upgradable packages match this REGEXP, the plugin will return CRITICAL status. Can be specified multiple times. |
| apt_timeout | Optional. Seconds before plugin times out (default: 10). |
| apt_only_critical | Optional. Only warn about critical upgrades. |
breeze ¶
The check_breeze plugin reports the signal strength of a Breezecom wireless equipment.
| breeze_hostname | Required. Name or IP address of host to check. Defaults to “$address$” if the host’s address attribute is set, “$address6$” otherwise. |
| breeze_community | Optional. SNMPv1 community. Defaults to “public”. |
| breeze_warning | Required. Percentage strength below which a WARNING status will result. Defaults to 50. |
| breeze_critical | Required. Percentage strength below which a WARNING status will result. Defaults to 20. |
by_ssh ¶
The check_by_ssh plugin uses SSH to execute commands on a remote host.
| by_ssh_address | Optional. The host’s address. Defaults to “$address$” if the host’s address attribute is set, “$address6$” otherwise. |
| by_ssh_port | Optional. The SSH port. Defaults to 22. |
| by_ssh_command | Required. The command that should be executed. Can be an array if multiple arguments should be passed to check_by_ssh. |
| by_ssh_arguments | Optional. A dictionary with arguments for the command. This works exactly like the ‘arguments’ dictionary for ordinary CheckCommands. |
| by_ssh_logname | Optional. The SSH username. |
| by_ssh_identity | Optional. The SSH identity. |
| by_ssh_quiet | Optional. Whether to suppress SSH warnings. Defaults to false. |
| by_ssh_warn | Optional. The warning threshold. |
| by_ssh_crit | Optional. The critical threshold. |
| by_ssh_timeout | Optional. The timeout in seconds. |
| by_ssh_options | Optional. Call ssh with ‘-o OPTION’ (multiple options may be specified as an array). |
| by_ssh_ipv4 | Optional. Use IPv4 connection. Defaults to false. |
| by_ssh_ipv6 | Optional. Use IPv6 connection. Defaults to false. |
| by_ssh_skip_stderr | Optional. Ignore all or (if specified) first n lines on STDERR. |
clamd ¶
The check_clamd plugin tests CLAMD connections with the specified host (or unix socket).
| clamd_address | Required. The host’s address or unix socket (must be an absolute path). |
| clamd_port | Optional. Port number (default: none). |
| clamd_expect | Optional. String to expect in server response. Multiple strings must be defined as array. |
| clamd_all | Optional. All expect strings need to occur in server response. Defaults to false. |
| clamd_escape_send | Optional. Enable usage of \n, \r, \t or \\ in send string. |
| clamd_send | Optional. String to send to the server. |
| clamd_escape_quit | Optional. Enable usage of \n, \r, \t or \\ in quit string. |
| clamd_quit | Optional. String to send server to initiate a clean close of the connection. |
| clamd_refuse | Optional. Accept TCP refusals with states ok, warn, crit. Defaults to crit. |
| clamd_mismatch | Optional. Accept expected string mismatches with states ok, warn, crit. Defaults to warn. |
| clamd_jail | Optional. Hide output from TCP socket. |
| clamd_maxbytes | Optional. Close connection once more than this number of bytes are received. |
| clamd_delay | Optional. Seconds to wait between sending string and polling for response. |
| clamd_certificate | Optional. Minimum number of days a certificate has to be valid. 1st value is number of days for warning, 2nd is critical (if not specified: 0) – separated by comma. |
| clamd_ssl | Optional. Use SSL for the connection. Defaults to false. |
| clamd_wtime | Optional. Response time to result in warning status (seconds). |
| clamd_ctime | Optional. Response time to result in critical status (seconds). |
| clamd_timeout | Optional. Seconds before connection times out. Defaults to 10. |
| clamd_ipv4 | Optional. Use IPv4 connection. Defaults to false. |
| clamd_ipv6 | Optional. Use IPv6 connection. Defaults to false. |
dhcp ¶
The check_dhcp plugin tests the availability of DHCP servers on a network.
| dhcp_serverip | Optional. The IP address of the DHCP server which we should get a response from. |
| dhcp_requestedip | Optional. The IP address which we should be offered by a DHCP server. |
| dhcp_timeout | Optional. The timeout in seconds. |
| dhcp_interface | Optional. The interface to use. |
| dhcp_mac | Optional. The MAC address to use in the DHCP request. |
| dhcp_unicast | Optional. Whether to use unicast requests. Defaults to false. |
dig ¶
The check_dig plugin test the DNS service on the specified host using dig.
| dig_server | Optional. The DNS server to query. Defaults to “127.0.0.1”. |
| dig_port | Optional. Port number (default: 53). |
| dig_lookup | Required. The address that should be looked up. |
| dig_record_type | Optional. Record type to lookup (default: A). |
| dig_expected_address | Optional. An address expected to be in the answer section. If not set, uses whatever was in -l. |
| dig_arguments | Optional. Pass STRING as argument(s) to dig. |
| dig_retries | Optional. Number of retries passed to dig, timeout is divided by this value (Default: 3). |
| dig_warning | Optional. Response time to result in warning status (seconds). |
| dig_critical | Optional. Response time to result in critical status (seconds). |
| dig_timeout | Optional. Seconds before connection times out (default: 10). |
| dig_ipv4 | Optional. Force dig to only use IPv4 query transport. Defaults to false. |
| dig_ipv6 | Optional. Force dig to only use IPv6 query transport. Defaults to false. |
disk ¶
The check_disk plugin checks the amount of used disk space on a mounted file system and generates an alert if free space is less than one of the threshold values.
| disk_wfree | Optional. The free space warning threshold. Defaults to “20%”. If the percent sign is omitted, units from disk_units are used. |
| disk_cfree | Optional. The free space critical threshold. Defaults to “10%”. If the percent sign is omitted, units from disk_units are used. |
| disk_inode_wfree | Optional. The free inode warning threshold. |
| disk_inode_cfree | Optional. The free inode critical threshold. |
| disk_partition | Optional. The partition. Deprecated in 2.3. |
| disk_partition_excluded | Optional. The excluded partition. Deprecated in 2.3. |
| disk_partitions | Optional. The partition(s). Multiple partitions must be defined as array. |
| disk_partitions_excluded | Optional. The excluded partition(s). Multiple partitions must be defined as array. |
| disk_clear | Optional. Clear thresholds. May be true or false. |
| disk_exact_match | Optional. For paths or partitions specified with -p, only check for exact paths. May be true or false. |
| disk_errors_only | Optional. Display only devices/mountpoints with errors. May be true or false. |
| disk_ignore_reserved | Optional. If set, account root-reserved blocks are not accounted for freespace in perfdata. May be true or false. |
| disk_group | Optional. Group paths. Thresholds apply to (free-)space of all partitions together. |
| disk_kilobytes | Optional. Same as –units kB. May be true or false. |
| disk_local | Optional. Only check local filesystems. May be true or false. |
| disk_stat_remote_fs | Optional. Only check local filesystems against thresholds. Yet call stat on remote filesystems to test if they are accessible (e.g. to detect Stale NFS Handles). May be true or false. |
| disk_mountpoint | Optional. Display the mountpoint instead of the partition. May be true or false. |
| disk_megabytes | Optional. Same as –units MB. May be true or false. |
| disk_all | Optional. Explicitly select all paths. This is equivalent to -R ‘.*‘. May be true or false. |
| disk_eregi_path | Optional. Case insensitive regular expression for path/partition. Multiple regular expression strings must be defined as array. |
| disk_ereg_path | Optional. Regular expression for path or partition. Multiple regular expression strings must be defined as array. |
| disk_ignore_eregi_path | Optional. Regular expression to ignore selected path/partition (case insensitive). Multiple regular expression strings must be defined as array. |
| disk_ignore_ereg_path | Optional. Regular expression to ignore selected path or partition. Multiple regular expression strings must be defined as array. |
| disk_timeout | Optional. Seconds before connection times out (default: 10). |
| disk_units | Optional. Choose bytes, kB, MB, GB, TB (default: MB). |
| disk_exclude_type | Optional. Ignore all filesystems of indicated type. Multiple regular expression strings must be defined as array. Defaults to “none”, “tmpfs”, “sysfs”, “proc”, “configfs”, “devtmpfs”, “devfs”, “mtmfs”, “tracefs”, “cgroup”, “fuse.gvfsd-fuse”, “fuse.gvfs-fuse-daemon”, “fdescfs”, “overlay”, “nsfs”, “squashfs”. |
disk_smb ¶
The check_disk_smb plugin
uses the smbclient binary to check SMB shares.
| disk_smb_hostname | Required. NetBIOS name of the server. |
| disk_smb_share | Required. Share name being queried. |
| disk_smb_workgroup | Optional. Workgroup or Domain used (defaults to ‘WORKGROUP’ if omitted). |
| disk_smb_address | Optional. IP address of the host (only necessary if host belongs to another network). |
| disk_smb_username | Optional. Username for server log-in (defaults to ‘guest’ if omitted). |
| disk_smb_password | Optional. Password for server log-in (defaults to an empty password if omitted). |
| disk_smb_wused | Optional. The used space warning threshold. Defaults to “85%”. If the percent sign is omitted, use optional disk units. |
| disk_smb_cused | Optional. The used space critical threshold. Defaults to “95%”. If the percent sign is omitted, use optional disk units. |
| disk_smb_port | Optional. Connection port, e.g. 139 or 445. Defaults to smbclient default if omitted. |
dns ¶
The check_dns plugin
uses the nslookup program to obtain the IP address for the given host/domain query.
An optional DNS server to use may be specified. If no DNS server is specified, the
default server(s) specified in /etc/resolv.conf will be used.
| dns_lookup | Optional. The hostname or IP to query the DNS for. Defaults to “$host_name$”. |
| dns_server | Optional. The DNS server to query. Defaults to the server configured in the OS. |
| dns_query_type | Optional. The DNS record query type where TYPE =(A, AAAA, SRV, TXT, MX, ANY). The default query type is ‘A’ (IPv4 host entry) |
| dns_expected_answers | Optional. The answer(s) to look for. A hostname must end with a dot. Multiple answers must be defined as array. |
| dns_authoritative | Optional. Expect the server to send an authoritative answer. |
| dns_accept_cname | Optional. Accept cname responses as a valid result to a query. |
| dns_wtime | Optional. Return warning if elapsed time exceeds value. |
| dns_ctime | Optional. Return critical if elapsed time exceeds value. |
| dns_timeout | Optional. Seconds before connection times out. Defaults to 10. |
file_age ¶
The check_file_age plugin checks a file’s size and modification time to make sure it’s not empty and that it’s sufficiently recent.
| file_age_file | Required. File to monitor. |
| file_age_warning_time | Optional. File must be no more than this many seconds old as warning threshold. Defaults to “240s”. |
| file_age_critical_time | Optional. File must be no more than this many seconds old as critical threshold. Defaults to “600s”. |
| file_age_warning_size | Optional. File must be at least this many bytes long as warning threshold. No default given. |
| file_age_critical_size | Optional. File must be at least this many bytes long as critical threshold. Defaults to “0B”. |
| file_age_ignoremissing | Optional. Return OK if the file does not exist. Defaults to false. |
flexlm ¶
The check_flexlm plugin
checks available flexlm license managers. Requires the lmstat command.
| flexlm_licensefile | Required. Name of license file (usually license.dat). |
| flexlm_timeout | Optional. Plugin time out in seconds. Defaults to 15. |
fping4 ¶
The check_fping plugin
uses the fping command to ping the specified host for a fast check. Note that it is
necessary to set the suid flag on fping.
This CheckCommand expects an IPv4 address.
| fping_address | Optional. The host’s IPv4 address. Defaults to “$address$”. |
| fping_wrta | Optional. The RTA warning threshold in milliseconds. Defaults to 100. |
| fping_wpl | Optional. The packet loss warning threshold in %. Defaults to 5. |
| fping_crta | Optional. The RTA critical threshold in milliseconds. Defaults to 200. |
| fping_cpl | Optional. The packet loss critical threshold in %. Defaults to 15. |
| fping_number | Optional. The number of packets to send. Defaults to 5. |
| fping_interval | Optional. The interval between packets in milli-seconds. Defaults to 500. |
| fping_bytes | Optional. The size of ICMP packet. |
| fping_target_timeout | Optional. The target timeout in milli-seconds. |
| fping_source_ip | Optional. The name or ip address of the source ip. |
| fping_source_interface | Optional. The source interface name. |
fping6 ¶
will use the fping command to ping the specified host for a fast check. Note that it is
This CheckCommand expects an IPv6 address.
| fping_address | Optional. The host’s IPv6 address. Defaults to “$address6$”. |
ftp ¶
The check_ftp plugin tests FTP connections with the specified host (or unix socket).
| ftp_address | Optional. The host’s address. Defaults to “$address$” if the host’s address attribute is set, “$address6$” otherwise. |
| ftp_port | Optional. The FTP port number. |
| ftp_expect | Optional. String to expect in server response. Multiple strings must be defined as array. |
| ftp_all | Optional. All expect strings need to occur in server response. Defaults to false. |
| ftp_escape_send | Optional. Enable usage of \n, \r, \t or \\ in send string. |
| ftp_send | Optional. String to send to the server. |
| ftp_escape_quit | Optional. Enable usage of \n, \r, \t or \\ in quit string. |
| ftp_quit | Optional. String to send server to initiate a clean close of the connection. |
| ftp_refuse | Optional. Accept TCP refusals with states ok, warn, crit. Defaults to crit. |
| ftp_mismatch | Optional. Accept expected string mismatches with states ok, warn, crit. Defaults to warn. |
| ftp_jail | Optional. Hide output from TCP socket. |
| ftp_maxbytes | Optional. Close connection once more than this number of bytes are received. |
| ftp_delay | Optional. Seconds to wait between sending string and polling for response. |
| ftp_certificate | Optional. Minimum number of days a certificate has to be valid. 1st value is number of days for warning, 2nd is critical (if not specified: 0) – separated by comma. |
| ftp_ssl | Optional. Use SSL for the connection. Defaults to false. |
| ftp_wtime | Optional. Response time to result in warning status (seconds). |
| ftp_ctime | Optional. Response time to result in critical status (seconds). |
| ftp_timeout | Optional. Seconds before connection times out. Defaults to 10. |
| ftp_ipv4 | Optional. Use IPv4 connection. Defaults to false. |
| ftp_ipv6 | Optional. Use IPv6 connection. Defaults to false. |
game ¶
The check_game plugin
tests game server connections with the specified host.
This plugin uses the ‘qstat’ command, the popular game server status query tool.
If you don’t have the package installed, you will need to download
or install the package quakestat before you can use this plugin.
| game_game | Required. Name of the game. |
| game_ipaddress | Required. Ipaddress of the game server to query. |
| game_timeout | Optional. Seconds before connection times out. Defaults to 10. |
| game_port | Optional. Port to connect to. |
| game_gamefield | Optional. Field number in raw qstat output that contains game name. |
| game_mapfield | Optional. Field number in raw qstat output that contains map name. |
| game_pingfield | Optional. Field number in raw qstat output that contains ping time. |
| game_gametime | Optional. Field number in raw qstat output that contains game time. |
| game_hostname | Optional. Name of the host running the game. |
hostalive ¶
Check command object for the check_ping
plugin with host check default values. This variant uses the host’s address attribute
if available and falls back to using the address6 attribute if the address attribute is not set.
| ping_address | Optional. The host’s address. Defaults to “$address$” if the host’s address attribute is set, “$address6$” otherwise. |
| ping_wrta | Optional. The RTA warning threshold in milliseconds. Defaults to 3000. |
| ping_wpl | Optional. The packet loss warning threshold in %. Defaults to 80. |
| ping_crta | Optional. The RTA critical threshold in milliseconds. Defaults to 5000. |
| ping_cpl | Optional. The packet loss critical threshold in %. Defaults to 100. |
| ping_packets | Optional. The number of packets to send. Defaults to 5. |
| ping_timeout | Optional. The plugin timeout in seconds. Defaults to 0 (no timeout). |
hostalive4 ¶
plugin with host check default values. This variant uses the host’s address attribute.
hostalive6 ¶
plugin with host check default values. This variant uses the host’s address6 attribute.
hpjd ¶
The check_hpjd plugin tests the state of an HP printer with a JetDirect card. Net-snmp must be installed on the computer running the plugin.
| hpjd_address | Optional. The host’s address. Defaults to “$address$” if the host’s address attribute is set, “$address6$” otherwise. |
| hpjd_port | Optional. The host’s SNMP port. Defaults to 161. |
| hpjd_community | Optional. The SNMP community. Defaults to “public”. |
http ¶
The check_http plugin tests the HTTP service on the specified host. It can test normal (http) and secure (https) servers, follow redirects, search for strings and regular expressions, check connection times, and report on certificate expiration times.
The plugin can either test the HTTP response of a server, or if http_certificate is set to a non-empty value, the TLS certificate age for a HTTPS host.
| http_address | Optional. The host’s address. Defaults to “$address$” if the host’s address attribute is set, “$address6$” otherwise. |
| http_vhost | Optional. The virtual host that should be sent in the “Host” header. |
| http_uri | Optional. The request URI for GET or POST. Defaults to /. |
| http_port | Optional. The TCP port. Defaults to 80 when not using SSL, 443 otherwise. |
| http_ssl | Optional. Whether to use SSL. Defaults to false. |
| http_ssl_force_tlsv1 | Optional. Whether to force TLSv1. |
| http_ssl_force_tlsv1_1 | Optional. Whether to force TLSv1.1. |
| http_ssl_force_tlsv1_2 | Optional. Whether to force TLSv1.2. |
| http_ssl_force_sslv2 | Optional. Whether to force SSLv2. |
| http_ssl_force_sslv3 | Optional. Whether to force SSLv3. |
| http_ssl_force_tlsv1_or_higher | Optional. Whether to force TLSv1 or higher. |
| http_ssl_force_tlsv1_1_or_higher | Optional. Whether to force TLSv1.1 or higher. |
| http_ssl_force_tlsv1_2_or_higher | Optional. Whether to force TLSv1.2 or higher. |
| http_ssl_force_sslv2_or_higher | Optional. Whether to force SSLv2 or higher. |
| http_ssl_force_sslv3_or_higher | Optional. Whether to force SSLv3 or higher. |
| http_sni | Optional. Whether to use SNI. Defaults to false. |
| http_auth_pair | Optional. Add ‘username:password’ authorization pair. |
| http_proxy_auth_pair | Optional. Add ‘username:password’ authorization pair for proxy. |
| http_ignore_body | Optional. Don’t download the body, just the headers. |
| http_linespan | Optional. Allow regex to span newline. |
| http_expect_body_regex | Optional. A regular expression which the body must match against. Incompatible with http_ignore_body. |
| http_expect_body_eregi | Optional. A case-insensitive expression which the body must match against. Incompatible with http_ignore_body. |
| http_invertregex | Optional. Changes behavior of http_expect_body_regex and http_expect_body_eregi to return CRITICAL if found, OK if not. |
| http_warn_time | Optional. The warning threshold. |
| http_critical_time | Optional. The critical threshold. |
| http_expect | Optional. Comma-delimited list of strings, at least one of them is expected in the first (status) line of the server response. Default: HTTP/1. |
| http_certificate | Optional. Minimum number of days a certificate has to be valid. Port defaults to 443. When this option is used the URL is not checked. The first parameter defines the warning threshold (in days), the second parameter the critical threshold (in days). (Example http_certificate = "30,20"). |
| http_clientcert | Optional. Name of file contains the client certificate (PEM format). |
| http_privatekey | Optional. Name of file contains the private key (PEM format). |
| http_headerstring | Optional. String to expect in the response headers. |
| http_string | Optional. String to expect in the content. |
| http_post | Optional. URL encoded http POST data. |
| http_method | Optional. Set http method (for example: HEAD, OPTIONS, TRACE, PUT, DELETE). |
| http_maxage | Optional. Warn if document is more than seconds old. |
| http_contenttype | Optional. Specify Content-Type header when POSTing. |
| http_useragent | Optional. String to be sent in http header as User Agent. |
| http_header | Optional. Any other tags to be sent in http header. |
| http_extendedperfdata | Optional. Print additional perfdata. Defaults to false. |
| http_onredirect | Optional. How to handle redirect pages. Possible values: “ok” (default), “warning”, “critical”, “follow”, “sticky” (like follow but stick to address), “stickyport” (like sticky but also to port) |
| http_pagesize | Optional. Minimum page size required:Maximum page size required. |
| http_timeout | Optional. Seconds before connection times out. |
| http_ipv4 | Optional. Use IPv4 connection. Defaults to false. |
| http_ipv6 | Optional. Use IPv6 connection. Defaults to false. |
| http_link | Optional. Wrap output in HTML link. Defaults to false. |
| http_verbose | Optional. Show details for command-line debugging. Defaults to false. |
icmp ¶
The check_icmp plugin
check_icmp allows for checking multiple hosts at once compared to check_ping.
The main difference is that check_ping executes the system’s ping(1) command and
parses its output while check_icmp talks ICMP itself. check_icmp must be installed with
setuid root.
| icmp_address | Optional. The host’s address. This can either be a single address or an array of addresses. Defaults to “$address$”. |
| icmp_wrta | Optional. The RTA warning threshold in milliseconds. Defaults to 100. |
| icmp_wpl | Optional. The packet loss warning threshold in %. Defaults to 5. |
| icmp_crta | Optional. The RTA critical threshold in milliseconds. Defaults to 200. |
| icmp_cpl | Optional. The packet loss critical threshold in %. Defaults to 15. |
| icmp_source | Optional. The source IP address to send packets from. |
| icmp_packets | Optional. The number of packets to send. Defaults to 5. |
| icmp_packet_interval | Optional The maximum packet interval. Defaults to 80 (milliseconds). |
| icmp_target_interval | Optional. The maximum target interval. |
| icmp_hosts_alive | Optional. The number of hosts which have to be alive for the check to succeed. |
| icmp_data_bytes | Optional. Payload size for each ICMP request. Defaults to 8. |
| icmp_timeout | Optional. The plugin timeout in seconds. Defaults to 10 (seconds). |
| icmp_ttl | Optional. The TTL on outgoing packets. |
imap ¶
The check_imap plugin tests IMAP connections with the specified host (or unix socket).
| imap_address | Optional. The host’s address. Defaults to “$address$” if the host’s address attribute is set, “$address6$” otherwise. |
| imap_port | Optional. The port that should be checked. Defaults to 143. |
| imap_escape | Optional. Can use \n, \r, \t or \ in send or quit string. Must come before send or quit option. Default: nothing added to send, \r\n added to end of quit. |
| imap_send | Optional. String to send to the server. |
| imap_expect | Optional. String to expect in server response. Multiple strings must be defined as array. |
| imap_all | Optional. All expect strings need to occur in server response. Default is any. |
| imap_quit | Optional. String to send server to initiate a clean close of the connection. |
| imap_refuse | Optional. Accept TCP refusals with states ok, warn, crit (default: crit). |
| imap_mismatch | Optional. Accept expected string mismatches with states ok, warn, crit (default: warn). |
| imap_jail | Optional. Hide output from TCP socket. |
| imap_maxbytes | Optional. Close connection once more than this number of bytes are received. |
| imap_delay | Optional. Seconds to wait between sending string and polling for response. |
| imap_certificate_age | Optional. Minimum number of days a certificate has to be valid. |
| imap_ssl | Optional. Use SSL for the connection. |
| imap_warning | Optional. Response time to result in warning status (seconds). |
| imap_critical | Optional. Response time to result in critical status (seconds). |
| imap_timeout | Optional. Seconds before connection times out (default: 10). |
| imap_ipv4 | Optional. Use IPv4 connection. Defaults to false. |
| imap_ipv6 | Optional. Use IPv6 connection. Defaults to false. |
ldap ¶
The check_ldap plugin can be used to check LDAP servers.
The plugin can also be used for monitoring ldaps connections instead of the deprecated check_ldaps.
This can be ensured by enabling ldap_starttls or ldap_ssl.
| ldap_address | Optional. Host name, IP Address, or unix socket (must be an absolute path). Defaults to “$address$” if the host’s address attribute is set, “$address6$” otherwise. |
| ldap_port | Optional. Port number. Defaults to 389. |
| ldap_attr | Optional. LDAP attribute to search for (default: “(objectclass=*)”) |
| ldap_base | Required. LDAP base (eg. ou=myunit,o=myorg,c=at). |
| ldap_bind | Optional. LDAP bind DN (if required). |
| ldap_pass | Optional. LDAP password (if required). |
| ldap_starttls | Optional. Use STARTSSL mechanism introduced in protocol version 3. |
| ldap_ssl | Optional. Use LDAPS (LDAP v2 SSL method). This also sets the default port to 636. |
| ldap_v2 | Optional. Use LDAP protocol version 2 (enabled by default). |
| ldap_v3 | Optional. Use LDAP protocol version 3 (disabled by default) |
| ldap_warning | Optional. Response time to result in warning status (seconds). |
| ldap_critical | Optional. Response time to result in critical status (seconds). |
| ldap_warning_entries | Optional. Number of found entries to result in warning status. |
| ldap_critical_entries | Optional. Number of found entries to result in critical status. |
| ldap_timeout | Optional. Seconds before connection times out (default: 10). |
| ldap_verbose | Optional. Show details for command-line debugging (disabled by default) |
load ¶
The check_load plugin tests the current system load average.
| load_wload1 | Optional. The 1-minute warning threshold. Defaults to 5. |
| load_wload5 | Optional. The 5-minute warning threshold. Defaults to 4. |
| load_wload15 | Optional. The 15-minute warning threshold. Defaults to 3. |
| load_cload1 | Optional. The 1-minute critical threshold. Defaults to 10. |
| load_cload5 | Optional. The 5-minute critical threshold. Defaults to 6. |
| load_cload15 | Optional. The 15-minute critical threshold. Defaults to 4. |
| load_percpu | Optional. Divide the load averages by the number of CPUs (when possible). Defaults to false. |
mailq ¶
The check_mailq plugin checks the number of messages in the mail queue (supports multiple sendmail queues, qmail).
| mailq_warning | Required. Min. number of messages in queue to generate warning. |
| mailq_critical | Required. Min. number of messages in queue to generate critical alert ( w < c ). |
| mailq_domain_warning | Optional. Min. number of messages for same domain in queue to generate warning |
| mailq_domain_critical | Optional. Min. number of messages for same domain in queue to generate critical alert ( W < C ). |
| mailq_timeout | Optional. Plugin timeout in seconds (default = 15). |
| mailq_servertype | Optional. [ sendmail | qmail | postfix | exim | nullmailer ] (default = autodetect). |
| mailq_sudo | Optional. Use sudo to execute the mailq command. |
mysql ¶
The check_mysql plugin tests connections to a MySQL server.
| mysql_hostname | Optional. Host name, IP Address, or unix socket (must be an absolute path). |
| mysql_port | Optional. Port number (default: 3306). |
| mysql_socket | Optional. Use the specified socket (has no effect if mysql_hostname is used). |
| mysql_ignore_auth | Optional. Ignore authentication failure and check for mysql connectivity only. |
| mysql_database | Optional. Check database with indicated name. |
| mysql_file | Optional. Read from the specified client options file. |
| mysql_group | Optional. Use a client options group. |
| mysql_username | Optional. Connect using the indicated username. |
| mysql_password | Optional. Use the indicated password to authenticate the connection. |
| mysql_check_slave | Optional. Check if the slave thread is running properly. |
| mysql_warning | Optional. Exit with WARNING status if slave server is more than INTEGER seconds behind master. |
| mysql_critical | Optional. Exit with CRITICAL status if slave server is more then INTEGER seconds behind master. |
| mysql_ssl | Optional. Use ssl encryption. |
| mysql_cacert | Optional. Path to CA signing the cert. |
| mysql_cert | Optional. Path to SSL certificate. |
| mysql_key | Optional. Path to private SSL key. |
| mysql_cadir | Optional. Path to CA directory. |
| mysql_ciphers | Optional. List of valid SSL ciphers. |
mysql_query ¶
The check_mysql_query plugin checks a query result against threshold levels. The result from the query should be numeric. For extra security, create a user with minimal access.
Note: You must specify mysql_query_password with an empty string to force an empty password,
overriding any my.cnf settings.
| mysql_query_hostname | Optional. Host name, IP Address, or unix socket (must be an absolute path). |
| mysql_query_port | Optional. Port number (default: 3306). |
| mysql_query_database | Optional. Check database with indicated name. |
| mysql_query_file | Optional. Read from the specified client options file. |
| mysql_query_group | Optional. Use a client options group. |
| mysql_query_username | Optional. Connect using the indicated username. |
| mysql_query_password | Optional. Use the indicated password to authenticate the connection. |
| mysql_query_execute | Required. SQL Query to run on the MySQL Server. |
| mysql_query_warning | Optional. Exit with WARNING status if query is outside of the range (format: start:end). |
| mysql_query_critical | Optional. Exit with CRITICAL status if query is outside of the range. |
negate ¶
The negate plugin negates the status of a plugin (returns OK for CRITICAL and vice-versa). Additional switches can be used to control which state becomes what.
| negate_timeout | Optional. Seconds before plugin times out (default: 11). |
| negate_timeout_result | Optional. Custom result on Negate timeouts, default to UNKNOWN. |
| negate_ok | Optional. OK, WARNING, CRITICAL or UNKNOWN. |
| negate_warning | Numeric values are accepted. |
| negate_critical | If nothing is specified, |
| negate_unknown | permutes OK and CRITICAL. |
| negate_substitute | Optional. Substitute output text as well. Will only substitute text in CAPITALS. |
| negate_command | Required. Command to be negated. |
| negate_arguments | Optional. Arguments for the negated command. |
nrpe ¶
The check_nrpe plugin can be used to query an NRPE
server or NSClient++. Note: This plugin
is considered insecure/deprecated.
| nrpe_address | Optional. The host’s address. Defaults to “$address$” if the host’s address attribute is set, “$address6$” otherwise. |
| nrpe_port | Optional. The NRPE port. Defaults to 5666. |
| nrpe_command | Optional. The command that should be executed. |
| nrpe_no_ssl | Optional. Whether to disable SSL or not. Defaults to false. |
| nrpe_timeout_unknown | Optional. Whether to set timeouts to unknown instead of critical state. Defaults to false. |
| nrpe_timeout | Optional. The timeout in seconds. |
| nrpe_arguments | Optional. Arguments that should be passed to the command. Multiple arguments must be defined as array. |
| nrpe_ipv4 | Optional. Use IPv4 connection. Defaults to false. |
| nrpe_ipv6 | Optional. Use IPv6 connection. Defaults to false. |
| nrpe_version_2 | Optional. Use this if you want to connect using NRPE v2 protocol. Defaults to false. |
nscp ¶
The check_nt plugin collects data from the NSClient++ service.
| nscp_address | Optional. The host’s address. Defaults to “$address$” if the host’s address attribute is set, “$address6$” otherwise. |
| nscp_port | Optional. The NSClient++ port. Defaults to 12489. |
| nscp_password | Optional. The NSClient++ password. |
| nscp_variable | Required. The variable that should be checked. |
| nscp_params | Optional. Parameters for the query. Multiple parameters must be defined as array. |
| nscp_warn | Optional. The warning threshold. |
| nscp_crit | Optional. The critical threshold. |
| nscp_timeout | Optional. The query timeout in seconds. |
| nscp_showall | Optional. Use with SERVICESTATE to see working services or PROCSTATE for running processes. Defaults to false. |
ntp_time ¶
The check_ntp_time plugin checks the clock offset between the local host and a remote NTP server.
Note: If you want to monitor an NTP server, please use ntp_peer.
| ntp_address | Optional. The host’s address. Defaults to “$address$” if the host’s address attribute is set, “$address6$” otherwise. |
| ntp_port | Optional. Port number (default: 123). |
| ntp_quiet | Optional. Returns UNKNOWN instead of CRITICAL if offset cannot be found. |
| ntp_warning | Optional. Offset to result in warning status (seconds). |
| ntp_critical | Optional. Offset to result in critical status (seconds). |
| ntp_timeoffset | Optional. Expected offset of the ntp server relative to local server (seconds). |
| ntp_timeout | Optional. Seconds before connection times out (default: 10). |
| ntp_ipv4 | Optional. Use IPv4 connection. Defaults to false. |
| ntp_ipv6 | Optional. Use IPv6 connection. Defaults to false. |
ntp_peer ¶
The check_ntp_peer plugin
checks the health of an NTP server. It supports checking the offset with the sync peer, the
jitter and stratum. This plugin will not check the clock offset between the local host and NTP
server; please use ntp_time for that purpose.
| ntp_port | Optional. The port to use. Default to 123. |
| ntp_quiet | Optional. Returns UNKNOWN instead of CRITICAL or WARNING if server isn’t synchronized. |
| ntp_wstratum | Optional. Warning threshold for stratum of server’s synchronization peer. |
| ntp_cstratum | Optional. Critical threshold for stratum of server’s synchronization peer. |
| ntp_wjitter | Optional. Warning threshold for jitter. |
| ntp_cjitter | Optional. Critical threshold for jitter. |
| ntp_wsource | Optional. Warning threshold for number of usable time sources. |
| ntp_csource | Optional. Critical threshold for number of usable time sources. |
pgsql ¶
The check_pgsql plugin
tests a PostgreSQL DBMS to determine whether it is active and accepting queries.
If a query is specified using the pgsql_query attribute, it will be executed after
connecting to the server. The result from the query has to be numeric in order
to compare it against the query thresholds if set.
| pgsql_hostname | Optional. Host name, IP Address, or unix socket (must be an absolute path). |
| pgsql_port | Optional. Port number (default: 5432). |
| pgsql_database | Optional. Database to check (default: template1). |
| pgsql_username | Optional. Login name of user. |
| pgsql_password | Optional. Password (BIG SECURITY ISSUE). |
| pgsql_options | Optional. Connection parameters (keyword = value), see below. |
| pgsql_warning | Optional. Response time to result in warning status (seconds). |
| pgsql_critical | Optional. Response time to result in critical status (seconds). |
| pgsql_timeout | Optional. Seconds before connection times out (default: 10). |
| pgsql_query | Optional. SQL query to run. Only first column in first row will be read. |
| pgsql_query_warning | Optional. SQL query value to result in warning status (double). |
| pgsql_query_critical | Optional. SQL query value to result in critical status (double). |
ping ¶
The check_ping plugin uses the ping command to probe the specified host for packet loss (percentage) and round trip average (milliseconds).
This command uses the host’s address attribute if available and falls back to using
ping4 ¶
This command uses the host’s address attribute if not explicitly specified using
the ping_address attribute.
ping6 ¶
This command uses the host’s address6 attribute if not explicitly specified using
pop ¶
The check_pop plugin tests POP connections with the specified host (or unix socket).
| pop_address | Optional. The host’s address. Defaults to “$address$” if the host’s address attribute is set, “$address6$” otherwise. |
| pop_port | Optional. The port that should be checked. Defaults to 110. |
| pop_escape | Optional. Can use \n, \r, \t or \ in send or quit string. Must come before send or quit option. Default: nothing added to send, \r\n added to end of quit. |
| pop_send | Optional. String to send to the server. |
| pop_expect | Optional. String to expect in server response. Multiple strings must be defined as array. |
| pop_all | Optional. All expect strings need to occur in server response. Default is any. |
| pop_quit | Optional. String to send server to initiate a clean close of the connection. |
| pop_refuse | Optional. Accept TCP refusals with states ok, warn, crit (default: crit). |
| pop_mismatch | Optional. Accept expected string mismatches with states ok, warn, crit (default: warn). |
| pop_jail | Optional. Hide output from TCP socket. |
| pop_maxbytes | Optional. Close connection once more than this number of bytes are received. |
| pop_delay | Optional. Seconds to wait between sending string and polling for response. |
| pop_certificate_age | Optional. Minimum number of days a certificate has to be valid. |
| pop_ssl | Optional. Use SSL for the connection. |
| pop_warning | Optional. Response time to result in warning status (seconds). |
| pop_critical | Optional. Response time to result in critical status (seconds). |
| pop_timeout | Optional. Seconds before connection times out (default: 10). |
| pop_ipv4 | Optional. Use IPv4 connection. Defaults to false. |
| pop_ipv6 | Optional. Use IPv6 connection. Defaults to false. |
procs ¶
The check_procs plugin checks all processes and generates WARNING or CRITICAL states if the specified metric is outside the required threshold ranges. The metric defaults to number of processes. Search filters can be applied to limit the processes to check.
| procs_warning | Optional. The process count warning threshold. Defaults to 250. |
| procs_critical | Optional. The process count critical threshold. Defaults to 400. |
| procs_metric | Optional. Check thresholds against metric. |
| procs_timeout | Optional. Seconds before plugin times out. |
| procs_traditional | Optional. Filter own process the traditional way by PID instead of /proc/pid/exe. Defaults to false. |
| procs_state | Optional. Only scan for processes that have one or more of the status flags you specify. |
| procs_ppid | Optional. Only scan for children of the parent process ID indicated. |
| procs_vsz | Optional. Only scan for processes with VSZ higher than indicated. |
| procs_rss | Optional. Only scan for processes with RSS higher than indicated. |
| procs_pcpu | Optional. Only scan for processes with PCPU higher than indicated. |
| procs_user | Optional. Only scan for processes with user name or ID indicated. |
| procs_argument | Optional. Only scan for processes with args that contain STRING. |
| procs_argument_regex | Optional. Only scan for processes with args that contain the regex STRING. |
| procs_command | Optional. Only scan for exact matches of COMMAND (without path). |
| procs_nokthreads | Optional. Only scan for non kernel threads. Defaults to false. |
radius ¶
The check_radius plugin checks a RADIUS server to see if it is accepting connections. The server to test must be specified in the invocation, as well as a user name and password. A configuration file may also be present. The format of the configuration file is described in the radiusclient library sources. The password option presents a substantial security issue because the password can possibly be determined by careful watching of the command line in a process listing. This risk is exacerbated because the plugin will typically be executed at regular predictable intervals. Please be sure that the password used does not allow access to sensitive system resources.
| radius_address | Optional. The radius server’s address. Defaults to “$address$” if the host’s address attribute is set, “$address6$” otherwise. |
| radius_config_file | Required. The radius configuration file. |
| radius_username | Required. The radius username to test. |
| radius_password | Required. The radius password to test. |
| radius_port | Optional. The radius port number (default 1645). |
| radius_nas_id | Optional. The NAS identifier. |
| radius_nas_address | Optional. The NAS IP address. |
| radius_expect | Optional. The response string to expect from the server. |
| radius_retries | Optional. The number of times to retry a failed connection. |
| radius_timeout | Optional. The number of seconds before connection times out (default: 10). |
rpc ¶
The check_rpc
plugin tests if a service is registered and running using rpcinfo -H host -C rpc_command.
| rpc_address | Optional. The rpc host address. Defaults to “$address$ if the host address attribute is set, “$address6$” otherwise. |
| rpc_command | Required. The programm name (or number). |
| rpc_port | Optional. The port that should be checked. |
| rpc_version | Optional. The version you want to check for (one or more). |
| rpc_udp | Optional. Use UDP test. Defaults to false. |
| rpc_tcp | Optional. Use TCP test. Defaults to false. |
| rpc_verbose | Optional. Show verbose output. Defaults to false. |
simap ¶
The check_simap plugin tests SIMAP connections with the specified host (or unix socket).
| simap_address | Optional. The host’s address. Defaults to “$address$” if the host’s address attribute is set, “$address6$” otherwise. |
| simap_port | Optional. The port that should be checked. Defaults to 993. |
| simap_escape | Optional. Can use \n, \r, \t or \ in send or quit string. Must come before send or quit option. Default: nothing added to send, \r\n added to end of quit. |
| simap_send | Optional. String to send to the server. |
| simap_expect | Optional. String to expect in server response. Multiple strings must be defined as array. |
| simap_all | Optional. All expect strings need to occur in server response. Default is any. |
| simap_quit | Optional. String to send server to initiate a clean close of the connection. |
| simap_refuse | Optional. Accept TCP refusals with states ok, warn, crit (default: crit). |
| simap_mismatch | Optional. Accept expected string mismatches with states ok, warn, crit (default: warn). |
| simap_jail | Optional. Hide output from TCP socket. |
| simap_maxbytes | Optional. Close connection once more than this number of bytes are received. |
| simap_delay | Optional. Seconds to wait between sending string and polling for response. |
| simap_certificate_age | Optional. Minimum number of days a certificate has to be valid. |
| simap_ssl | Optional. Use SSL for the connection. |
| simap_warning | Optional. Response time to result in warning status (seconds). |
| simap_critical | Optional. Response time to result in critical status (seconds). |
| simap_timeout | Optional. Seconds before connection times out (default: 10). |
| simap_ipv4 | Optional. Use IPv4 connection. Defaults to false. |
| simap_ipv6 | Optional. Use IPv6 connection. Defaults to false. |
smart ¶
The check_ide_smart plugin
checks a local hard drive with the (Linux specific) SMART interface. Requires installation of smartctl.
| smart_device | Required. The name of a local hard drive to monitor. |
smtp ¶
The check_smtp plugin will attempt to open an SMTP connection with the host.
| smtp_address | Optional. The host’s address. Defaults to “$address$” if the host’s address attribute is set, “$address6$” otherwise. |
| smtp_port | Optional. The port that should be checked. Defaults to 25. |
| smtp_mail_from | Optional. Test a MAIL FROM command with the given email address. |
| smtp_expect | Optional. String to expect in first line of server response (default: ‘220’). |
| smtp_command | Optional. SMTP command (may be used repeatedly). |
| smtp_response | Optional. Expected response to command (may be used repeatedly). |
| smtp_helo_fqdn | Optional. FQDN used for HELO |
| smtp_certificate_age | Optional. Minimum number of days a certificate has to be valid. |
| smtp_starttls | Optional. Use STARTTLS for the connection. |
| smtp_authtype | Optional. SMTP AUTH type to check (default none, only LOGIN supported). |
| smtp_authuser | Optional. SMTP AUTH username. |
| smtp_authpass | Optional. SMTP AUTH password. |
| smtp_ignore_quit | Optional. Ignore failure when sending QUIT command to server. |
| smtp_warning | Optional. Response time to result in warning status (seconds). |
| smtp_critical | Optional. Response time to result in critical status (seconds). |
| smtp_timeout | Optional. Seconds before connection times out (default: 10). |
| smtp_ipv4 | Optional. Use IPv4 connection. Defaults to false. |
| smtp_ipv6 | Optional. Use IPv6 connection. Defaults to false. |
snmp ¶
The check_snmp plugin checks the status of remote machines and obtains system information via SNMP.
Note: This plugin uses the snmpget command included with the NET-SNMP package.
| snmp_address | Optional. The host’s address. Defaults to “$address$” if the host’s address attribute is set, “$address6$” otherwise. |
| snmp_oid | Required. The SNMP OID. |
| snmp_community | Optional. The SNMP community. Defaults to “public”. |
| snmp_port | Optional. The SNMP port. Defaults to “161”. |
| snmp_retries | Optional. Number of retries to be used in the SNMP requests. |
| snmp_warn | Optional. The warning threshold. |
| snmp_crit | Optional. The critical threshold. |
| snmp_string | Optional. Return OK state if the string matches exactly with the output value |
| snmp_ereg | Optional. Return OK state if extended regular expression REGEX matches with the output value |
| snmp_eregi | Optional. Return OK state if case-insensitive extended REGEX matches with the output value |
| snmp_label | Optional. Prefix label for output value |
| snmp_invert_search | Optional. Invert search result and return CRITICAL state if found |
| snmp_units | Optional. Units label(s) for output value (e.g., ‘sec.’). |
| snmp_version | Optional. Version to use. E.g. 1, 2, 2c or 3. |
| snmp_miblist | Optional. MIB’s to use, comma separated. Defaults to “ALL”. |
| snmp_rate_multiplier | Optional. Converts rate per second. For example, set to 60 to convert to per minute. |
| snmp_rate | Optional. Boolean. Enable rate calculation. |
| snmp_getnext | Optional. Boolean. Use SNMP GETNEXT. Defaults to false. |
| snmp_timeout | Optional. The command timeout in seconds. Defaults to 10 seconds. |
| snmp_offset | Optional. Add/subtract the specified OFFSET to numeric sensor data. |
| snmp_output_delimiter | Optional. Separates output on multiple OID requests. |
| snmp_perf_oids | Optional. Label performance data with OIDs instead of –label’s. |
snmpv3 ¶
Check command object for the check_snmp plugin, using SNMPv3 authentication and encryption options.
| snmpv3_address | Optional. The host’s address. Defaults to “$address$” if the host’s address attribute is set, “$address6$” otherwise. |
| snmpv3_getnext | Optional. Use SNMP GETNEXT instead of SNMP GET. |
| snmpv3_seclevel | Optional. The security level. Defaults to authPriv. |
| snmpv3_auth_alg | Optional. The authentication algorithm. Defaults to SHA. |
| snmpv3_user | Required. The username to log in with. |
| snmpv3_auth_key | Required, The authentication key. Required if snmpv3_seclevel is set to authPriv otherwise optional. |
| snmpv3_priv_key | Required. The encryption key. |
| snmpv3_oid | Required. The SNMP OID. |
| snmpv3_priv_alg | Optional. The encryption algorithm. Defaults to AES. |
| snmpv3_warn | Optional. The warning threshold. |
| snmpv3_crit | Optional. The critical threshold. |
| snmpv3_string | Optional. Return OK state (for that OID) if STRING is an exact match. |
| snmpv3_ereg | Optional. Return OK state (for that OID) if extended regular expression REGEX matches. |
| snmpv3_eregi | Optional. Return OK state (for that OID) if case-insensitive extended REGEX matches. |
| snmpv3_invert_search | Optional. Invert search result and return CRITICAL if found |
| snmpv3_label | Optional. Prefix label for output value. |
| snmpv3_units | Optional. Units label(s) for output value (e.g., ‘sec.’). |
| snmpv3_rate_multiplier | Optional. Converts rate per second. For example, set to 60 to convert to per minute. |
| snmpv3_rate | Optional. Boolean. Enable rate calculation. |
| snmpv3_timeout | Optional. The command timeout in seconds. Defaults to 10 seconds. |
snmp-uptime ¶
Check command object for the check_snmp plugin, using the uptime OID by default.
| snmp_oid | Optional. The SNMP OID. Defaults to “1.3.6.1.2.1.1.3.0”. |
spop ¶
The check_spop plugin tests SPOP connections with the specified host (or unix socket).
| spop_address | Optional. The host’s address. Defaults to “$address$” if the host’s address attribute is set, “$address6$” otherwise. |
| spop_port | Optional. The port that should be checked. Defaults to 995. |
| spop_escape | Optional. Can use \n, \r, \t or \ in send or quit string. Must come before send or quit option. Default: nothing added to send, \r\n added to end of quit. |
| spop_send | Optional. String to send to the server. |
| spop_expect | Optional. String to expect in server response. Multiple strings must be defined as array. |
| spop_all | Optional. All expect strings need to occur in server response. Default is any. |
| spop_quit | Optional. String to send server to initiate a clean close of the connection. |
| spop_refuse | Optional. Accept TCP refusals with states ok, warn, crit (default: crit). |
| spop_mismatch | Optional. Accept expected string mismatches with states ok, warn, crit (default: warn). |
| spop_jail | Optional. Hide output from TCP socket. |
| spop_maxbytes | Optional. Close connection once more than this number of bytes are received. |
| spop_delay | Optional. Seconds to wait between sending string and polling for response. |
| spop_certificate_age | Optional. Minimum number of days a certificate has to be valid. |
| spop_ssl | Optional. Use SSL for the connection. |
| spop_warning | Optional. Response time to result in warning status (seconds). |
| spop_critical | Optional. Response time to result in critical status (seconds). |
| spop_timeout | Optional. Seconds before connection times out (default: 10). |
| spop_ipv4 | Optional. Use IPv4 connection. Defaults to false. |
| spop_ipv6 | Optional. Use IPv6 connection. Defaults to false. |
ssh ¶
The check_ssh plugin connects to an SSH server at a specified host and port.
| ssh_port | Optional. The port that should be checked. Defaults to 22. |
| ssh_timeout | Optional. Seconds before connection times out. Defaults to 10. |
ssl ¶
Check command object for the check_tcp plugin, using ssl-related options.
| ssl_address | Optional. The host’s address. Defaults to “$address$” if the host’s address attribute is set, “$address6$” otherwise. |
| ssl_port | Optional. The port that should be checked. Defaults to 443. |
| ssl_timeout | Optional. Timeout in seconds for the connect and handshake. The plugin default is 10 seconds. |
| ssl_cert_valid_days_warn | Optional. Warning threshold for days before the certificate will expire. When used, the default for ssl_cert_valid_days_critical is 0. |
| ssl_cert_valid_days_critical | Optional. Critical threshold for days before the certificate will expire. When used, ssl_cert_valid_days_warn must also be set. |
| ssl_sni | Optional. The server_name that is send to select the SSL certificate to check. Important if SNI is used. |
ssmtp ¶
The check_ssmtp plugin tests SSMTP connections with the specified host (or unix socket).
| ssmtp_address | Optional. The host’s address. Defaults to “$address$” if the host’s address attribute is set, “$address6$” otherwise. |
| ssmtp_port | Optional. The port that should be checked. Defaults to 465. |
| ssmtp_escape | Optional. Can use \n, \r, \t or \ in send or quit string. Must come before send or quit option. Default: nothing added to send, \r\n added to end of quit. |
| ssmtp_send | Optional. String to send to the server. |
| ssmtp_expect | Optional. String to expect in server response. Multiple strings must be defined as array. |
| ssmtp_all | Optional. All expect strings need to occur in server response. Default is any. |
| ssmtp_quit | Optional. String to send server to initiate a clean close of the connection. |
| ssmtp_refuse | Optional. Accept TCP refusals with states ok, warn, crit (default: crit). |
| ssmtp_mismatch | Optional. Accept expected string mismatches with states ok, warn, crit (default: warn). |
| ssmtp_jail | Optional. Hide output from TCP socket. |
| ssmtp_maxbytes | Optional. Close connection once more than this number of bytes are received. |
| ssmtp_delay | Optional. Seconds to wait between sending string and polling for response. |
| ssmtp_certificate_age | Optional. Minimum number of days a certificate has to be valid. |
| ssmtp_ssl | Optional. Use SSL for the connection. |
| ssmtp_warning | Optional. Response time to result in warning status (seconds). |
| ssmtp_critical | Optional. Response time to result in critical status (seconds). |
| ssmtp_timeout | Optional. Seconds before connection times out (default: 10). |
| ssmtp_ipv4 | Optional. Use IPv4 connection. Defaults to false. |
| ssmtp_ipv6 | Optional. Use IPv6 connection. Defaults to false. |
swap ¶
The check_swap plugin checks the swap space on a local machine.
| swap_wfree | Optional. The free swap space warning threshold in % (enable swap_integer for number values). Defaults to 50%. |
| swap_cfree | Optional. The free swap space critical threshold in % (enable swap_integer for number values). Defaults to 25%. |
| swap_integer | Optional. Specifies whether the thresholds are passed as number or percent value. Defaults to false (percent values). |
| swap_allswaps | Optional. Conduct comparisons for all swap partitions, one by one. Defaults to false. |
| swap_noswap | Optional. Resulting state when there is no swap regardless of thresholds. Possible values are “ok”, “warning”, “critical”, “unknown”. Defaults to “critical”. |
tcp ¶
The check_tcp plugin tests TCP connections with the specified host (or unix socket).
| tcp_address | Optional. The host’s address. Defaults to “$address$” if the host’s address attribute is set, “$address6$” otherwise. |
| tcp_port | Required. The port that should be checked. |
| tcp_expect | Optional. String to expect in server response. Multiple strings must be defined as array. |
| tcp_all | Optional. All expect strings need to occur in server response. Defaults to false. |
| tcp_escape_send | Optional. Enable usage of \n, \r, \t or \\ in send string. |
| tcp_send | Optional. String to send to the server. |
| tcp_escape_quit | Optional. Enable usage of \n, \r, \t or \\ in quit string. |
| tcp_quit | Optional. String to send server to initiate a clean close of the connection. |
| tcp_refuse | Optional. Accept TCP refusals with states ok, warn, crit. Defaults to crit. |
| tcp_mismatch | Optional. Accept expected string mismatches with states ok, warn, crit. Defaults to warn. |
| tcp_jail | Optional. Hide output from TCP socket. |
| tcp_maxbytes | Optional. Close connection once more than this number of bytes are received. |
| tcp_delay | Optional. Seconds to wait between sending string and polling for response. |
| tcp_certificate | Optional. Minimum number of days a certificate has to be valid. 1st value is number of days for warning, 2nd is critical (if not specified: 0) – separated by comma. |
| tcp_ssl | Optional. Use SSL for the connection. Defaults to false. |
| tcp_wtime | Optional. Response time to result in warning status (seconds). |
| tcp_ctime | Optional. Response time to result in critical status (seconds). |
| tcp_timeout | Optional. Seconds before connection times out. Defaults to 10. |
| tcp_ipv4 | Optional. Use IPv4 connection. Defaults to false. |
| tcp_ipv6 | Optional. Use IPv6 connection. Defaults to false. |
udp ¶
The check_udp plugin tests UDP connections with the specified host (or unix socket).
Custom attributes passed as command parameters:
| Name | Description |
| udp_address | Optional. The host’s address. Defaults to “$address$” if the host’s address attribute is set, “$address6$” otherwise. |
| udp_port | Required. The port that should be checked. |
| udp_send | Required. The payload to send in the UDP datagram. |
| udp_expect | Required. The payload to expect in the response datagram. |
| udp_quit | Optional. The payload to send to ‘close’ the session. |
| udp_ipv4 | Optional. Use IPv4 connection. Defaults to false. |
| udp_ipv6 | Optional. Use IPv6 connection. Defaults to false. |
ups ¶
The check_ups plugin tests the UPS service on the specified host. Network UPS Tools must be running for this plugin to work.
| ups_address | Required. The address of the host running upsd. Defaults to “$address$” if the host’s address attribute is set, “$address6$” otherwise. |
| ups_name | Required. The UPS name. Defaults to ups. |
| ups_port | Optional. The port to which to connect. Defaults to 3493. |
| ups_variable | Optional. The variable to monitor. Must be one of LINE, TEMP, BATTPCT or LOADPCT. If this is not set, the check only relies on the value of ups.status. |
| ups_warning | Optional. The warning threshold for the selected variable. |
| ups_critical | Optional. The critical threshold for the selected variable. |
| ups_celsius | Optional. Display the temperature in degrees Celsius instead of Fahrenheit. Defaults to false. |
| ups_timeout | Optional. The number of seconds before the connection times out. Defaults to 10. |
users ¶
The check_users plugin checks the number of users currently logged in on the local system and generates an error if the number exceeds the thresholds specified.
| users_wgreater | Optional. The user count warning threshold. Defaults to 20. |
| users_cgreater | Optional. The user count critical threshold. Defaults to 50. |
Windows Plugins for Icinga 2 ¶
To allow a basic monitoring of Windows clients Icinga 2 comes with a set of Windows only plugins. While trying to mirror the functionalities of their linux cousins from the monitoring-plugins package, the differences between Windows and Linux are too big to be able use the same CheckCommands for both systems.
A check-commands-windows.conf comes with Icinga 2, it assumes that the Windows Plugins are installed in the PluginDir set in your constants.conf. To enable them the following include directive is needed in you icinga2.conf:
include <windows-plugins>
One of the differences between the Windows plugins and their linux counterparts is that they consistently do not require thresholds to run, functioning like dummies without.
Threshold syntax ¶
So not specified differently the thresholds for the plugins all follow the same pattern
| Threshold | Meaning |
| “29” | The threshold is 29. |
| “!29” | The threshold is 29, but the negative of the result is returned. |
| “[10-40]” | The threshold is a range from (including) 10 to 40, a value inside means the threshold has been exceeded. |
| ”![10-40]” | Same as above, but the result is inverted. |
disk-windows ¶
Check command object for the check_disk.exe plugin.
Aggregates the disk space of all volumes and mount points it can find, or the ones defined in disk_win_path. Ignores removable storage like flash drives and discs (CD, DVD etc.).
The data collection is instant and free disk space (default, see disk_win_show_used) is used for threshold computation.
Note
Percentage based thresholds can be used by adding a ‘%’ to the threshold value.
Custom attributes:
| disk_win_warn | Optional. The warning threshold. Defaults to “20%”. |
| disk_win_crit | Optional. The critical threshold. Defaults to “10%”. |
| disk_win_path | Optional. Check only these paths, default checks all. |
| disk_win_unit | Optional. Use this unit to display disk space, thresholds are interpreted in this unit. Defaults to “mb”, possible values are: b, kb, mb, gb and tb. |
| disk_win_exclude | Optional. Exclude these drives from check. |
| disk_win_show_used | Optional. Use used instead of free space. |
load-windows ¶
Check command object for the check_load.exe plugin.
This plugin collects the inverse of the performance counter \Processor(_Total)\% Idle Time two times, with a wait time of one second between the collection. To change this wait time use perfmon-windows.
Custom attributes:
| load_win_warn | Optional. The warning threshold. |
| load_win_crit | Optional. The critical threshold. |
memory-windows ¶
Check command object for the check_memory.exe plugin.
The memory collection is instant and free memory is used for threshold computation.
Note
Percentage based thresholds can be used by adding a ‘%’ to the threshold value. Keep in mind that memory_win_unit is applied before the value is calculated.
Custom attributes:
| memory_win_warn | Optional. The warning threshold. Defaults to “10%”. |
| memory_win_crit | Optional. The critical threshold. Defaults to “5%”. |
| memory_win_unit | Optional. The unit to display the received value in, thresholds are interpreted in this unit. Defaults to “mb” (megabyte), possible values are: b, kb, mb, gb and tb. |
| memory_win_show_used | Optional. Show used memory instead of the free memory. |
network-windows ¶
Check command object for the check_network.exe plugin.
Collects the total Bytes inbound and outbound for all interfaces in one second, to itemise interfaces or use a different collection interval use perfmon-windows.
Custom attributes:
| network_win_warn | Optional. The warning threshold. |
| network_win_crit | Optional. The critical threshold. |
| network_no_isatap | Optional. Do not print ISATAP interfaces. |
perfmon-windows ¶
Check command object for the check_perfmon.exe plugin.
This plugins allows to collect data from a Performance Counter. After the first data collection a second one is done after perfmon_win_wait milliseconds. When you know perfmon_win_counter only requires one set of data to provide valid data you can set perfmon_win_wait to 0.
To receive a list of possible Performance Counter Objects run check_perfmon.exe --print-objects and to view an objects instances and counters run check_perfmon.exe --print-object-info -P "name of object"
Custom attributes:
| perfmon_win_warn | Optional. The warning threshold. |
| perfmon_win_crit | Optional. The critical threshold. |
| perfmon_win_counter | Required. The Performance Counter to use. Ex. \Processor(_Total)\% Idle Time. |
| perfmon_win_wait | Optional. Time in milliseconds to wait between data collection (default: 1000). |
| perfmon_win_type | Optional. Format in which to expect performance values. Possible are: long, int64 and double (default). |
| perfmon_win_syntax | Optional. Use this in the performance output instead of perfmon\_win\_counter. Exists for graphics compatibility reasons. |
ping-windows ¶
Check command object for the check_ping.exe plugin.
ping-windows should automatically detect whether ping_win_address is an IPv4 or IPv6 address. If not, use ping4-windows and ping6-windows. Also note that check_ping.exe waits at least ping_win_timeout milliseconds between the pings.
Custom attributes:
| ping_win_warn | Optional. The warning threshold. RTA and package loss separated by comma. |
| ping_win_crit | Optional. The critical threshold. RTA and package loss separated by comma. |
| ping_win_address | Required. An IPv4 or IPv6 address. |
| ping_win_packets | Optional. Number of packages to send. Default: 5. |
| ping_win_timeout | Optional. The timeout in milliseconds. Default: 1000 |
procs-windows ¶
Check command object for check_procs.exe plugin.
When using procs_win_user this plugins needs administrative privileges to access the processes of other users, to just enumerate them no additional privileges are required.
Custom attributes:
| procs_win_warn | Optional. The warning threshold. |
| procs_win_crit | Optional. The critical threshold. |
| procs_win_user | Optional. Count this users processes. |
service-windows ¶
Check command object for check_service.exe plugin.
This checks thresholds work different since the binary decision whether a service is running or not does not allow for three states. As a default check_service.exe will return CRITICAL when service_win_service is not running, the service_win_warn flag changes this to WARNING.
Custom attributes:
| service_win_warn | Optional. Warn when service is not running. |
| service_win_description | Optional. If this is set, service\_win\_service looks at the service description. |
| service_win_service | Required. Name of the service to check. |
swap-windows ¶
Check command object for check_swap.exe plugin.
The data collection is instant.
Custom attributes:
| swap_win_warn | Optional. The warning threshold. Defaults to “10%”. |
| swap_win_crit | Optional. The critical threshold. Defaults to “5%”. |
| swap_win_unit | Optional. The unit to display the received value in, thresholds are interpreted in this unit. Defaults to “mb” (megabyte). |
| swap_win_show_used | Optional. Show used swap instead of the free swap. |
update-windows ¶
Check command object for check_update.exe plugin.
Querying Microsoft for Windows updates can take multiple seconds to minutes. An update is treated as important when it has the WSUS flag for SecurityUpdates or CriticalUpdates.
Note
The Network Services Account which runs Icinga 2 by default does not have the required permissions to run this check.
Custom attributes:
| update_win_warn | Optional. If set, returns warning when important updates are available. |
| update_win_crit | Optional. If set, return critical when important updates that require a reboot are available. |
| update_win_reboot | Optional. Set to treat ‘may need update’ as ‘definitely needs update’. Please Note that this is true for almost every update and is therefore not recommended. |
In contrast to most other plugins, the values of check_update’s custom attributes do not set thresholds, but just enable/disable the behavior described in the table above.
It can be enabled/disabled for example by setting them to “true” or “false”, “1” or “0” would also work.
Thresholds will always be “1”.
Note
If they are enabled, performance data will be shown in the web interface. If run without the optional parameters, the plugin will output critical if any important updates are available.
uptime-windows ¶
Check command object for check_uptime.exe plugin.
Uses GetTickCount64 to get the uptime, so boot time is not included.
Custom attributes:
| uptime_win_warn | Optional. The warning threshold. |
| uptime_win_crit | Optional. The critical threshold. |
| uptime_win_unit | Optional. The unit to display the received value in, thresholds are interpreted in this unit. Defaults to “s”(seconds), possible values are ms (milliseconds), s, m (minutes), h (hours). |
users-windows ¶
Check command object for check_users.exe plugin.
Custom attributes:
| users_win_warn | Optional. The warning threshold. |
| users_win_crit | Optional. The critical threshold. |
Plugin Check Commands for NSClient++ ¶
There are two methods available for querying NSClient++:
- Query the HTTP API locally from an Icinga 2 client (requires a running NSClient++ service)
- Run a local CLI check (does not require NSClient++ as a service)
Both methods have their advantages and disadvantages. One thing to note: If you rely on performance counter delta calculations such as CPU utilization, please use the HTTP API instead of the CLI sample call.
For security reasons, it is advised to enable the NSClient++ HTTP API for local connection from the Icinga 2 client only. Remote connections to the HTTP API are not recommended with using the legacy HTTP API.
nscp_api ¶
check_nscp_api is part of the Icinga 2 plugins. This plugin is available for
both, Windows and Linux/Unix.
Verify that the ITL CheckCommand is included in the icinga2.conf configuration file:
vim /etc/icinga2/icinga2.conf
include <plugins>
check_nscp_api runs queries against the NSClient++ API. Therefore NSClient++ needs to have
the webserver module enabled, configured and loaded.
You can install the webserver using the following CLI commands:
./nscp.exe web install
./nscp.exe web password — –set icinga
Now you can define specific queries and integrate them into Icinga 2.
The check plugin check_nscp_api can be integrated with the nscp_api CheckCommand object:
Custom attributes:
| nscp_api_host | Required. NSCP API host address. Defaults to “$address$” if the host’s address attribute is set, “$address6$” otherwise. |
| nscp_api_port | Optional. NSCP API port. Defaults to 8443. |
| nscp_api_password | Required. NSCP API password. Please check the NSCP documentation for setup details. |
| nscp_api_query | Required. NSCP API query endpoint. Refer to the NSCP documentation for possible values. |
| nscp_api_arguments | Optional. NSCP API arguments dictionary either as single strings or key-value pairs using =. Refer to the NSCP documentation. |
nscp_api_arguments can be used to pass required thresholds to the executed check. The example below
checks the CPU utilization and specifies warning and critical thresholds.
check_nscp_api --host 10.0.10.148 --password icinga --query check_cpu --arguments show-all warning='load>40' critical='load>30'
check_cpu CRITICAL: critical(5m: 48%, 1m: 36%), 5s: 0% | 'total 5m'=48%;40;30 'total 1m'=36%;40;30 'total 5s'=0%;40;30
nscp-local ¶
Icinga 2 can use the nscp client command to run arbitrary NSClient++ checks locally on the client.
You can enable these check commands by adding the following the include directive in your icinga2.conf configuration file:
include <nscp>
You can also optionally specify an alternative installation directory for NSClient++ by adding the NscpPath constant in your constants.conf configuration file:
const NscpPath = "C:\\Program Files (x86)\\NSClient++"
By default Icinga 2 uses the Microsoft Installer API to determine where NSClient++ is installed. It should not be necessary to manually set this constant.
Note that it is not necessary to run NSClient++ as a Windows service for these commands to work.
The check command object for NSClient++ is available as nscp-local.
| nscp_log_level | Optional. The log level. Defaults to “critical”. |
| nscp_load_all | Optional. Whether to load all modules. Defaults to false. |
| nscp_modules | Optional. An array of NSClient++ modules to load. Defaults to [ "CheckSystem" ]. |
| nscp_boot | Optional. Whether to use the –boot option. Defaults to true. |
| nscp_query | Required. The NSClient++ query. Try nscp client -q x for a list. |
| nscp_arguments | Optional. An array of query arguments. |
| nscp_showall | Optional. Shows more details in plugin output, default to false. |
Tip
In order to measure CPU load, you’ll need a running NSClient++ service. Therefore it is advised to use a local nscp-api check against its REST API.
nscp-local-cpu ¶
Check command object for the check_cpu NSClient++ plugin.
| nscp_cpu_time | Optional. Calculate average usage for the given time intervals. Value has to be an array, default to [ “1m”, “5m”, “15m” ]. |
| nscp_cpu_warning | Optional. Threshold for WARNING state in percent, default to 80. |
| nscp_cpu_critical | Optional. Threshold for CRITICAL state in percent, default to 90. |
| nscp_cpu_arguments | Optional. Additional arguments. |
| nscp_cpu_showall | Optional. Shows more details in plugin output, default to false. |
nscp-local-memory ¶
Check command object for the check_memory NSClient++ plugin.
| nscp_memory_committed | Optional. Check for committed memory, default to false. |
| nscp_memory_physical | Optional. Check for physical memory, default to true. |
| nscp_memory_free | Optional. Switch between checking free (true) or used memory (false), default to false. |
| nscp_memory_warning | Optional. Threshold for WARNING state in percent or absolute (use MB, GB, …), default to 80 (free=false) or 20 (free=true). |
| nscp_memory_critical | Optional. Threshold for CRITICAL state in percent or absolute (use MB, GB, …), default to 90 (free=false) or 10 (free=true). |
| nscp_memory_arguments | Optional. Additional arguments. |
| nscp_memory_showall | Optional. Shows more details in plugin output, default to false. |
nscp-local-os-version ¶
Check command object for the check_os_version NSClient++ plugin.
This command has the same custom attributes like the nscp-local check command.
nscp-local-pagefile ¶
Check command object for the check_pagefile NSClient++ plugin.
nscp-local-process ¶
Check command object for the check_process NSClient++ plugin.
nscp-local-service ¶
Check command object for the check_service NSClient++ plugin.
| nscp_service_name | Required. Name of service to check. |
| nscp_service_type | Optional. Type to check, default to state. |
| nscp_service_ok | Optional. State for return an OK, i.e. for type=state running, stopped, … |
| nscp_service_otype | Optional. Dedicate type for nscp_service_ok, default to nscp_service_state. |
| nscp_service_warning | Optional. State for return an WARNING. |
| nscp_service_wtype | Optional. Dedicate type for nscp_service_warning, default to nscp_service_state. |
| nscp_service_critical | Optional. State for return an CRITICAL. |
| nscp_service_ctype | Optional. Dedicate type for nscp_service_critical, default to nscp_service_state. |
| nscp_service_arguments | Optional. Additional arguments. |
| nscp_service_showall | Optional. Shows more details in plugin output, default to true. |
nscp-local-uptime ¶
Check command object for the check_uptime NSClient++ plugin.
nscp-local-version ¶
Check command object for the check_version NSClient++ plugin.
In addition to that the default value for nscp_modules is set to [ "CheckHelpers" ].
nscp-local-disk ¶
Check command object for the check_drivesize NSClient++ plugin.
| nscp_disk_drive | Optional. Drive character, default to all drives. |
| nscp_disk_free | Optional. Switch between checking free space (free=true) or used space (free=false), default to false. |
| nscp_disk_warning | Optional. Threshold for WARNING in percent or absolute (use MB, GB, …), default to 80 (used) or 20 percent (free). |
| nscp_disk_critical | Optional. Threshold for CRITICAL in percent or absolute (use MB, GB, …), default to 90 (used) or 10 percent (free). |
| nscp_disk_arguments | Optional. Additional arguments. |
| nscp_disk_showall | Optional. Shows more details in plugin output, default to true. |
| nscp_modules | Optional. An array of NSClient++ modules to load. Defaults to [ "CheckDisk" ]. |
nscp-local-counter ¶
Check command object for the check_pdh NSClient++ plugin.
| nscp_counter_name | Required. Performance counter name. |
| nscp_counter_warning | Optional. WARNING Threshold. |
| nscp_counter_critical | Optional. CRITICAL Threshold. |
| nscp_counter_arguments | Optional. Additional arguments. |
| nscp_counter_showall | Optional. Shows more details in plugin output, default to false. |
| nscp_counter_perfsyntax | Optional. Apply performance data label, e.g. Total Processor Time to avoid special character problems. Defaults to nscp_counter_name. |
nscp-local-tasksched ¶
Check Command object for the check_tasksched NSClient++ plugin.
You can check for a single task or for a complete folder (and sub folders) of tasks.
| nscp_tasksched_name | Optional. Name of the task to check. |
| nscp_tasksched_folder | Optional. The folder in which the tasks to check reside. |
| nscp_tasksched_recursive | Optional. Recurse sub folder, defaults to true. |
| nscp_tasksched_hidden | Optional. Look for hidden tasks, defaults to false. |
| nscp_tasksched_warning | Optional. Filter which marks items which generates a warning state, defaults to exit_code != 0. |
| nscp_tasksched_critical | Optional. Filter which marks items which generates a critical state, defaults to exit_code < 0. |
| nscp_tasksched_emptystate | Optional. Return status to use when nothing matched filter, defaults to warning. |
| nscp_tasksched_perfsyntax | Optional. Performance alias syntax., defaults to %(title) |
| nscp_tasksched_detailsyntax | Optional. Detail level syntax, defaults to %(folder)/%(title): %(exit_code) != 0 |
| nscp_tasksched_arguments | Optional. Additional arguments. |
| nscp_tasksched_showall | Optional. Shows more details in plugin output, default to false. |
| nscp_modules | Optional. An array of NSClient++ modules to load. Defaults to [ "CheckTaskSched" ]. |
Plugin Check Commands for Manubulon SNMP ¶
The SNMP Manubulon Plugin Check Commands provide configuration for plugin check
commands provided by the SNMP Manubulon project.
Note: Some plugin parameters are only available in Debian packages or in a forked repository with patches applied.
The SNMP manubulon plugin check commands assume that the global constant named ManubulonPluginDir
is set to the path where the Manubublon SNMP plugins are installed.
You can enable these plugin check commands by adding the following the include directive in your icinga2.conf configuration file:
include <manubulon>
Checks by Host Type¶
N/A : Not available for this type.
SNMP : Available for simple SNMP query.
?? : Untested.
Specific : Script name for platform specific checks.
| Host type | Interface | storage | load/cpu | mem | process | env | specific |
| Linux | Yes | Yes | Yes | Yes | Yes | No | |
| Windows | Yes | Yes | Yes | Yes | Yes | No | check_snmp_win.pl |
| Cisco router/switch | Yes | N/A | Yes | Yes | N/A | Yes | |
| HP router/switch | Yes | N/A | Yes | Yes | N/A | No | |
| Bluecoat proxy | Yes | SNMP | Yes | SNMP | No | Yes | |
| CheckPoint on SPLAT | Yes | Yes | Yes | Yes | Yes | No | check_snmp_cpfw.pl |
| CheckPoint on Nokia IP | Yes | Yes | Yes | No | ?? | No | check_snmp_vrrp.pl |
| Boostedge | Yes | Yes | Yes | Yes | ?? | No | check_snmp_boostedge.pl |
| AS400 | Yes | Yes | Yes | Yes | No | No | |
| NetsecureOne Netbox | Yes | Yes | Yes | ?? | Yes | No | |
| Radware Linkproof | Yes | N/A | SNMP | SNMP | No | No | check_snmp_linkproof_nhr check_snmp_vrrp.pl |
| IronPort | Yes | SNMP | SNMP | SNMP | No | Yes | |
| Cisco CSS | Yes | ?? | Yes | Yes | No | ?? | check_snmp_css.pl |
snmp-env ¶
Check command object for the check_snmp_env.pl plugin.
| snmp_nocrypt | Optional. Define SNMP encryption. If set to false, snmp_v3 needs to be enabled. Defaults to true (no encryption). |
| snmp_port | Optional. The SNMP port connection. |
| snmp_v2 | Optional. SNMP version to 2c. Defaults to false. |
| snmp_v3 | Optional. SNMP version to 3. Defaults to false. |
| snmp_login | Optional. SNMP version 3 username. Defaults to “snmpuser”. |
| snmp_password | Required. SNMP version 3 password. No value defined as default. |
| snmp_v3_use_privpass | Optional. Define to use SNMP version 3 priv password. Defaults to false. |
| snmp_v3_use_authprotocol | Optional. Define to use SNMP version 3 authentication protocol. Defaults to false. |
| snmp_authprotocol | Optional. SNMP version 3 authentication protocol. Defaults to “md5,des”. |
| snmp_privpass | Required. SNMP version 3 priv password. No value defined as default. |
| snmp_env_type | Optional. Environment Type [cisco |
| snmp_env_fan | Optional. Minimum fan rpm value (only needed for ‘iron’ & ‘linux’) |
| snmp_env_celsius | Optional. Maximum temp in degrees celsius (only needed for ‘iron’ & ‘linux’) |
| snmp_perf | Optional. Enable perfdata values. Defaults to true. |
| snmp_timeout | Optional. The command timeout in seconds. Defaults to 5 seconds. |
snmp-load ¶
Check command object for the check_snmp_load.pl plugin.
| snmp_warn | Optional. The warning threshold. Change the snmp_load_type var to “netsl” for using 3 values. |
| snmp_crit | Optional. The critical threshold. Change the snmp_load_type var to “netsl” for using 3 values. |
| snmp_load_type | Optional. Load type. Defaults to “stand”. Check all available types in the snmp load documentation. |
snmp-memory ¶
Check command object for the check_snmp_mem.pl plugin.
| snmp_is_cisco | Optional. Change OIDs for Cisco switches. Defaults to false. |
| snmp_is_hp | Optional. Change OIDs for HP/Procurve switches. Defaults to false. |
| snmp_memcached | Optional. Include cached memory in used memory, Defaults to false. |
| snmp_membuffer | Optional. Exclude buffered memory in used memory, Defaults to false. |
snmp-storage ¶
Check command object for the check_snmp_storage.pl plugin.
| snmp_storage_name | Optional. Storage name. Default to regex “^/$$”. More options available in the snmp storage documentation. |
| snmp_storage_olength | Optional. Max-size of the SNMP message, usefull in case of Too Long responses. |
snmp-interface ¶
Check command object for the check_snmp_int.pl plugin.
| snmp_interface | Optional. Network interface name. Default to regex “eth0”. |
| snmp_interface_inverse | Optional. Inverse Interface check, down is ok. Defaults to false as it is missing. |
| snmp_interface_perf | Optional. Check the input/output bandwidth of the interface. Defaults to true. |
| snmp_interface_label | Optional. Add label before speed in output: in=, out=, errors-out=, etc. |
| snmp_interface_bits_bytes | Optional. Output performance data in bits/s or Bytes/s. Depends on snmp_interface_kbits set to true. Defaults to true. |
| snmp_interface_percent | Optional. Output performance data in % of max speed. Defaults to false. |
| snmp_interface_kbits | Optional. Make the warning and critical levels in KBits/s. Defaults to true. |
| snmp_interface_megabytes | Optional. Make the warning and critical levels in Mbps or MBps. Depends on snmp_interface_kbits set to true. Defaults to true. |
| snmp_interface_64bit | Optional. Use 64 bits counters instead of the standard counters when checking bandwidth & performance data for interface >= 1Gbps. Defaults to false. |
| snmp_interface_errors | Optional. Add error & discard to Perfparse output. Defaults to true. |
| snmp_interface_noregexp | Optional. Do not use regexp to match interface name in description OID. Defaults to false. |
| snmp_interface_delta | Optional. Delta time of perfcheck. Defaults to “300” (5 min). |
| snmp_interface_warncrit_percent | Optional. Make the warning and critical levels in % of reported interface speed. If set, snmp_interface_megabytes needs to be set to false. Defaults to false. |
| snmp_interface_ifname | Optional. Switch from IF-MIB::ifDescr to IF-MIB::ifName when looking up the interface’s name. |
| snmp_interface_ifalias | Optional. Switch from IF-MIB::ifDescr to IF-MIB::ifAlias when looking up the interface’s name. |
| snmp_interface_weathermap | Optional. Output data for “weathermap” lines in NagVis. Depends on snmp_interface_perf set to true. Defaults to false. Note: Available in check_snmp_int.pl v2.1.0. |
snmp-process ¶
Check command object for the check_snmp_process.pl plugin.
| snmp_privpass | Required. SNMP version 3 priv password. No value defined as default.. |
| snmp_process_name | Optional. Name of the process (regexp). No trailing slash!. Defaults to “.*”. |
| snmp_process_use_params | Optional. Add process parameters to process name for regexp matching. Example: “named.*-t /var/named/chroot” will only select named process with this parameter. Defaults to false. |
| snmp_process_mem_usage | Optional. Define to check memory usage for the process. Defaults to false. |
| snmp_process_mem_threshold | Optional. Defines the warning and critical thresholds in Mb when snmp_process_mem_usage set to true. Example “512,1024”. Defaults to “0,0”. |
| snmp_process_cpu_usage | Optional. Define to check CPU usage for the process. Defaults to false. |
| snmp_process_cpu_threshold | Optional. Defines the warning and critical thresholds in % when snmp_process_cpu_usage set to true. If more than one CPU, value can be > 100% : 100%=1 CPU. Example “15,50”. Defaults to “0,0”. |
snmp-service ¶
Check command object for the check_snmp_win.pl plugin.
| snmp_service_name | Optional. Comma separated names of services (perl regular expressions can be used for every one). By default, it is not case sensitive. eg. ^dns$. Defaults to “.*”. |
| snmp_service_count | Optional. Compare matching services with a specified number instead of the number of names provided. |
| snmp_service_showall | Optional. Show all services in the output, instead of only the non-active ones. Defaults to false. |
| snmp_service_noregexp | Optional. Do not use regexp to match NAME in service description. Defaults to false. |
Contributed Plugin Check Commands ¶
The contributed Plugin Check Commands provides various additional command definitions contributed by community members.
These check commands assume that the global constant named PluginContribDir
is set to the path where the user installs custom plugins and can be enabled by
uncommenting the corresponding line in icinga2.conf:
include <plugin-contrib>
This is enabled by default since Icinga 2 2.5.0.
Big Data ¶
This category contains plugins for various Big Data systems.
cloudera_service_status ¶
The cloudera_service_status plugin uses Cloudera Manager API to monitor cluster services
| cloudera_host | Required. Hostname of cloudera server. |
| cloudera_port | Optional. Port where cloudera is listening. Defaults to 443. |
| cloudera_user | Required. The username for the API connection. |
| cloudera_pass | Required. The password for the API connection. |
| cloudera_api_version | Required. API version of cloudera. |
| cloudera_cluster | Required. The cluster name in cloudera manager. |
| cloudera_service | Required. Name of cluster service to be checked. |
| cloudera_verify_ssl | Optional. Verify SSL. Defaults to true. |
Databases ¶
This category contains plugins for various database servers.
db2_health ¶
The check_db2_health plugin
uses the DBD::DB2 Perl library to monitor a DB2
database.
The Git repository is located on GitHub.
| db2_health_database | Required. The name of the database. (If it was catalogued locally, this parameter and db2_health_not_catalogued = false are the only you need. Otherwise you must specify database, hostname and port) |
| db2_health_username | Optional. The username for the database connection. |
| db2_health_password | Optional. The password for the database connection. |
| db2_health_port | Optional. The port where DB2 is listening. |
| db2_health_warning | Optional. The warning threshold depending on the mode. |
| db2_health_critical | Optional. The critical threshold depending on the mode. |
| db2_health_mode | Required. The mode uses predefined keywords for the different checks. For example “connection-time”, “database-usage” or “sql”. |
| db2_health_method | Optional. This tells the plugin how to connect to the database. The only method implemented yet is “dbi” which is the default. (It means, the plugin uses the perl module DBD::DB2). |
| db2_health_name | Optional. The tablespace, datafile, wait event, latch, enqueue depending on the mode or SQL statement to be executed with “db2_health_mode” sql. |
| db2_health_name2 | Optional. If “db2_health_name” is a sql statement, “db2_health_name2” can be used to appear in the output and the performance data. |
| db2_health_regexp | Optional. If set to true, “db2_health_name” will be interpreted as a regular expression. Defaults to false. |
| db2_health_units | Optional. This is used for a better output of mode=sql and for specifying thresholds for mode=tablespace-free. Possible values are “%”, “KB”, “MB” and “GB”. |
| db2_health_maxinactivity | Optional. Used for the maximum amount of time a certain event has not happened. |
| db2_health_mitigation | Optional. Classifies the severity of an offline tablespace. |
| db2_health_lookback | Optional. How many days in the past db2_health check should look back to calculate exitcode. |
| db2_health_report | Optional. Report can be used to output only the bad news. Possible values are “short”, “long”, “html”. Defaults to short. |
| db2_health_not_catalogued | Optional. Set this variable to false if you want to use a catalogued locally database. Defaults to true. |
| db2_health_env_db2_home | Required. Specifies the location of the db2 client libraries as environment variable DB2_HOME. Defaults to “/opt/ibm/db2/V10.5”. |
| db2_health_env_db2_version | Optional. Specifies the DB2 version as environment variable DB2_VERSION. |
mssql_health ¶
The check_mssql_health plugin
uses the DBD::Sybase Perl library based on FreeTDS to monitor a
MS SQL server.
| mssql_health_hostname | Optional. Specifies the database hostname or address. No default because you typically use “mssql_health_server”. |
| mssql_health_username | Optional. The username for the database connection. |
| mssql_health_password | Optional. The password for the database connection. |
| mssql_health_port | Optional. Specifies the database port. No default because you typically use “mssql_health_server”. |
| mssql_health_server | Optional. The name of a predefined connection (in freetds.conf). |
| mssql_health_currentdb | Optional. The name of a database which is used as the current database for the connection. |
| mssql_health_offlineok | Optional. Set this to true if offline databases are perfectly ok for you. Defaults to false. |
| mssql_health_nooffline | Optional. Set this to true to ignore offline databases. Defaults to false. |
| mssql_health_dbthresholds | Optional. With this parameter thresholds are read from the database table check_mssql_health_thresholds. |
| mssql_health_notemp | Optional. Set this to true to ignore temporary databases/tablespaces. Defaults to false. |
| mssql_health_commit | Optional. Set this to true to turn on autocommit for the dbd::sybase module. Defaults to false. |
| mssql_health_method | Optional. How the plugin should connect to the database (dbi for the perl module DBD::Sybase (default) and sqlrelay for the SQLRelay proxy). |
| mssql_health_mode | Required. The mode uses predefined keywords for the different checks. For example “connection-time”, “database-free” or “sql”. |
| mssql_health_regexp | Optional. If set to true, “mssql_health_name” will be interpreted as a regular expression. Defaults to false. |
| mssql_health_warning | Optional. The warning threshold depending on the mode. |
| mssql_health_critical | Optional. The critical threshold depending on the mode. |
| mssql_health_warningx | Optional. A possible override for the warning threshold. |
| mssql_health_criticalx | Optional. A possible override for the critical threshold. |
| mssql_health_units | Optional. This is used for a better output of mode=sql and for specifying thresholds for mode=tablespace-free. Possible values are “%”, “KB”, “MB” and “GB”. |
| mssql_health_name | Optional. Depending on the mode this could be the database name or a SQL statement. |
| mssql_health_name2 | Optional. If “mssql_health_name” is a sql statement, “mssql_health_name2” can be used to appear in the output and the performance data. |
| mssql_health_name3 | Optional. Additional argument used for ‘database-file-free’ mode for example. |
| mssql_health_extraopts | Optional. Read command line arguments from an external file. |
| mssql_health_blacklist | Optional. Blacklist some (missing/failed) components |
| mssql_health_mitigation | Optional. The parameter allows you to change a critical error to a warning. |
| mssql_health_lookback | Optional. The amount of time you want to look back when calculating average rates. |
| mssql_health_environment | Optional. Add a variable to the plugin’s environment. |
| mssql_health_negate | Optional. Emulate the negate plugin. –negate warning=critical –negate unknown=critical. |
| mssql_health_morphmessage | Optional. Modify the final output message. |
| mssql_health_morphperfdata | Optional. The parameter allows you to change performance data labels. |
| mssql_health_selectedperfdata | Optional. The parameter allows you to limit the list of performance data. |
| mssql_health_report | Optional. Report can be used to output only the bad news. Possible values are “short”, “long”, “html”. Defaults to short. |
| mssql_health_multiline | Optional. Multiline output. |
| mssql_health_withmymodulesdyndir | Optional. Add-on modules for the my-modes will be searched in this directory. |
| mssql_health_statefilesdir | Optional. An alternate directory where the plugin can save files. |
| mssql_health_isvalidtime | Optional. Signals the plugin to return OK if now is not a valid check time. |
| mssql_health_timeout | Optional. Plugin timeout. Defaults to 15s. |
mysql_health ¶
The check_mysql_health plugin
uses the DBD::MySQL Perl library to monitor a
MySQL or MariaDB database.
| mysql_health_hostname | Required. Specifies the database hostname or address. Defaults to “$address$” or “$address6$” if the address attribute is not set. |
| mysql_health_port | Optional. Specifies the database port. Defaults to 3306 (or 1186 for “mysql_health_mode” cluster). |
| mysql_health_socket | Optional. Specifies the database unix socket. No default. |
| mysql_health_username | Optional. The username for the database connection. |
| mysql_health_password | Optional. The password for the database connection. |
| mysql_health_database | Optional. The database to connect to. Defaults to information_schema. |
| mysql_health_warning | Optional. The warning threshold depending on the mode. |
| mysql_health_critical | Optional. The critical threshold depending on the mode. |
| mysql_health_warningx | Optional. The extended warning thresholds depending on the mode. |
| mysql_health_criticalx | Optional. The extended critical thresholds depending on the mode. |
| mysql_health_mode | Required. The mode uses predefined keywords for the different checks. For example “connection-time”, “slave-lag” or “sql”. |
| mysql_health_method | Optional. How the plugin should connect to the database (dbi for using DBD::Mysql (default), mysql for using the mysql-Tool). |
| mysql_health_commit | Optional. Turns on autocommit for the dbd::* module. |
| mysql_health_notemp | Optional. Ignore temporary databases/tablespaces. |
| mysql_health_nooffline | Optional. Skip the offline databases. |
| mysql_health_regexp | Optional. Parameter name/name2/name3 will be interpreted as (perl) regular expression. |
| mysql_health_name | Optional. The name of a specific component to check. |
| mysql_health_name2 | Optional. The secondary name of a component. |
| mysql_health_name3 | Optional. The tertiary name of a component. |
| mysql_health_units | Optional. This is used for a better output of mode=sql and for specifying thresholds for mode=tablespace-free. Possible values are “%”, “KB”, “MB” and “GB”. |
| mysql_health_labelformat | Optional. One of those formats pnp4nagios or groundwork. Defaults to pnp4nagios. |
| mysql_health_extraopts | Optional. Read command line arguments from an external file. |
| mysql_health_blacklist | Optional. Blacklist some (missing/failed) components |
| mysql_health_mitigation | Optional. The parameter allows you to change a critical error to a warning. |
| mysql_health_lookback | Optional. The amount of time you want to look back when calculating average rates. |
| mysql_health_environment | Optional. Add a variable to the plugin’s environment. |
| mysql_health_morphmessage | Optional. Modify the final output message. |
| mysql_health_morphperfdata | Optional. The parameter allows you to change performance data labels. |
| mysql_health_selectedperfdata | Optional. The parameter allows you to limit the list of performance data. |
| mysql_health_report | Optional. Can be used to shorten the output. |
| mysql_health_multiline | Optional. Multiline output. |
| mysql_health_negate | Optional. Emulate the negate plugin. –negate warning=critical –negate unknown=critical. |
| mysql_health_withmymodulesdyndir | Optional. Add-on modules for the my-modes will be searched in this directory. |
| mysql_health_statefilesdir | Optional. An alternate directory where the plugin can save files. |
| mysql_health_isvalidtime | Optional. Signals the plugin to return OK if now is not a valid check time. |
| mysql_health_timeout | Optional. Plugin timeout. Defaults to 60s. |
oracle_health ¶
The check_oracle_health plugin
uses the DBD::Oracle Perl library to monitor an Oracle database.
| oracle_health_connect | Required. Specifies the database connection string (from tnsnames.ora). |
| oracle_health_username | Optional. The username for the database connection. |
| oracle_health_password | Optional. The password for the database connection. |
| oracle_health_warning | Optional. The warning threshold depending on the mode. |
| oracle_health_critical | Optional. The critical threshold depending on the mode. |
| oracle_health_mode | Required. The mode uses predefined keywords for the different checks. For example “connection-time”, “flash-recovery-area-usage” or “sql”. |
| oracle_health_method | Optional. How the plugin should connect to the database (dbi for using DBD::Oracle (default), sqlplus for using the sqlplus-Tool). |
| oracle_health_name | Optional. The tablespace, datafile, wait event, latch, enqueue depending on the mode or SQL statement to be executed with “oracle_health_mode” sql. |
| oracle_health_name2 | Optional. If “oracle_health_name” is a sql statement, “oracle_health_name2” can be used to appear in the output and the performance data. |
| oracle_health_regexp | Optional. If set to true, “oracle_health_name” will be interpreted as a regular expression. Defaults to false. |
| oracle_health_units | Optional. This is used for a better output of mode=sql and for specifying thresholds for mode=tablespace-free. Possible values are “%”, “KB”, “MB” and “GB”. |
| oracle_health_ident | Optional. If set to true, outputs instance and database names. Defaults to false. |
| oracle_health_commit | Optional. Set this to true to turn on autocommit for the dbd::oracle module. Defaults to false. |
| oracle_health_noperfdata | Optional. Set this to true if you want to disable perfdata. Defaults to false. |
| oracle_health_timeout | Optional. Plugin timeout. Defaults to 60s. |
| oracle_health_report | Optional. Select the plugin output format. Can be short or long. Default to long. |
Environment Macros:
| ORACLE_HOME | Required. Specifies the location of the oracle instant client libraries. Defaults to “/usr/lib/oracle/11.2/client64/lib”. Can be overridden by setting the custom attribute oracle_home. |
| LD_LIBRARY_PATH | Required. Specifies the location of the oracle instant client libraries for the run-time shared library loader. Defaults to “/usr/lib/oracle/11.2/client64/lib”. Can be overridden by setting the custom attribute oracle_ld_library_path. |
| TNS_ADMIN | Required. Specifies the location of the tnsnames.ora including the database connection strings. Defaults to “/etc/icinga2/plugin-configs”. Can be overridden by setting the custom attribute oracle_tns_admin. |
postgres ¶
The check_postgres plugin
uses the psql binary to monitor a PostgreSQL database.
| postgres_host | Optional. Specifies the database hostname or address. Defaults to “$address$” or “$address6$” if the address attribute is not set. If “postgres_unixsocket” is set to true, falls back to unix socket. |
| postgres_port | Optional. Specifies the database port. Defaults to 5432. |
| postgres_dbname | Optional. Specifies the database name to connect to. Defaults to “postgres” or “template1”. |
| postgres_dbuser | Optional. The username for the database connection. Defaults to “postgres”. |
| postgres_dbpass | Optional. The password for the database connection. You can use a .pgpass file instead. |
| postgres_dbservice | Optional. Specifies the service name to use inside of pg_service.conf. |
| postgres_warning | Optional. Specifies the warning threshold, range depends on the action. |
| postgres_critical | Optional. Specifies the critical threshold, range depends on the action. |
| postgres_include | Optional. Specifies name(s) items to specifically include (e.g. tables), depends on the action. |
| postgres_exclude | Optional. Specifies name(s) items to specifically exclude (e.g. tables), depends on the action. |
| postgres_includeuser | Optional. Include objects owned by certain users. |
| postgres_excludeuser | Optional. Exclude objects owned by certain users. |
| postgres_standby | Optional. Assume that the server is in continuous WAL recovery mode if set to true. Defaults to false. |
| postgres_production | Optional. Assume that the server is in production mode if set to true. Defaults to false. |
| postgres_action | Required. Determines the test executed. |
| postgres_unixsocket | Optional. If “postgres_unixsocket” is set to true, the unix socket is used instead of an address. Defaults to false. |
| postgres_query | Optional. Query for “custom_query” action. |
| postgres_valtype | Optional. Value type of query result for “custom_query”. |
| postgres_reverse | Optional. If “postgres_reverse” is set, warning and critical values are reversed for “custom_query” action. |
| postgres_tempdir | Optional. Specify directory for temporary files. The default directory is dependent on the OS. More details here. |
mongodb ¶
The check_mongodb.py plugin
uses the pymongo Python library to monitor a MongoDB instance.
| mongodb_host | Required. Specifies the hostname or address. Defaults to “$address$” if the host’s address attribute is set, “$address6$” otherwise. |
| mongodb_port | Required. The port mongodb is running on. |
| mongodb_user | Optional. The username you want to login as. |
| mongodb_passwd | Optional. The password you want to use for that user. |
| mongodb_authdb | Optional. The database you want to authenticate against. |
| mongodb_warning | Optional. The warning threshold we want to set. |
| mongodb_critical | Optional. The critical threshold we want to set. |
| mongodb_action | Required. The action you want to take. |
| mongodb_maxlag | Optional. Get max replication lag (for replication_lag action only). |
| mongodb_mappedmemory | Optional. Get mapped memory instead of resident (if resident memory can not be read). |
| mongodb_perfdata | Optional. Enable output of Nagios performance data. |
| mongodb_database | Optional. Specify the database to check. |
| mongodb_alldatabases | Optional. Check all databases (action database_size). |
| mongodb_ssl | Optional. Connect using SSL. |
| mongodb_replicaset | Optional. Connect to replicaset. |
| mongodb_replcheck | Optional. If set to true, will enable the mongodb_replicaset value needed for “replica_primary” check. |
| mongodb_querytype | Optional. The query type to check [query|insert|update|delete|getmore|command] from queries_per_second. |
| mongodb_collection | Optional. Specify the collection to check. |
| mongodb_sampletime | Optional. Time used to sample number of pages faults. |
elasticsearch ¶
The check_elasticsearch plugin uses the HTTP API to monitor an Elasticsearch node.
| elasticsearch_host | Optional. Hostname or network address to probe. Defaults to “$address$” if the host’s address attribute is set, “$address6$” otherwise. |
| elasticsearch_failuredomain | Optional. A comma-separated list of ElasticSearch attributes that make up your cluster’s failure domain. |
| elasticsearch_masternodes | Optional. Issue a warning if the number of master-eligible nodes in the cluster drops below this number. By default, do not monitor the number of nodes in the cluster. |
| elasticsearch_port | Optional. TCP port to probe. The ElasticSearch API should be listening here. Defaults to 9200. |
| elasticsearch_prefix | Optional. Optional prefix (e.g. ‘es’) for the ElasticSearch API. Defaults to ‘’. |
| elasticsearch_yellowcritical | Optional. Instead of issuing a ‘warning’ for a yellow cluster state, issue a ‘critical’ alert. Defaults to false. |
redis ¶
The check_redis.pl plugin
uses the Redis Perl library to monitor a Redis instance. The plugin can
measure response time, hitrate, memory utilization, check replication synchronization, etc. It is
also possible to test data in a specified key and calculate averages or summaries on ranges.
| redis_hostname | Required. Hostname or IP Address to check. Defaults to “$address$” if the host’s address attribute is set, “$address6$” otherwise. |
| redis_port | Optional. Port number to query. Default to “6379”. |
| redis_database | Optional. Database name (usually a number) to query, needed for redis_query. |
| redis_password | Optional. Password for Redis authentication. Safer alternative is to put them in a file and use redis_credentials. |
| redis_credentials | Optional. Credentials file to read for Redis authentication. |
| redis_timeout | Optional. Allows to set timeout for execution of this plugin. |
| redis_variables | Optional. List of variables from info data to do threshold checks on. |
| redis_warn | Optional. This option can only be used if redis_variables is used and the number of values listed here must exactly match number of variables specified. |
| redis_crit | Optional. This option can only be used if redis_variables is used and the number of values listed here must exactly match number of variables specified. |
| redis_perfparse | Optional. This should only be used with variables and causes variable data not only to be printed as part of main status line but also as perfparse compatible output. Defaults to false. |
| redis_perfvars | Optional. This allows to list variables which values will go only into perfparse output (and not for threshold checking). |
| redis_prev_perfdata | Optional. If set to true, previous performance data are used to calculate rate of change for counter statistics variables and for proper calculation of hitrate. Defaults to false. |
| redis_rate_label | Optional. Prefix or Suffix label used to create a new variable which has rate of change of another base variable. You can specify PREFIX or SUFFIX or both as one string separated by “,”. Default if not specified is suffix “_rate”. |
| redis_query | Optional. Option specifies key to query and optional variable name to assign the results to after. |
| redis_option | Optional. Specifiers are separated by “,” and must include NAME or PATTERN. |
| redis_response_time | Optional. If this is used, plugin will measure and output connection response time in seconds. With redis_perfparse this would also be provided on perf variables. |
| redis_hitrate | Optional. Calculates Hitrate and specify values are interpreted as WARNING and CRITICAL thresholds. |
| redis_memory_utilization | Optional. This calculates percent of total memory on system used by redis. Total_memory on server must be specified with redis_total_memory. If you specify by itself, the plugin will just output this info. Parameter values are interpreted as WARNING and CRITICAL thresholds. |
| redis_total_memory | Optional. Amount of memory on a system for memory utilization calculation. Use system memory or max_memory setting of redis. |
| redis_replication_delay | Optional. Allows to set threshold on replication delay info. |
Hardware ¶
This category includes all plugin check commands for various hardware checks.
hpasm ¶
The check_hpasm plugin
monitors the hardware health of HP Proliant Servers, provided that the hpasm
(HP Advanced Server Management) software is installed. It is also able to monitor
the system health of HP Bladesystems and storage systems.
The plugin can run in two different ways:
- Local execution using the
hpasmclicommand line tool. - Remote SNMP query which invokes the HP Insight Tools on the remote node.
You can either set or omit hpasm_hostname custom attribute and select the corresponding node.
The hpasm_remote attribute enables the plugin to execute remote SNMP queries if set to true.
For compatibility reasons this attribute uses true as default value, and ensures that
specifying the hpasm_hostname always enables remote checks.
| hpasm_hostname | Optional. The host’s address. Defaults to “$address$” if the host’s address attribute is set, “$address6$” otherwise. |
| hpasm_community | Optional. SNMP community of the server (SNMP v1/2 only). |
| hpasm_protocol | Optional. The SNMP protocol to use (default: 2c, other possibilities: 1,3). |
| hpasm_port | Optional. The SNMP port to use (default: 161). |
| hpasm_blacklist | Optional. Blacklist some (missing/failed) components. |
| hpasm_ignore-dimms | Optional. Ignore “N/A”-DIMM status on misc. servers (e.g. older DL320). |
| hpasm_ignore-fan-redundancy | Optional. Ignore missing redundancy partners. |
| hpasm_customthresholds | Optional. Use custom thresholds for certain temperatures. |
| hpasm_eventrange | Optional. Period of time before critical IML events respectively become warnings or vanish. A range is described as a number and a unit (s, m, h, d), e.g. –eventrange 1h/20m. |
| hpasm_perfdata | Optional. Output performance data. If your performance data string becomes too long and is truncated by Nagios, then you can use –perfdata=short instead. This will output temperature tags without location information. |
| hpasm_username | Optional. The securityName for the USM security model (SNMPv3 only). |
| hpasm_authpassword | Optional. The authentication password for SNMPv3. |
| hpasm_authprotocol | Optional. The authentication protocol for SNMPv3 (md5|sha). |
| hpasm_privpassword | Optional. The password for authPriv security level. |
| hpasm_privprotocol | Optional. The private protocol for SNMPv3 (des|aes|aes128|3des|3desde). |
| hpasm_servertype | Optional. The type of the server: proliant (default) or bladesystem. |
| hpasm_eval-nics | Optional. Check network interfaces (and groups). Try it and report me whyt you think about it. I need to build up some know how on this subject. If you get an error and think, it is not justified for your configuration, please tell me about it. (always send the output of “snmpwalk -On .... 1.3.6.1.4.1.232” and a description how you setup your nics and why it is correct opposed to the plugins error message. |
| hpasm_remote | Optional. Run remote SNMP checks if enabled. Otherwise checks are executed locally using the hpasmcli binary. Defaults to true. |
openmanage ¶
The check_openmanage plugin checks the hardware health of Dell PowerEdge (and some PowerVault) servers. It uses the Dell OpenManage Server Administrator (OMSA) software, which must be running on the monitored system. check_openmanage can be used remotely with SNMP or locally with icinga2 agent, check_by_ssh or similar, whichever suits your needs and particular taste.
The plugin checks the health of the storage subsystem, power supplies, memory modules, temperature probes etc., and gives an alert if any of the components are faulty or operate outside normal parameters.
| openmanage_all | Optional. Check everything, even log content |
| openmanage_blacklist | Optional. Blacklist missing and/or failed components |
| openmanage_check | Optional. Fine-tune which components are checked |
| openmanage_community | Optional. SNMP community string [default=public] |
| openmanage_config | Optional. Specify configuration file |
| openmanage_critical | Optional. Custom temperature critical limits |
| openmanage_extinfo | Optional. Append system info to alerts |
| openmanage_fahrenheit | Optional. Use Fahrenheit as temperature unit |
| openmanage_hostname | Optional. Hostname or IP (required for SNMP) |
| openmanage_htmlinfo | Optional. HTML output with clickable links |
| openmanage_info | Optional. Prefix any alerts with the service tag |
| openmanage_ipv6 | Optional. Use IPv6 instead of IPv4 [default=no] |
| openmanage_legacy_perfdata | Optional. Legacy performance data output |
| openmanage_no_storage | Optional. Don’t check storage |
| openmanage_only | Optional. Only check a certain component or alert type |
| openmanage_perfdata | Optional. Output performance data [default=no] |
| openmanage_port | Optional. SNMP port number [default=161] |
| openmanage_protocol | Optional. SNMP protocol version [default=2c] |
| openmanage_short_state | Optional. Prefix alerts with alert state abbreviated |
| openmanage_show_blacklist | Optional. Show blacklistings in OK output |
| openmanage_state | Optional. Prefix alerts with alert state |
| openmanage_tcp | Optional. Use TCP instead of UDP [default=no] |
| openmanage_timeout | Optional. Plugin timeout in seconds [default=30] |
| openmanage_vdisk_critical | Optional. Make any alerts on virtual disks critical |
| openmanage_warning | Optional. Custom temperature warning limits |
adaptec-raid ¶
The check_adaptec_raid plugin
uses the arcconf binary to monitor Adaptec RAID controllers.
| adaptec_controller_number | Required. Controller number to monitor. |
| arcconf_path | Required. Path to the arcconf binary, e.g. “/sbin/arcconf”. |
lsi-raid ¶
The check_lsi_raid plugin
uses the storcli binary to monitor MegaRAID RAID controllers.
| lsi_controller_number | Optional. Controller number to monitor. |
| storcli_path | Optional. Path to the storcli binary, e.g. “/usr/sbin/storcli”. |
| lsi_enclosure_id | Optional. Enclosure numbers to be checked, comma-separated. |
| lsi_ld_id | Optional. Logical devices to be checked, comma-separated. |
| lsi_pd_id | Optional. Physical devices to be checked, comma-separated. |
| lsi_temp_warning | Optional. RAID controller warning temperature. |
| lsi_temp_critical | Optional. RAID controller critical temperature. |
| lsi_pd_temp_warning | Optional. Disk warning temperature. |
| lsi_pd_temp_critical | Optional. Disk critical temperature. |
| lsi_bbu_temp_warning | Optional. Battery warning temperature. |
| lsi_bbu_temp_critical | Optional. Battery critical temperature. |
| lsi_cv_temp_warning | Optional. CacheVault warning temperature. |
| lsi_cv_temp_critical | Optional. CacheVault critical temperature. |
| lsi_ignored_media_errors | Optional. Warning threshold for media errors. |
| lsi_ignored_other_errors | Optional. Warning threshold for other errors. |
| lsi_ignored_predictive_fails | Optional. Warning threshold for predictive failures. |
| lsi_ignored_shield_counters | Optional. Warning threshold for shield counter. |
| lsi_ignored_bbm_counters | Optional. Warning threshold for BBM counter. |
| lsi_bbu | Optional. Define if BBU is present and it’s state should be checked. |
| lsi_noenclosures | Optional. If set to true, does not check enclosures. |
| lsi_nosudo | Optional. If set to true, does not use sudo when running storcli. |
| lsi_nocleanlogs | Optional. If set to true, does not clean up the log files after executing storcli checks. |
smart-attributes ¶
The check_smart_attributes plugin
uses the smartctl binary to monitor SMART values of SSDs and HDDs.
| smart_attributes_config_path | Required. Path to the smart attributes config file (e.g. check_smartdb.json). |
| smart_attributes_device | Required. Device name (e.g. /dev/sda) to monitor. |
IcingaCLI ¶
This category includes all plugins using the icingacli provided by Icinga Web 2.
The user running Icinga 2 needs sufficient permissions to read the Icinga Web 2 configuration directory. e.g. usermod -a -G icingaweb2 icinga. You need to restart, not reload Icinga 2 for the new group membership to work.
Business Process ¶
This subcommand is provided by the business process module
and executed as icingacli businessprocess CLI command.
| icingacli_businessprocess_process | Required. Business process to monitor. |
| icingacli_businessprocess_config | Optional. Configuration file containing your business process without file extension. |
| icingacli_businessprocess_details | Optional. Get details for root cause analysis. Defaults to false. |
| icingacli_businessprocess_statetype | Optional. Define which state type to look at, soft or hard. Overrides the default value inside the businessprocess module, if configured. |
Director ¶
This subcommand is provided by the director module > 1.4.2 and executed as icingacli director health check. Please refer to the documentation for all available sub-checks.
| icingacli_director_check | Optional. Run only a specific test suite. |
| icingacli_director_db | Optional. Use a specific Icinga Web DB resource. |
IPMI Devices ¶
This category includes all plugins for IPMI devices.
ipmi-sensor ¶
The check_ipmi_sensor plugin
uses the ipmimonitoring binary to monitor sensor data for IPMI devices. Please
read the documentation
for installation and configuration details.
| ipmi_address | Required. Specifies the remote host (IPMI device) to check. Defaults to “$address$”. |
| ipmi_config_file | Optional. Path to the FreeIPMI configuration file. It should contain IPMI username, IPMI password, and IPMI privilege-level. |
| ipmi_username | Optional. The IPMI username. |
| ipmi_password | Optional. The IPMI password. |
| ipmi_privilege_level | Optional. The IPMI privilege level of the IPMI user. |
| ipmi_backward_compatibility_mode | Optional. Enable backward compatibility mode, useful for FreeIPMI 0.5.* (this omits FreeIPMI options “–quiet-cache” and “–sdr-cache-recreate”). |
| ipmi_sensor_type | Optional. Limit sensors to query based on IPMI sensor type. Examples for IPMI sensor types are ‘Fan’, ‘Temperature’ and ‘Voltage’. |
| ipmi_sel_type | Optional. Limit SEL entries to specific types, run ‘ipmi-sel -L’ for a list of types. All sensors are populated to the SEL and per default all sensor types are monitored. |
| ipmi_exclude_sensor_id | Optional. Exclude sensor matching ipmi_sensor_id. |
| ipmi_exclude_sensor | Optional. Exclude sensor based on IPMI sensor type. (Comma-separated) |
| ipmi_exclude_sel | Optional. Exclude SEL entries of specific sensor types. (comma-separated list). |
| ipmi_sensor_id | Optional. Include sensor matching ipmi_sensor_id. |
| ipmi_protocol_lan_version | Optional. Change the protocol LAN version. Defaults to “LAN_2_0”. |
| ipmi_number_of_active_fans | Optional. Number of fans that should be active. Otherwise a WARNING state is returned. |
| ipmi_show_fru | Optional. Print the product serial number if it is available in the IPMI FRU data. |
| ipmi_no_sel_checking | Optional. Turn off system event log checking via ipmi-sel. |
| ipmi_no_thresholds | Optional. Turn off performance data thresholds from output-sensor-thresholds. |
| ipmi_verbose | Optional. Be Verbose multi line output, also with additional details for warnings. |
| ipmi_debug | Optional. Be Verbose debugging output, followed by normal multi line output. |
ipmi-alive ¶
The ipmi-alive check commands allows you to create a ping check for the IPMI Interface.
Custom attributes passed as command parameters:
| Name | Description |
| ping_address | Optional. The address of the IPMI interface. Defaults to “$address$” if the IPMI interface’s address attribute is set, “$address6$” otherwise. |
| ping_wrta | Optional. The RTA warning threshold in milliseconds. Defaults to 5000. |
| ping_wpl | Optional. The packet loss warning threshold in %. Defaults to 100. |
| ping_crta | Optional. The RTA critical threshold in milliseconds. Defaults to 5000. |
| ping_cpl | Optional. The packet loss critical threshold in %. Defaults to 100. |
| ping_packets | Optional. The number of packets to send. Defaults to 1. |
| ping_timeout | Optional. The plugin timeout in seconds. Defaults to 0 (no timeout). |
Log Management ¶
This category includes all plugins for log management, for example Logstash.
logstash ¶
The logstash plugin connects to the Node API of Logstash. This plugin requires at least Logstash version 5.0.x.
The Node API is not activated by default. You have to configure your Logstash installation in order to allow plugin connections.
| logstash_hostname | Optional. Hostname where Logstash is running. Defaults to check_address |
| logstash_port | Optional. Port where Logstash is listening for API requests. Defaults to 9600 |
| logstash_filedesc_warn | Optional. Warning threshold of file descriptor usage in percent. Defaults to 85 (percent). |
| logstash_filedesc_crit | Optional. Critical threshold of file descriptor usage in percent. Defaults to 95 (percent). |
| logstash_heap_warn | Optional. Warning threshold of heap usage in percent. Defaults to 70 (percent). |
| logstash_heap_crit | Optional. Critical threshold of heap usage in percent Defaults to 80 (percent). |
| logstash_inflight_warn | Optional. Warning threshold of inflight events. |
| logstash_inflight_crit | Optional. Critical threshold of inflight events. |
| logstash_cpu_warn | Optional. Warning threshold for cpu usage in percent. |
| logstash_cpu_crit | Optional. Critical threshold for cpu usage in percent. |
Metrics ¶
This category includes all plugins for metric-based checks.
graphite ¶
The check_graphite plugin
uses the rest-client Ruby library to monitor a Graphite instance.
| graphite_url | Required. Target url. |
| graphite_metric | Required. Metric path string. |
| graphite_shortname | Optional. Metric short name (used for performance data). |
| graphite_duration | Optional. Length, in minute of data to parse (default: 5). |
| graphite_function | Optional. Function applied to metrics for thresholds (default: average). |
| graphite_warning | Required. Warning threshold. |
| graphite_critical | Required. Critical threshold. |
| graphite_units | Optional. Adds a text tag to the metric count in the plugin output. Useful to identify the metric units. Doesn’t affect data queries. |
| graphite_message | Optional. Text message to output (default: “metric count:”). |
| graphite_zero_on_error | Optional. Return 0 on a graphite 500 error. |
| graphite_link_graph | Optional. Add a link in the plugin output, showing a 24h graph for this metric in graphite. |
Network Components ¶
This category includes all plugins for various network components like routers, switches and firewalls.
interfacetable ¶
The check_interfacetable_v3t plugin generates a html page containing information about the monitored node and all of its interfaces.
| interfacetable_hostquery | Required. Specifies the remote host to poll. Defaults to “$address$”. |
| interfacetable_hostdisplay | Optional. Specifies the hostname to display in the HTML link. Defaults to “$host.display_name$”. |
| interfacetable_regex | Optional. Interface names and property names for some other options will be interpreted as regular expressions. Defaults to false. |
| interfacetable_outputshort | Optional. Reduce the verbosity of the plugin output. Defaults to false. |
| interfacetable_exclude | Optional. Comma separated list of interfaces globally excluded from the monitoring. |
| interfacetable_include | Optional. Comma separated list of interfaces globally included in the monitoring. |
| interfacetable_aliasmatching | Optional. Allow you to specify alias in addition to interface names. Defaults to false. |
| interfacetable_excludetraffic | Optional. Comma separated list of interfaces excluded from traffic checks. |
| interfacetable_includetraffic | Optional. Comma separated list of interfaces included for traffic checks. |
| interfacetable_warningtraffic | Optional. Interface traffic load percentage leading to a warning alert. |
| interfacetable_criticaltraffic | Optional. Interface traffic load percentage leading to a critical alert. |
| interfacetable_pkt | Optional. Add unicast/non-unicast pkt stats for each interface. |
| interfacetable_trafficwithpkt | Optional. Enable traffic calculation using pkt counters instead of octet counters. Useful when using 32-bit counters to track the load on > 1GbE interfaces. Defaults to false. |
| interfacetable_trackproperty | Optional. List of tracked properties. |
| interfacetable_excludeproperty | Optional. Comma separated list of interfaces excluded from the property tracking. |
| interfacetable_includeproperty | Optional. Comma separated list of interfaces included in the property tracking. |
| interfacetable_community | Optional. Specifies the snmp v1/v2c community string. Defaults to “public” if using snmp v1/v2c, ignored using v3. |
| interfacetable_snmpv2 | Optional. Use snmp v2c. Defaults to false. |
| interfacetable_login | Optional. Login for snmpv3 authentication. |
| interfacetable_passwd | Optional. Auth password for snmpv3 authentication. |
| interfacetable_privpass | Optional. Priv password for snmpv3 authentication. |
| interfacetable_protocols | Optional. Authentication protocol,Priv protocol for snmpv3 authentication. |
| interfacetable_domain | Optional. SNMP transport domain. |
| interfacetable_contextname | Optional. Context name for the snmp requests. |
| interfacetable_port | Optional. SNMP port. Defaults to standard port. |
| interfacetable_64bits | Optional. Use SNMP 64-bits counters. Defaults to false. |
| interfacetable_maxrepetitions | Optional. Increasing this value may enhance snmp query performances by gathering more results at one time. |
| interfacetable_snmptimeout | Optional. Define the Transport Layer timeout for the snmp queries. |
| interfacetable_snmpretries | Optional. Define the number of times to retry sending a SNMP message. |
| interfacetable_snmpmaxmsgsize | Optional. Size of the SNMP message in octets, useful in case of too long responses. Be careful with network filters. Range 484 - 65535. Apply only to netsnmp perl bindings. The default is 1472 octets for UDP/IPv4, 1452 octets for UDP/IPv6, 1460 octets for TCP/IPv4, and 1440 octets for TCP/IPv6. |
| interfacetable_unixsnmp | Optional. Use unix snmp utilities for snmp requests. Defaults to false, which means use the perl bindings. |
| interfacetable_enableperfdata | Optional. Enable port performance data. Defaults to false. |
| interfacetable_perfdataformat | Optional. Define which performance data will be generated. Possible values are “full” (default), “loadonly”, “globalonly”. |
| interfacetable_perfdatathreshold | Optional. Define which thresholds are printed in the generated performance data. Possible values are “full” (default), “loadonly”, “globalonly”. |
| interfacetable_perfdatadir | Optional. When specified, the performance data are also written directly to a file, in the specified location. |
| interfacetable_perfdataservicedesc | Optional. Specify additional parameters for output performance data to PNP. Defaults to “$service.name$”, only affects interfacetable_perfdatadir. |
| interfacetable_grapher | Optional. Specify the used graphing solution. Possible values are “pnp4nagios” (default), “nagiosgrapher”, “netwaysgrapherv2” and “ingraph”. |
| interfacetable_grapherurl | Optional. Graphing system url. Default depends on interfacetable_grapher. |
| interfacetable_portperfunit | Optional. Traffic could be reported in bits (counters) or in bps (calculated value). |
| interfacetable_nodetype | Optional. Specify the node type, for specific information to be printed / specific oids to be used. Possible values: “standard” (default), “cisco”, “hp”, “netscreen”, “netapp”, “bigip”, “bluecoat”, “brocade”, “brocade-nos”, “nortel”, “hpux”. |
| interfacetable_duplex | Optional. Add the duplex mode property for each interface in the interface table. Defaults to false. |
| interfacetable_stp | Optional. Add the stp state property for each interface in the interface table. Defaults to false. |
| interfacetable_vlan | Optional. Add the vlan attribution property for each interface in the interface table. Defaults to false. This option is available only for the following nodetypes: “cisco”, “hp”, “nortel” |
| interfacetable_noipinfo | Optional. Remove the ip information for each interface from the interface table. Defaults to false. |
| interfacetable_alias | Optional. Add the alias information for each interface in the interface table. Defaults to false. |
| interfacetable_accessmethod | Optional. Access method for a shortcut to the host in the HTML page. Format is : |
| interfacetable_htmltablelinktarget | Optional. Specifies the windows or the frame where the [details] link will load the generated html page. Possible values are: “_blank”, “_self” (default), “_parent”, “_top”, or a frame name. |
| interfacetable_delta | Optional. Set the delta used for interface throughput calculation in seconds. |
| interfacetable_ifs | Optional. Input field separator. Defaults to “,”. |
| interfacetable_cache | Optional. Define the retention time of the cached data in seconds. |
| interfacetable_noifloadgradient | Optional. Disable color gradient from green over yellow to red for the load percentage. Defaults to false. |
| interfacetable_nohuman | Optional. Do not translate bandwidth usage in human readable format. Defaults to false. |
| interfacetable_snapshot | Optional. Force the plugin to run like if it was the first launch. Defaults to false. |
| interfacetable_timeout | Optional. Define the global timeout limit of the plugin in seconds. Defaults to “15s”. |
| interfacetable_css | Optional. Define the css stylesheet used by the generated html files. Possible values are “classic”, “icinga” or “icinga-alternate1”. |
| interfacetable_config | Optional. Specify a config file to load. |
| interfacetable_noconfigtable | Optional. Disable configuration table on the generated HTML page. Defaults to false. |
| interfacetable_notips | Optional. Disable the tips in the generated html tables. Defaults to false. |
| interfacetable_defaulttablesorting | Optional. Default table sorting can be “index” (default) or “name”. |
| interfacetable_tablesplit | Optional. Generate multiple interface tables, one per interface type. Defaults to false. |
| interfacetable_notype | Optional. Remove the interface type for each interface. Defaults to false. |
iftraffic ¶
The check_iftraffic plugin checks the utilization of a given interface name using the SNMP protocol.
| iftraffic_address | Required. Specifies the remote host. Defaults to “$address$”. |
| iftraffic_community | Optional. SNMP community. Defaults to “public’” if omitted. |
| iftraffic_interface | Required. Queried interface name. |
| iftraffic_bandwidth | Required. Interface maximum speed in kilo/mega/giga/bits per second. |
| iftraffic_units | Optional. Interface units can be one of these values: g (gigabits/s),m (megabits/s), k (kilobits/s),b (bits/s) |
| iftraffic_warn | Optional. Percent of bandwidth usage necessary to result in warning status (defaults to 85). |
| iftraffic_crit | Optional. Percent of bandwidth usage necessary to result in critical status (defaults to 98). |
| iftraffic_max_counter | Optional. Maximum counter value of net devices in kilo/mega/giga/bytes. |
iftraffic64 ¶
The check_iftraffic64 plugin checks the utilization of a given interface name using the SNMP protocol.
| iftraffic64_address | Required. Specifies the remote host. Defaults to “$address$”. |
| iftraffic64_community | Optional. SNMP community. Defaults to “public’” if omitted. |
| iftraffic64_interface | Required. Queried interface name. |
| iftraffic64_bandwidth | Required. Interface maximum speed in kilo/mega/giga/bits per second. |
| iftraffic64_units | Optional. Interface units can be one of these values: g (gigabits/s),m (megabits/s), k (kilobits/s),b (bits/s) |
| iftraffic64_warn | Optional. Percent of bandwidth usage necessary to result in warning status (defaults to 85). |
| iftraffic64_crit | Optional. Percent of bandwidth usage necessary to result in critical status (defaults to 98). |
| iftraffic64_max_counter | Optional. Maximum counter value of net devices in kilo/mega/giga/bytes. |
interfaces ¶
The check_interfaces plugin uses SNMP to monitor network interfaces and their utilization.
| interfaces_address | Optional. The host’s address. Defaults to “$address$” if the host’s address attribute is set, “$address6$” otherwise. |
| interfaces_regex | Optional. Interface list regexp. |
| interfaces_exclude_regex | Optional. Interface list negative regexp. |
| interfaces_errors | Optional. Number of in errors (CRC errors for cisco) to consider a warning (default 50). |
| interface_out_errors | Optional. Number of out errors (collisions for cisco) to consider a warning (default same as in errors). |
| interfaces_perfdata | Optional. perfdata from last check result. |
| interfaces_prefix | Optional. Prefix interface names with this label. |
| interfaces_lastcheck | Optional. Last checktime (unixtime). |
| interfaces_bandwidth | Optional. Bandwidth warn level in percent. |
| interfaces_speed | Optional. Override speed detection with this value (bits per sec). |
| interfaces_trim | Optional. Cut this number of characters from the start of interface descriptions. |
| interfaces_mode | Optional. Special operating mode (default,cisco,nonbulk,bintec). |
| interfaces_auth_proto | Optional. SNMPv3 Auth Protocol (SHA|MD5) |
| interfaces_auth_phrase | Optional. SNMPv3 Auth Phrase |
| interfaces_priv_proto | Optional. SNMPv3 Privacy Protocol (AES|DES) |
| interfaces_priv_phrase | Optional. SNMPv3 Privacy Phrase |
| interfaces_user | Optional. SNMPv3 User |
| interfaces_down_is_ok | Optional. Disables critical alerts for down interfaces. |
| interfaces_aliases | Optional. Retrieves the interface description. |
| interfaces_match_aliases | Optional. Also match against aliases (Option –aliases automatically enabled). |
| interfaces_timeout | Optional. Sets the SNMP timeout (in ms). |
| interfaces_sleep | Optional. Sleep between every SNMP query (in ms). |
| interfaces_names | Optional. If set to true, use ifName instead of ifDescr. |
nwc_health ¶
The check_nwc_health plugin uses SNMP to monitor network components. The plugin is able to generate interface statistics, check hardware (CPU, memory, fan, power, etc.), monitor firewall policies, HRSP, load-balancer pools, processor and memory usage.
Currently the following network components are supported: Cisco IOS, Cisco Nexus, Cisco ASA, Cisco PIX, F5 BIG-IP, CheckPoint Firewall1, Juniper NetScreen, HP Procurve, Nortel, Brocade 4100/4900, EMC DS 4700, EMC DS 24, Allied Telesyn. Blue Coat SG600, Cisco Wireless Lan Controller 5500, Brocade ICX6610-24-HPOE, Cisco UC Telefonzeugs, FOUNDRY-SN-AGENT-MIB, FRITZ!BOX 7390, FRITZ!DECT 200, Juniper IVE, Pulse-Gateway MAG4610, Cisco IronPort AsyncOS, Foundry, etc. A complete list can be found in the plugin documentation.
| nwc_health_hostname | Optional. The host’s address. Defaults to “$address$” if the host’s address attribute is set, “$address6$” otherwise. |
| nwc_health_mode | Optional. The plugin mode. A list of all available modes can be found in the plugin documentation. |
| nwc_health_timeout | Optional. Seconds before plugin times out (default: 15) |
| nwc_health_blacklist | Optional. Blacklist some (missing/failed) components. |
| nwc_health_port | Optional. The SNMP port to use (default: 161). |
| nwc_health_domain | Optional. The transport domain to use (default: udp/ipv4, other possible values: udp6, udp/ipv6, tcp, tcp4, tcp/ipv4, tcp6, tcp/ipv6). |
| nwc_health_protocol | Optional. The SNMP protocol to use (default: 2c, other possibilities: 1,3). |
| nwc_health_community | Optional. SNMP community of the server (SNMP v1/2 only). |
| nwc_health_username | Optional. The securityName for the USM security model (SNMPv3 only). |
| nwc_health_authpassword | Optional. The authentication password for SNMPv3. |
| nwc_health_authprotocol | Optional. The authentication protocol for SNMPv3 (md5|sha). |
| nwc_health_privpassword | Optional. The password for authPriv security level. |
| nwc_health_privprotocol | Optional. The private protocol for SNMPv3 (des|aes|aes128|3des|3desde). |
| nwc_health_contextengineid | Optional. The context engine id for SNMPv3 (10 to 64 hex characters). |
| nwc_health_contextname | Optional. The context name for SNMPv3 (empty represents the default context). |
| nwc_health_name | Optional. The name of an interface (ifDescr). |
| nwc_health_drecksptkdb | Optional. This parameter must be used instead of –name, because Devel::ptkdb is stealing the latter from the command line. |
| nwc_health_alias | Optional. The alias name of a 64bit-interface (ifAlias) |
| nwc_health_regexp | Optional. A flag indicating that –name is a regular expression |
| nwc_health_ifspeedin | Optional. Override the ifspeed oid of an interface (only inbound) |
| nwc_health_ifspeedout | Optional. Override the ifspeed oid of an interface (only outbound) |
| nwc_health_ifspeed | Optional. Override the ifspeed oid of an interface |
| nwc_health_units | Optional. One of %, B, KB, MB, GB, Bit, KBi, MBi, GBi. (used for e.g. mode interface-usage) |
| nwc_health_name2 | Optional. The secondary name of a component. |
| nwc_health_role | Optional. The role of this device in a hsrp group (active/standby/listen). |
| nwc_health_report | Optional. Can be used to shorten the output. Possible values are: ‘long’ (default), ‘short’ (to shorten if available), or ‘html’ (to produce some html outputs if available) |
| nwc_health_lookback | Optional. The amount of time you want to look back when calculating average rates. Use it for mode interface-errors or interface-usage. Without –lookback the time between two runs of check_nwc_health is the base for calculations. If you want your checkresult to be based for example on the past hour, use –lookback 3600. |
| nwc_health_warning | Optional. The warning threshold |
| nwc_health_critical | Optional. The critical threshold |
| nwc_health_warningx | Optional. The extended warning thresholds |
| nwc_health_criticalx | Optional. The extended critical thresholds |
| nwc_health_mitigation | Optional. The parameter allows you to change a critical error to a warning (1) or ok (0). |
| nwc_health_selectedperfdata | Optional. The parameter allows you to limit the list of performance data. It’s a perl regexp. Only matching perfdata show up in the output. |
| nwc_health_morphperfdata | Optional. The parameter allows you to change performance data labels. It’s a perl regexp and a substitution. –morphperfdata ‘(.)ISATAP(.)’=’$1patasi$2’ |
| nwc_health_negate | Optional. The parameter allows you to map exit levels, such as warning=critical. |
| nwc_health_mymodules-dyn-dir | Optional. A directory where own extensions can be found. |
| nwc_health_servertype | Optional. The type of the network device: cisco (default). Use it if auto-detection is not possible. |
| nwc_health_statefilesdir | Optional. An alternate directory where the plugin can save files. |
| nwc_health_oids | Optional. A list of oids which are downloaded and written to a cache file. Use it together with –mode oidcache. |
| nwc_health_offline | Optional. The maximum number of seconds since the last update of cache file before it is considered too old. |
| nwc_health_multiline | Optional. Multiline output |
Operating System ¶
This category contains plugins which receive details about your operating system or the guest system.
mem ¶
The check_mem.pl plugin checks the memory usage on linux and unix hosts. It is able to count cache memory as free when compared to thresholds. More details can be found on this blog entry.
| mem_used | Optional. Tell the plugin to check for used memory in opposite of mem_free. Must specify one of these as true. |
| mem_free | Optional. Tell the plugin to check for free memory in opposite of mem_used. Must specify one of these as true. |
| mem_cache | Optional. If set to true, plugin will count cache as free memory. Defaults to false. |
| mem_warning | Required. Specify the warning threshold as number interpreted as percent. |
| mem_critical | Required. Specify the critical threshold as number interpreted as percent. |
running_kernel ¶
The check_running_kernel plugin
is provided by the nagios-plugin-contrib package on Debian/Ubuntu.
Custom attributes:
| running_kernel_use_sudo | Whether to run the plugin with sudo. Defaults to false except on Ubuntu where it defaults to true. |
iostats ¶
The check_iostats plugin
uses the iostat binary to monitor I/O on a Linux host. The default thresholds are rather high
so you can use a grapher for baselining before setting your own.
| iostats_disk | Required. The device to monitor without path. e.g. sda or vda. (default: sda). |
| iostats_warning_tps | Required. Warning threshold for tps (default: 3000). |
| iostats_warning_read | Required. Warning threshold for KB/s reads (default: 50000). |
| iostats_warning_write | Required. Warning threshold for KB/s writes (default: 10000). |
| iostats_warning_wait | Required. Warning threshold for % iowait (default: 50). |
| iostats_critical_tps | Required. Critical threshold for tps (default: 5000). |
| iostats_critical_read | Required. Critical threshold for KB/s reads (default: 80000). |
| iostats_critical_write | Required. Critical threshold for KB/s writes (default: 25000). |
| iostats_critical_wait | Required. Critical threshold for % iowait (default: 80). |
iostat ¶
The check_iostat plugin
uses the iostat binary to monitor disk I/O on a Linux host. The default thresholds are rather high
| iostat_disk | Required. The device to monitor without path. e.g. sda or vda. (default: sda). |
| iostat_wtps | Required. Warning threshold for tps (default: 100). |
| iostat_wread | Required. Warning threshold for KB/s reads (default: 100). |
| iostat_wwrite | Required. Warning threshold for KB/s writes (default: 100). |
| iostat_ctps | Required. Critical threshold for tps (default: 200). |
| iostat_cread | Required. Critical threshold for KB/s reads (default: 200). |
| iostat_cwrite | Required. Critical threshold for KB/s writes (default: 200). |
yum ¶
The check_yum plugin checks the YUM package
management system for package updates.
The plugin requires the yum-plugin-security package to differentiate between security and normal updates.
| yum_all_updates | Optional. Set to true to not distinguish between security and non-security updates, but returns critical for any available update. This may be used if the YUM security plugin is absent or you want to maintain every single package at the latest version. You may want to use yum_warn_on_any_update instead of this option. Defaults to false. |
| yum_warn_on_any_update | Optional. Set to true to warn if there are any (non-security) package updates available. Defaults to false. |
| yum_cache_only | Optional. If set to true, plugin runs entirely from cache and does not update the cache when running YUM. Useful if you have yum makecache cronned. Defaults to false. |
| yum_no_warn_on_lock | Optional. If set to true, returns OK instead of WARNING when YUM is locked and fails to check for updates due to another instance running. Defaults to false. |
| yum_no_warn_on_updates | Optional. If set to true, returns OK instead of WARNING even when updates are available. The plugin output still shows the number of available updates. Defaults to false. |
| yum_enablerepo | Optional. Explicitly enables a repository when calling YUM. Can take a comma separated list of repositories. Note that enabling repositories can lead to unexpected results, for example when protected repositories are enabled. |
| yum_disablerepo | Optional. Explicitly disables a repository when calling YUM. Can take a comma separated list of repositories. Note that enabling repositories can lead to unexpected results, for example when protected repositories are enabled. |
| yum_installroot | Optional. Specifies another installation root directory (for example a chroot). |
| yum_timeout | Optional. Set a timeout in seconds after which the plugin will exit (defaults to 55 seconds). |
Storage ¶
This category includes all plugins for various storage and object storage technologies.
glusterfs ¶
The glusterfs plugin
is used to check the GlusterFS storage health on the server.
The plugin requires sudo permissions.
| glusterfs_perfdata | Optional. Print perfdata of all or the specified volume. |
| glusterfs_warnonfailedheal | Optional. Warn if the heal-failed log contains entries. The log can be cleared by restarting glusterd. |
| glusterfs_volume | Optional. Only check the specified VOLUME. If –volume is not set, all volumes are checked. |
| glusterfs_disk_warning | Optional. Warn if disk usage is above DISKWARN. Defaults to 90 (percent). |
| glusterfs_disk_critical | Optional. Return a critical error if disk usage is above DISKCRIT. Defaults to 95 (percent). |
| glusterfs_inode_warning | Optional. Warn if inode usage is above DISKWARN. Defaults to 90 (percent). |
| glusterfs_inode_critical | Optional. Return a critical error if inode usage is above DISKCRIT. Defaults to 95 (percent). |
ceph ¶
The ceph plugin is used to check the Ceph storage health on the server.
| ceph_exec_dir | Optional. Ceph executable. Default /usr/bin/ceph. |
| ceph_conf_file | Optional. Alternative ceph conf file. |
| ceph_mon_address | Optional. Ceph monitor address[:port]. |
| ceph_client_id | Optional. Ceph client id. |
| ceph_client_name | Optional. Ceph client name. |
| ceph_client_key | Optional. Ceph client keyring file. |
| ceph_whitelist | Optional. Whitelist regexp for ceph health warnings. |
| ceph_details | Optional. Run ‘ceph health detail’. |
Virtualization ¶
This category includes all plugins for various virtualization technologies.
esxi_hardware ¶
The check_esxi_hardware.py plugin uses the pywbem Python library to monitor the hardware of ESXi servers through the VMWare API and CIM service.
| esxi_hardware_host | Required. Specifies the host to monitor. Defaults to “$address$”. |
| esxi_hardware_user | Required. Specifies the user for polling. Must be a local user of the root group on the system. Can also be provided as a file path file:/path/to/.passwdfile, then first string of file is used. |
| esxi_hardware_pass | Required. Password of the user. Can also be provided as a file path file:/path/to/.passwdfile, then second string of file is used. |
| esxi_hardware_port | Optional. Specifies the CIM port to connect to. Defaults to 5989. |
| esxi_hardware_vendor | Optional. Defines the vendor of the server: “auto”, “dell”, “hp”, “ibm”, “intel”, “unknown” (default). |
| esxi_hardware_html | Optional. Add web-links to hardware manuals for Dell servers (use your country extension). Only useful with esxi_hardware_vendor = dell. |
| esxi_hardware_ignore | Optional. Comma separated list of elements to ignore. |
| esxi_hardware_perfdata | Optional. Add performcedata for graphers like PNP4Nagios to the output. Defaults to false. |
| esxi_hardware_nopower | Optional. Do not collect power performance data, when esxi_hardware_perfdata is set to true. Defaults to false. |
| esxi_hardware_novolts | Optional. Do not collect voltage performance data, when esxi_hardware_perfdata is set to true. Defaults to false. |
| esxi_hardware_nocurrent | Optional. Do not collect current performance data, when esxi_hardware_perfdata is set to true. Defaults to false. |
| esxi_hardware_notemp | Optional. Do not collect temperature performance data, when esxi_hardware_perfdata is set to true. Defaults to false. |
| esxi_hardware_nofan | Optional. Do not collect fan performance data, when esxi_hardware_perfdata is set to true. Defaults to false. |
| esxi_hardware_nolcd | Optional. Do not collect lcd/display status data. Defaults to false. |
VMware ¶
Check commands for the check_vmware_esx plugin.
vmware-esx-dc-volumes
Check command object for the check_vmware_esx plugin. Shows all datastore volumes info.
| vmware_datacenter | Required. Datacenter/vCenter hostname. |
| vmware_cluster | Optional. ESX or ESXi clustername. |
| vmware_sslport | Optional. SSL port connection. Defaults to “443”. |
| vmware_ignoreunknown | Optional. Sometimes 3 (unknown) is returned from a component. But the check itself is ok. With this option the plugin will return OK (0) instead of UNKNOWN (3). Defaults to “false”. |
| vmware_ignorewarning | Optional. Sometimes 2 (warning) is returned from a component. But the check itself is ok (from an operator view). With this option the plugin will return OK (0) instead of WARNING (1). Defaults to “false”. |
| vmware_timeout | Optional. Seconds before plugin times out. Defaults to “90”. |
| vmware_trace | Optional. Set verbosity level of vSphere API request/respond trace. |
| vmware_sessionfile | Optional. Session file name enhancement. |
| vmware_sessionfiledir | Optional. Path to store the vmware_sessionfile file. Defaults to “/var/spool/icinga2/tmp”. |
| vmware_nosession | Optional. No auth session – IT SHOULD BE USED FOR TESTING PURPOSES ONLY!. Defaults to “false”. |
| vmware_username | Optional. The username to connect to Host or vCenter server. No value defined as default. |
| vmware_password | Optional. The username’s password. No value defined as default. |
| vmware_authfile | Optional. Use auth file instead username/password to session connect. No effect if vmware_username and vmware_password are defined Authentication file content: username=vmuser password=p@ssw0rd |
| vmware_subselect | Optional. Volume name to be checked the free space. |
| vmware_gigabyte | Optional. Output in GB instead of MB. |
| vmware_usedspace | Optional. Output used space instead of free. Defaults to “false”. |
| vmware_alertonly | Optional. List only alerting volumes. Defaults to “false”. |
| vmware_exclude | Optional. Blacklist volumes name. No value defined as default. |
| vmware_include | Optional. Whitelist volumes name. No value defined as default. |
| vmware_isregexp | Optional. Treat blacklist and whitelist expressions as regexp. |
| vmware_dc_volume_used | Optional. Output used space instead of free. Defaults to “true”. |
| vmware_warn | Optional. The warning threshold for volumes. Defaults to “80%”. |
| vmware_crit | Optional. The critical threshold for volumes. Defaults to “90%”. |
vmware-esx-dc-runtime-info
Check command object for the check_vmware_esx plugin. Shows all runtime info for the datacenter/Vcenter.
vmware-esx-dc-runtime-listvms
Check command object for the check_vmware_esx plugin. List of vmware machines and their power state. BEWARE!! In larger environments systems can cause trouble displaying the informations needed due to the mass of data. Use vmware_alertonly to avoid this.
| vmware_alertonly | Optional. List only alerting VMs. Important here to avoid masses of data. |
| vmware_exclude | Optional. Blacklist VMs name. No value defined as default. |
| vmware_include | Optional. Whitelist VMs name. No value defined as default. |
| vmware_multiline | Optional. Multiline output in overview. This mean technically that a multiline output uses a HTML \<br> for the GUI. No value defined as default. |
vmware-esx-dc-runtime-listhost
Check command object for the check_vmware_esx plugin. List of VMware ESX hosts and their power state.
| vmware_alertonly | Optional. List only alerting hosts. Important here to avoid masses of data. |
| vmware_exclude | Optional. Blacklist VMware ESX hosts. No value defined as default. |
| vmware_include | Optional. Whitelist VMware ESX hosts. No value defined as default. |
vmware-esx-dc-runtime-listcluster
Check command object for the check_vmware_esx plugin. List of VMware clusters and their states.
| vmware_exclude | Optional. Blacklist VMware cluster. No value defined as default. |
| vmware_include | Optional. Whitelist VMware cluster. No value defined as default. |
vmware-esx-dc-runtime-issues
Check command object for the check_vmware_esx plugin. All issues for the host.
| vmware_exclude | Optional. Blacklist issues. No value defined as default. |
| vmware_include | Optional. Whitelist issues. No value defined as default. |
vmware-esx-dc-runtime-status
Check command object for the check_vmware_esx plugin. Overall object status (gray/green/red/yellow).
vmware-esx-dc-runtime-tools
Check command object for the check_vmware_esx plugin. Vmware Tools status.
| vmware_poweredonly | Optional. List only VMs which are powered on. No value defined as default. |
| vmware_exclude | Optional. Blacklist VMs. No value defined as default. |
| vmware_include | Optional. Whitelist VMs. No value defined as default. |
| vmware_openvmtools | Optional Prevent CRITICAL state for installed and running Open VM Tools. |
vmware-esx-soap-host-check
Check command object for the check_vmware_esx plugin. Simple check to verify a successful connection to VMware SOAP API.
| vmware_host | Required. ESX or ESXi hostname. |
| vmware_datacenter | Optional. Datacenter/vCenter hostname. In case the check is done through a Datacenter/vCenter host. |
vmware-esx-soap-host-uptime
Check command object for the check_vmware_esx plugin. Displays uptime of the VMware host.
vmware-esx-soap-host-cpu
Check command object for the check_vmware_esx plugin. CPU usage in percentage.
| vmware_warn | Optional. The warning threshold in percent. Defaults to “80%”. |
| vmware_crit | Optional. The critical threshold in percent. Defaults to “90%”. |
vmware-esx-soap-host-cpu-ready
Check command object for the check_vmware_esx plugin. Percentage of time that the virtual machine was ready, but could not get scheduled to run on the physical CPU. CPU ready time is dependent on the number of virtual machines on the host and their CPU loads. High or growing ready time can be a hint CPU bottlenecks.
vmware-esx-soap-host-cpu-wait
Check command object for the check_vmware_esx plugin. CPU time spent in wait state. The wait total includes time spent the CPU idle, CPU swap wait, and CPU I/O wait states. High or growing wait time can be a hint I/O bottlenecks.
vmware-esx-soap-host-cpu-usage
Check command object for the check_vmware_esx plugin. Actively used CPU of the host, as a percentage of the total available CPU. Active CPU is approximately equal to the ratio of the used CPU to the available CPU.
vmware-esx-soap-host-mem
Check command object for the check_vmware_esx plugin. All mem info(except overall and no thresholds).
vmware-esx-soap-host-mem-usage
Check command object for the check_vmware_esx plugin. Average mem usage in percentage.
vmware-esx-soap-host-mem-consumed
Check command object for the check_vmware_esx plugin. Amount of machine memory used on the host. Consumed memory includes Includes memory used by the Service Console, the VMkernel vSphere services, plus the total consumed metrics for all running virtual machines in MB.
| vmware_warn | Optional. The warning threshold in percent. No value defined as default. |
| vmware_crit | Optional. The critical threshold in percent. No value defined as default. |
vmware-esx-soap-host-mem-swapused
Check command object for the check_vmware_esx plugin. Amount of memory that is used by swap. Sum of memory swapped of all powered on VMs and vSphere services on the host in MB. In case of an error all VMs with their swap used will be displayed.
vmware-esx-soap-host-mem-overhead
Check command object for the check_vmware_esx plugin. Additional mem used by VM Server in MB.
| vmware_authfile | Optional. Use auth file instead username/password to session connect. No effect if vmware_username and vmware_password are defined Auhentication file content: username=vmuser password=p@ssw0rd |
vmware-esx-soap-host-mem-memctl
Check command object for the check_vmware_esx plugin. The sum of all vmmemctl values in MB for all powered-on virtual machines, plus vSphere services on the host. If the balloon target value is greater than the balloon value, the VMkernel inflates the balloon, causing more virtual machine memory to be reclaimed. If the balloon target value is less than the balloon value, the VMkernel deflates the balloon, which allows the virtual machine to consume additional memory if needed (used by VM memory control driver). In case of an error all VMs with their vmmemctl values will be displayed.
vmware-esx-soap-host-net
Check command object for the check_vmware_esx plugin. Shows net info.
| vmware_exclude | Optional. Blacklist NICs. No value defined as default. |
| vmware_isregexp | Optional. Treat blacklist expression as regexp. |
vmware-esx-soap-host-net-usage
Check command object for the check_vmware_esx plugin. Overall network usage in KBps(Kilobytes per Second).
| vmware_warn | Optional. The warning threshold in KBps(Kilobytes per Second). No value defined as default. |
| vmware_crit | Optional. The critical threshold in KBps(Kilobytes per Second). No value defined as default. |
vmware-esx-soap-host-net-receive
Check command object for the check_vmware_esx plugin. Data receive in KBps(Kilobytes per Second).
vmware-esx-soap-host-net-send
Check command object for the check_vmware_esx plugin. Data send in KBps(Kilobytes per Second).
vmware-esx-soap-host-net-nic
Check command object for the check_vmware_esx plugin. Check all active NICs.
vmware-esx-soap-host-volumes
| vmware_spaceleft | Optional. This has to be used in conjunction with thresholds as mentioned above. |
vmware-esx-soap-host-io
Check command object for the check_vmware_esx plugin. Shows all disk io info. Without subselect no thresholds can be given. All I/O values are aggregated from historical intervals over the past 24 hours with a 5 minute sample rate.
vmware-esx-soap-host-io-aborted
Check command object for the check_vmware_esx plugin. Number of aborted SCSI commands.
| vmware_warn | Optional. The warning threshold. No value defined as default. |
| vmware_crit | Optional. The critical threshold. No value defined as default. |
vmware-esx-soap-host-io-resets
Check command object for the check_vmware_esx plugin. Number of SCSI bus resets.
vmware-esx-soap-host-io-read
Check command object for the check_vmware_esx plugin. Average number of kilobytes read from the disk each second.
vmware-esx-soap-host-io-read-latency
Check command object for the check_vmware_esx plugin. Average amount of time (ms) to process a SCSI read command issued from the Guest OS to the virtual machine.
vmware-esx-soap-host-io-write
Check command object for the check_vmware_esx plugin. Average number of kilobytes written to disk each second.
vmware-esx-soap-host-io-write-latency
Check command object for the check_vmware_esx plugin. Average amount of time (ms) taken to process a SCSI write command issued by the Guest OS to the virtual machine.
vmware-esx-soap-host-io-usage
Check command object for the check_vmware_esx plugin. Aggregated disk I/O rate. For hosts, this metric includes the rates for all virtual machines running on the host.
vmware-esx-soap-host-io-kernel-latency
Check command object for the check_vmware_esx plugin. Average amount of time (ms) spent by VMkernel processing each SCSI command.
vmware-esx-soap-host-io-device-latency
Check command object for the check_vmware_esx plugin. Average amount of time (ms) to complete a SCSI command from the physical device.
vmware-esx-soap-host-io-queue-latency
Check command object for the check_vmware_esx plugin. Average amount of time (ms) spent in the VMkernel queue.
vmware-esx-soap-host-io-total-latency
Check command object for the check_vmware_esx plugin. Average amount of time (ms) taken during the collection interval to process a SCSI command issued by the guest OS to the virtual machine. The sum of kernelWriteLatency and deviceWriteLatency.
vmware-esx-soap-host-media
Check command object for the check_vmware_esx plugin. List vm’s with attached host mounted media like cd,dvd or floppy drives. This is important for monitoring because a virtual machine with a mount cd or dvd drive can not be moved to another host.
vmware-esx-soap-host-service
Check command object for the check_vmware_esx plugin. Shows host service info.
| vmware_exclude | Optional. Blacklist services name. No value defined as default. |
| vmware_include | Optional. Whitelist services name. No value defined as default. |
vmware-esx-soap-host-runtime
Check command object for the check_vmware_esx plugin. Shows runtime info: VMs, overall status, connection state, health, storagehealth, temperature and sensor are represented as one value and without thresholds.
vmware-esx-soap-host-runtime-con
Check command object for the check_vmware_esx plugin. Shows connection state.
vmware-esx-soap-host-runtime-listvms
Check command object for the check_vmware_esx plugin. List of VMware machines and their status.
vmware-esx-soap-host-runtime-status
vmware-esx-soap-host-runtime-health
Check command object for the check_vmware_esx plugin. Checks cpu/storage/memory/sensor status.
| vmware_exclude | Optional. Blacklist status name. No value defined as default. |
| vmware_include | Optional. Whitelist status name. No value defined as default. |
vmware-esx-soap-host-runtime-health-listsensors
Check command object for the check_vmware_esx plugin. List all available sensors(use for listing purpose only).
vmware-esx-soap-host-runtime-health-nostoragestatus
Check command object for the check_vmware_esx plugin. This is to avoid a double alarm if you use vmware-esx-soap-host-runtime-health and vmware-esx-soap-host-runtime-storagehealth.
Check command object for the check_vmware_esx plugin. Local storage status check.
| vmware_exclude | Optional. Blacklist storage name. No value defined as default. |
| vmware_include | Optional. Whitelist storage name. No value defined as default. |
vmware-esx-soap-host-runtime-temp
Check command object for the check_vmware_esx plugin. Lists all temperature sensors.
| vmware_exclude | Optional. Blacklist sensor name. No value defined as default. |
| vmware_include | Optional. Whitelist sensor name. No value defined as default. |
vmware-esx-soap-host-runtime-issues
Check command object for the check_vmware_esx plugin. Lists all configuration issues for the host.
| vmware_exclude | Optional. Blacklist configuration issues. No value defined as default. |
| vmware_include | Optional. Whitelist configuration issues. No value defined as default. |
vmware-esx-soap-host-storage
Check command object for the check_vmware_esx plugin. Shows Host storage info.
| vmware_exclude | Optional. Blacklist adapters, luns and paths. No value defined as default. |
| vmware_include | Optional. Whitelist adapters, luns and paths. No value defined as default. |
vmware-esx-soap-host-storage-adapter
Check command object for the check_vmware_esx plugin. List host bus adapters.
| vmware_exclude | Optional. Blacklist adapters. No value defined as default. |
| vmware_include | Optional. Whitelist adapters. No value defined as default. |
vmware-esx-soap-host-storage-lun
Check command object for the check_vmware_esx plugin. List SCSI logical units. The listing will include: LUN, canonical name of the disc, all of displayed name which is not part of the canonical name and status.
| vmware_exclude | Optional. Blacklist luns. No value defined as default. |
| vmware_include | Optional. Whitelist luns. No value defined as default. |
vmware-esx-soap-host-storage-path
Check command object for the check_vmware_esx plugin. List multipaths and the associated paths.
| vmware_alertonly | Optional. List only alerting units. Important here to avoid masses of data. Defaults to “false”. |
| vmware_exclude | Optional. Blacklist paths. No value defined as default. |
| vmware_include | Optional. Whitelist paths. No value defined as default. |
| vmware_standbyok | Optional. For storage systems where a standby multipath is ok and not a warning. Defaults to false. |
vmware-esx-soap-vm-cpu
Check command object for the check_vmware_esx plugin. Shows all CPU usage info.
| vmware_datacenter | Optional. Datacenter/vCenter hostname. Conflicts with vmware_host. |
| vmware_host | Optional. ESX or ESXi hostname. Conflicts with vmware_datacenter. |
| vmware_vmname | Required. Virtual machine name. |
vmware-esx-soap-vm-cpu-ready
vmware-esx-soap-vm-cpu-wait
vmware-esx-soap-vm-cpu-usage
Check command object for the check_vmware_esx plugin. Amount of actively used virtual CPU, as a percentage of total available CPU. This is the host’s view of the CPU usage, not the guest operating system view. It is the average CPU utilization over all available virtual CPUs in the virtual machine.
| vmware_warn | Optional. Warning threshold in percent. Defaults to “80%”. |
| vmware_crit | Optional. Critical threshold in percent. Defaults to “90%”. |
vmware-esx-soap-vm-mem
Check command object for the check_vmware_esx plugin. Shows all memory info, except overall.
vmware-esx-soap-vm-mem-usage
Check command object for the check_vmware_esx plugin. Average mem usage in percentage of configured virtual machine “physical” memory.
vmware-esx-soap-vm-mem-consumed
Check command object for the check_vmware_esx plugin. Amount of guest physical memory in MB consumed by the virtual machine for guest memory. Consumed memory does not include overhead memory. It includes shared memory and memory that might be reserved, but not actually used. Use this metric for charge-back purposes.
vm consumed memory = memory granted – memory saved
vmware-esx-soap-vm-mem-memctl
Check command object for the check_vmware_esx plugin. Amount of guest physical memory that is currently reclaimed from the virtual machine through ballooning. This is the amount of guest physical memory that has been allocated and pinned by the balloon driver.
vmware-esx-soap-vm-net
vmware-esx-soap-vm-net-usage
vmware-esx-soap-vm-net-receive
Check command object for the check_vmware_esx plugin. Receive in KBps(Kilobytes per Second).
vmware-esx-soap-vm-net-send
Check command object for the check_vmware_esx plugin. Send in KBps(Kilobytes per Second).
vmware-esx-soap-vm-io
vmware-esx-soap-vm-io-read
| vmware_nosession | Optional. No auth session - IT SHOULD BE USED FOR TESTING PURPOSES ONLY!. Defaults to “false”. |
vmware-esx-soap-vm-io-write
vmware-esx-soap-vm-io-usage
vmware-esx-soap-vm-runtime
Check command object for the check_vmware_esx plugin. Shows virtual machine runtime info.
vmware-esx-soap-vm-runtime-con
Check command object for the check_vmware_esx plugin. Shows the connection state.
vmware-esx-soap-vm-runtime-powerstate
Check command object for the check_vmware_esx plugin. Shows virtual machine power state: poweredOn, poweredOff or suspended.
vmware-esx-soap-vm-runtime-status
vmware-esx-soap-vm-runtime-consoleconnections
Check command object for the check_vmware_esx plugin. Console connections to virtual machine.
vmware-esx-soap-vm-runtime-gueststate
Check command object for the check_vmware_esx plugin. Guest OS status. Needs VMware Tools installed and running.
vmware-esx-soap-vm-runtime-tools
Check command object for the check_vmware_esx plugin. Guest OS status. VMware tools status.
vmware-esx-soap-vm-runtime-issues
Check command object for the check_vmware_esx plugin. All issues for the virtual machine.
Web ¶
This category includes all plugins for web-based checks.
apache-status ¶
The check_apache_status.pl plugin uses the /server-status HTTP endpoint to monitor status metrics for the Apache webserver.
| apache_status_address | Optional. The host’s address. Defaults to “$address$” if the host’s address attribute is set, address6 otherwise. |
| apache_status_port | Optional. the http port. |
| apache_status_url | Optional. URL to use, instead of the default (http://apache_status_address/server-status). |
| apache_status_ssl | Optional. set to use ssl connection |
| apache_status_timeout | Optional. timeout in seconds |
| apache_status_warning | Optional. Warning threshold (number of open slots, busy workers and idle workers that will cause a WARNING) like ‘:20,50,:50’. |
| apache_status_critical | Optional. Critical threshold (number of open slots, busy workers and idle workers that will cause a CRITICAL) like ‘:10,25,:20’. |
ssl_cert ¶
The check_ssl_cert plugin uses the openssl binary (and optional curl) to check a X.509 certificate.
| ssl_cert_address | Optional. The host’s address. Defaults to “$address$” if the host’s address attribute is set, “$address6$” otherwise. |
| ssl_cert_port | Optional. TCP port number (default: 443). |
| ssl_cert_file | Optional. Local file path. Works only if ssl_cert_address is set to “localhost”. |
| ssl_cert_warn | Optional. Minimum number of days a certificate has to be valid. |
| ssl_cert_critical | Optional. Minimum number of days a certificate has to be valid to issue a critical status. |
| ssl_cert_cn | Optional. Pattern to match the CN of the certificate. |
| ssl_cert_altnames | Optional. Matches the pattern specified in -n with alternate |
| ssl_cert_issuer | Optional. Pattern to match the issuer of the certificate. |
| ssl_cert_org | Optional. Pattern to match the organization of the certificate. |
| ssl_cert_email | Optional. Pattern to match the email address contained in the certificate. |
| ssl_cert_serial | Optional. Pattern to match the serial number. |
| ssl_cert_noauth | Optional. Ignore authority warnings (expiration only) |
| ssl_cert_match_host | Optional. Match CN with the host name. |
| ssl_cert_selfsigned | Optional. Allow self-signed certificate. |
| ssl_cert_sni | Optional. Sets the TLS SNI (Server Name Indication) extension. |
| ssl_cert_timeout | Optional. Seconds before connection times out (default: 15) |
| ssl_cert_protocol | Optional. Use the specific protocol {http,smtp,pop3,imap,ftp,xmpp,irc,ldap} (default: http). |
| ssl_cert_clientcert | Optional. Use client certificate to authenticate. |
| ssl_cert_clientpass | Optional. Set passphrase for client certificate. |
| ssl_cert_ssllabs | Optional. SSL Labs assessment |
| ssl_cert_ssllabs_nocache | Optional. Forces a new check by SSL Labs |
| ssl_cert_rootcert | Optional. Root certificate or directory to be used for certificate validation. |
| ssl_cert_ignore_signature | Optional. Do not check if the certificate was signed with SHA1 od MD5. |
| ssl_cert_ssl_version | Optional. Force specific SSL version out of {ssl2,ssl3,tls1,tls1_1,tls1_2}. |
| ssl_cert_disable_ssl_versions | Optional. Disable specific SSL versions out of {ssl2,ssl3,tls1,tls1_1,tls1_2}. Multiple versions can be given as array. |
| ssl_cert_cipher | Optional. Cipher selection: force {ecdsa,rsa} authentication. |
| ssl_cert_ignore_expiration | Optional. Ignore expiration date. |
| ssl_cert_ignore_ocsp | Optional. Do not check revocation with OCSP. |
jmx4perl ¶
The check_jmx4perl plugin
uses the HTTP API exposed by the Jolokia
web application and queries Java message beans on an application server. It is
part of the JMX::Jmx4Perl Perl module which includes detailed
documentation.
| jmx4perl_url | Required. URL to agent web application. Defaults to “http://$address$:8080/jolokia”. |
| jmx4perl_product | Optional. Name of app server product (e.g. jboss), by default is uses an auto detection facility. |
| jmx4perl_alias | Optional. Alias name for attribute (e.g. MEMORY_HEAP_USED). All available aliases can be viewed by executing jmx4perl aliases on the command line. |
| jmx4perl_mbean | Optional. MBean name (e.g. java.lang:type=Memory). |
| jmx4perl_attribute | Optional. Attribute name (e.g. HeapMemoryUsage). |
| jmx4perl_operation | Optional. Operation to execute. |
| jmx4perl_value | Optional. Shortcut for specifying mbean/attribute/path. Slashes within names must be escaped with backslash. |
| jmx4perl_delta | Optional. Switches on incremental mode. Optional argument are seconds used for normalizing. |
| jmx4perl_path | Optional. Inner path for extracting a single value from a complex attribute or return value (e.g. used). |
| jmx4perl_target | Optional. JSR-160 Service URL specifing the target server. |
| jmx4perl_target_user | Optional. Username to use for JSR-160 connection. |
| jmx4perl_target_password | Optional. Password to use for JSR-160 connection. |
| jmx4perl_proxy | Optional. Proxy to use. |
| jmx4perl_user | Optional. User for HTTP authentication. |
| jmx4perl_password | Optional. Password for HTTP authentication. |
| jmx4perl_name | Optional. Name to use for output, by default a standard value based on the MBean and attribute will be used. |
| jmx4perl_method | Optional. HTTP method to use, either get or post. By default a method is determined automatically based on the request type. |
| jmx4perl_base | Optional. Base name, which when given, interprets critical and warning values as relative in the range 0 .. 100%. Must be given in the form mbean/attribute/path. |
| jmx4perl_base_mbean | Optional. Base MBean name, interprets critical and warning values as relative in the range 0 .. 100%. Requires “jmx4perl_base_attribute”. |
| jmx4perl_base_attribute | Optional. Base attribute for a relative check. Requires “jmx4perl_base_mbean”. |
| jmx4perl_base_path | Optional. Base path for relative checks, where this path is used on the base attribute’s value. |
| jmx4perl_unit | Optional. Unit of measurement of the data retrieved. Recognized values are [B|KB|MN|GB|TB] for memory values and [us|ms|s|m|h|d] for time values. |
| jmx4perl_null | Optional. Value which should be used in case of a null return value of an operation or attribute. Defaults to null. |
| jmx4perl_string | Optional. Force string comparison for critical and warning checks. Defaults to false. |
| jmx4perl_numeric | Optional. Force numeric comparison for critical and warning checks. Defaults to false. |
| jmx4perl_critical | Optional. Critical threshold for value. |
| jmx4perl_warning | Optional. Warning threshold for value. |
| jmx4perl_label | Optional. Label to be used for printing out the result of the check. For placeholders which can be used see the documentation. |
| jmx4perl_perfdata | Optional. Whether performance data should be omitted, which are included by default. Defaults to “on” for numeric values, to “off” for strings. |
| jmx4perl_unknown_is_critical | Optional. Map UNKNOWN errors to errors with a CRITICAL status. Defaults to false. |
| jmx4perl_timeout | Optional. Seconds before plugin times out. Defaults to “15”. |
| jmx4perl_config | Optional. Path to configuration file. |
| jmx4perl_server | Optional. Symbolic name of server url to use, which needs to be configured in the configuration file. |
| jmx4perl_check | Optional. Name of a check configuration as defined in the configuration file, use array if you need arguments. |
kdc ¶
The check_kdc plugin
uses the Kerberos kinit binary to monitor Kerberos 5 KDC by acquiring a ticket.
| kdc_address | Optional. The host’s address. Defaults to “$address$” if the host’s address attribute is set, address6 otherwise. |
| kdc_port | Optional Port on which KDC runs (default 88). |
| kdc_principal | Required Principal name to authenticate as (including realm). |
| kdc_keytab | Required Keytab file containing principal’s key. |
nginx_status ¶
The check_nginx_status.pl plugin uses the /nginx_status HTTP endpoint which provides metrics for monitoring Nginx.
| nginx_status_host_address | Optional. The host’s address. Defaults to “$address$” if the host’s address attribute is set, address6 otherwise. |
| nginx_status_port | Optional. the http port. |
| nginx_status_url | Optional. URL to use, instead of the default (http://nginx_status_hostname/nginx_status). |
| nginx_status_servername | Optional. ServerName to use if you specified an IP to match the good Virtualhost in your target. |
| nginx_status_ssl | Optional. set to use ssl connection. |
| nginx_status_disable_sslverify | Optional. set to disable SSL hostname verification. |
| nginx_status_user | Optional. Username for basic auth. |
| nginx_status_pass | Optional. Password for basic auth. |
| nginx_status_realm | Optional. Realm for basic auth. |
| nginx_status_maxreach | Optional. Number of max processes reached (since last check) that should trigger an alert. |
| nginx_status_timeout | Optional. timeout in seconds. |
| nginx_status_warn | Optional. Warning threshold (number of active connections, ReqPerSec or ConnPerSec that will cause a WARNING) like ‘10000,100,200’. |
| nginx_status_critical | Optional. Critical threshold (number of active connections, ReqPerSec or ConnPerSec that will cause a CRITICAL) like ‘20000,200,300’. |
rbl ¶
The check_rbl plugin
uses the Net::DNS Perl library to check whether your SMTP server
is blacklisted.
| rbl_hostname | Optional. The address or name of the SMTP server to check. Defaults to “$address$” if the host’s address attribute is set, address6 otherwise. |
| rbl_server | Required List of RBL servers as an array. |
| rbl_warning | Optional Number of blacklisting servers for a warning. |
| rbl_critical | Optional Number of blacklisting servers for a critical. |
| tbl_timeout | Optional Seconds before plugin times out (default: 15). |
squid ¶
The check_squid plugin
uses the squidclient binary to monitor a Squid proxy.
| squid_hostname | Optional. The host’s address. Defaults to “$address$” if the host’s address attribute is set, “$address6$” otherwise. |
| squid_data | Optional. Data to fetch (default: Connections) available data: Connections Cache Resources Memory FileDescriptors. |
| squid_port | Optional. Port number (default: 3128). |
| squid_user | Optional. WWW user. |
| squid_password | Optional. WWW password. |
| squid_warning | Optional. Warning threshold. See http://nagiosplug.sourceforge.net/developer-guidelines.html#THRESHOLDFORMAT for the threshold format. |
| squid_critical | Optional. Critical threshold. See http://nagiosplug.sourceforge.net/developer-guidelines.html#THRESHOLDFORMAT for the threshold format. |
| squid_client | Optional. Path of squidclient (default: /usr/bin/squidclient). |
| squid_timeout | Optional. Seconds before plugin times out (default: 15). |
webinject ¶
The check_webinject plugin uses WebInject to test web applications and web services in an automated fashion. It can be used to test individual system components that have HTTP interfaces (JSP, ASP, CGI, PHP, AJAX, Servlets, HTML Forms, XML/SOAP Web Services, REST, etc), and can be used as a test harness to create a suite of HTTP level automated functional, acceptance, and regression tests. A test harness allows you to run many test cases and collect/report your results. WebInject offers real-time results display and may also be used for monitoring system response times.
| webinject_config_file | Optional. There is a configuration file named ‘config.xml’ that is used to store configuration settings for your project. You can use this to specify which test case files to run and to set some constants and settings to be used by WebInject. |
| webinject_output | Optional. This option is followed by a directory name or a prefix to prepended to the output files. This is used to specify the location for writing output files (http.log, results.html, and results.xml). If a directory name is supplied (use either an absolute or relative path and make sure to add the trailing slash), all output files are written to this directory. If the trailing slash is omitted, it is assumed to a prefix and this will be prepended to the output files. You may also use a combination of a directory and prefix. |
| webinject_no_output | Optional. Suppresses all output to STDOUT except the results summary. |
| webinject_timeout | Optional. The value [given in seconds] will be compared to the global time elapsed to run all the tests. If the tests have all been successful, but have taken more time than the ‘globaltimeout’ value, a warning message is sent back to Icinga. |
| webinject_report_type | Optional. This setting is used to enable output formatting that is compatible for use with specific external programs. The available values you can set this to are: nagios, mrtg, external and standard. |
| webinject_testcase_file | Optional. When you launch WebInject in console mode, you can optionally supply an argument for a testcase file to run. It will look for this file in the directory that webinject.pl resides in. If no filename is passed from the command line, it will look in config.xml for testcasefile declarations. If no files are specified, it will look for a default file named ‘testcases.xml’ in the current [webinject] directory. If none of these are found, the engine will stop and give you an error. |
