Upgrading Icinga Web 2 ¶
Specific version upgrades are described below. Please note that upgrades are incremental. An upgrade from v2.6 to v2.8 requires to follow the instructions for v2.7 too.
Upgrading to Icinga Web 2 2.10.x¶
General
- The theme “solarized-dark” has been removed due to the introduction of the new default dark mode.
Deprecations
- Builtin support for PDF exports using the
dompdf
library will be dropped with version 2.12. It is highly recommended to use Icinga PDF Export instead.
Discontinued package updates
- We will stop offering major updates for Debian 9 (Stretch) starting with version 2.11. However, versions 2.9 and 2.10 will continue to receive minor updates on this platform.
icinga.com provides an overview about currently supported distributions.
Framework changes affecting third-party code
- Asset support for modules (#3961) introduced with v2.8 has now been removed.
expandable-toggle
-support has been removed. Useclass="collapsible" data-visible-height=0
to achieve the same effect. (Available since v2.7.0)- The
.var()
LESS mixin and the LESS functionextract-variable-default
have been removed (introduced with v2.9)
Upgrading to Icinga Web 2 2.9.1¶
Database Schema
- Please apply the
v2.9.1.sql
upgrade script depending on your database vendor. As of version2.9.9
, upgrade scripts can be found at/usr/share/icingaweb2/schema/*-upgrades/
. Older versions install these files to/usr/share/doc/icingaweb2/schema/*-upgrades/
for RPM-based systems and/usr/share/icingaweb2/etc/schema/*-upgrades/
for Debian or Ubuntu.
Upgrading to Icinga Web 2 2.9.x¶
Installation
- Icinga Web 2 now requires the Icinga PHP Library (ipl) (>= 0.6) and Icinga PHP Thirdparty (>= 0.10). Please make sure to install both when upgrading. We provide packages for them and if you’ve installed Icinga Web 2 already by package they should be installed automatically during the upgrade.
- Icinga Business Process Modelling has been updated to v2.3.1. If you’re using this module, this version is required when upgrading.
General
- For database connections to the IDO running on MySQL, a default charset (
latin1
) is now applied. If you had previously problems with special characters and umlauts and you’ve set this charset already manually, no change is required. However, if your IDO resource configuration has another charset configured than this, it is highly recommended to clear this setting. Otherwise the default won’t apply and characters may still be shown incorrectly in the UI.
Database Schema
- Icinga Web 2 now permits its users to stay logged in. This requires a new database table.
- Please apply the
v2.9.0.sql
Breaking changes
- Password changes are not allowed by default anymore
- The fake refusal
no-user/password-change
has now been changed to a grantuser/password-change
. Any user that hadno-user/password-change
previously still cannot change passwords. Though any user that didn’t have this permission, needs to be granteduser/password-change
now in order to change passwords.
Deprecations
- Support for EOL PHP versions (5.6, 7.0, 7.1 and 7.2) will be removed with version 2.11
- Support for Internet Explorer will be completely removed with version 2.11
- New features after v2.9 will already not (necessarily) be available in Internet Explorer
user.local_name
replaces theuser:local_name
macro in restrictions, and the latter will be removed with version 2.11- The configuration backend type
INI
is not configurable anymore. A database is now mandatory. - Existing configurations using this configuration backend type will stop working with the release of v2.11.
- To migrate your local user preferences to database, enable the
migrate
module and use the commandicingacli migrate preferences
. If you already setup the configuration database, it will work right away. If not, pass it the resource you’d like to use as configuration database with--resource=
. - Note that this only applies to user preferences. Other configurations are still stored
in
.ini
files. (#3770) - The Vagrant file and all its assets will be removed with version 2.11
- The
jquery-migrate
compatibility layer for Javascript code working with jQuery 2.x has been removed. It has been introduced with v2.7 when we upgraded jQuery to v3.4.1 in order to allow module developers a seamless upgrade chance. If a module still has UI glitches after an upgrade to v2.9, please contact the module developer. - The method
getHtmlForEvent
of theEventDetailsExtensionHook
previously received the host or service object of an event. Now the actual event object is passed to it instead. - Asset support for modules (#3961) introduced with v2.8 has now been deprecated in favor of library support (#4272) and will be removed with v2.10. We don’t expect broad usage of this feature since it’s been introduced with the latest major version, so it’s already being removed with the next one.
Upgrading to Icinga Web 2 2.8.x¶
Changes in packaging and dependencies
Valid for distributions:
- RHEL / CentOS 7
- Upgrade to PHP 7.3 via RedHat SCL
After upgrading to version 2.8.0 you’ll get the new rh-php73
dependency installed. This is a drop-in replacement
for the previous rh-php71
dependency and only requires the setup of a new fpm service and possibly some copying
of customized configurations.
php.ini or php-fpm settings you have tuned in the past need to be copied over to the new path:
From /etc/opt/rh/rh-php71/
to /etc/opt/rh/rh-php73/
Don’t forget to also install any additional php-modules for PHP 7.3 you’ve had previously installed for e.g. Icinga Web 2 modules.
There’s also a new service included which replaces the previous one for php-fpm:
Stop the old service: systemctl stop rh-php71-php-fpm.service
Start the new service: systemctl start rh-php73-php-fpm.service
You can now safely remove the previous dependency if you like:
yum remove rh-php71*
Icinga Web 2 v2.8+ is not supported on these platforms:
- RHEL / CentOS 6
- Debian 8 Jessie
- Ubuntu 16.04 LTS (Xenial Xerus)
Please consider an upgrade of your central Icinga system to a newer distribution release.
- Url parameter
view=compact
is now deprecated.showCompact
should be used instead. Details are in pull request #4164. - Form elements of type checkbox now need to be checked prior submission if they’re
required. Previously setting
required => true
didn’t cause the browser to complain if such a checkbox wasn’t checked. Browsers now do complain if so. - The general layout now uses flexbox instead of fixed positioning. This applies to the
#header
,#sidebar
,#main
,#footer
,#col1
,#col2
and a column’s controls.#sidebar
and#main
are now additionally wrapped in a new container#content-wrapper
Upgrading to Icinga Web 2 2.7.x ¶
Breaking changes
- We’ve upgraded jQuery to version 3.4.1. If you’re a module developer, please add
?_dev
to your address bar to check for log messages emitted by jquery-migrate. (https://github.com/jquery/jquery-migrate) Your javascript code will still work, though jquery-migrate will notify you if you’re utilizing deprecated/removed functions. jquery-migrate will be removed with Icinga Web v2.8 and code not adjusted accordingly will stop working. - If you’re using a language other than english and you’ve adjusted or disabled module dashboards, you’ll need to
update all of your
dashboard.ini
files. A CLI command exists to assist you with this task. Enable themigrate
module and run the following on the host where these files exist:icingacli migrate dashboard sections --verbose
Upgrading to Icinga Web 2 2.6.x ¶
- Icinga Web 2 version 2.6.x does not introduce any backward incompatible change.
Upgrading to Icinga Web 2 2.5.x ¶
Attention
Icinga Web 2 v2.5 requires at least PHP 5.6.
Breaking changes
- Hash marks (
) in INI files are no longer recognized as comments by parse_ini_file since PHP 7.0. - Existing sessions of logged-in users do no longer work as expected due to a change in the
User
data structure. Everyone who was logged in before the upgrade has to log out once.
- RHEL / CentOS 6 + 7
- Upgrading to PHP 7.0 / 7.1 via RedHat SCL (new dependency)
- See Upgrading to FPM for manual steps that are required
- SUSE SLE 12
- Upgrading PHP to >= 5.6.0 via the alternative packages. You might have to confirm the replacement of PHP < 5.6 - but that should work with any other PHP app as well.
- Make sure to enable the new Apache module
a2enmod php7
and restartapache2
Icinga Web 2 v2.5+ is not supported on these platforms:
- Debian 7 wheezy
- Ubuntu 14.04 LTS (trusty)
- SUSE SLE 11 (all service packs)
packages.icinga.com provides an overview about currently supported distributions.
Database schema
Icinga Web 2 v2.5.0 requires a schema update for the database. The database schema has been adjusted to support usernames up to 254 characters. This is necessary to support the new domain-aware authentication feature.
Continue here for MySQL and PostgreSQL.
Upgrading to Icinga Web 2 2.4.x ¶
- Icinga Web 2 version 2.4.x does not introduce any backward incompatible change.
Upgrading to Icinga Web 2 2.3.x ¶
- Icinga Web 2 version 2.3.x does not introduce any backward incompatible change.
Upgrading to Icinga Web 2 2.2.0 ¶
- The menu entry
Authorization
beneathConfig
has been renamed toAuthentication
. The role, user backend and user group backend configuration which was previously found beneathAuthentication
has been moved toApplication
Upgrading to Icinga Web 2 2.1.x ¶
- Since Icinga Web 2 version 2.1.3 LDAP user group backends respect the configuration option
group_filter
. Users who changed the configuration manually and used the optionfilter
instead have to change it back togroup_filter
Upgrading to Icinga Web 2 2.0.0 ¶
Icinga Web 2 installations from package on RHEL/CentOS 7 now depend on
php-ZendFramework
which is available through the EPEL repository. Before, Zend was installed as Icinga Web 2 vendor library through the packageicingaweb2-vendor-zend
. After upgrading, please make sure to remove the packageicingaweb2-vendor-zend
Icinga Web 2 version 2.0.0 requires permissions for accessing modules. Those permissions are automatically generated for each installed module in the format
module/<moduleName>
. Administrators have to grant the module permissions to users and/or user groups in the roles configuration for permitting access to specific modules. In addition, restrictions provided by modules are now configurable for each installed module too. Before, a module had to be enabled before having the possibility to configure restrictions. -
The instances.ini configuration file provided by the monitoring module has been renamed to commandtransports.ini. The content and location of the file remains unchanged.
The location of a user’s preferences has been changed from <config-dir>/preferences/<username>.ini to <config-dir>/preferences/<username>/config.ini. The content of the file remains unchanged.
Upgrading to Icinga Web 2 Release Candidate 1 ¶
The first release candidate of Icinga Web 2 introduces the following non-backward compatible changes:
The database schema has been adjusted and the tables
icingaweb_group
andicingaweb_group_membership
were altered to ensure referential integrity. Please use the upgrade script located in etc/schema/ to update your database schema -
Users who are using PostgreSQL < v9.1 are required to upgrade their environment to v9.1+ as this is the new minimum required version for utilizing PostgreSQL as database backend
The restrictions
monitoring/hosts/filter
andmonitoring/services/filter
provided by the monitoring module were merged together. The new restriction is calledmonitoring/filter/objects
and supports only a predefined subset of filter columns. Please see the module’s security related documentation for more details.
Upgrading to Icinga Web 2 Beta 3 ¶
Because Icinga Web 2 Beta 3 does not introduce any backward incompatible change you don’t have to change your configuration files after upgrading to Icinga Web 2 Beta 3.
Upgrading to Icinga Web 2 Beta 2 ¶
Icinga Web 2 Beta 2 introduces access control based on roles for secured actions. If you’ve already set up Icinga Web 2, you are required to create the file roles.ini beneath Icinga Web 2’s configuration directory with the following content:
[administrators]
users = "your_user_name, another_user_name"
permissions = "*"
After please log out from Icinga Web 2 and log in again for having all permissions granted.
If you delegated authentication to your web server using the autologin
backend, you have to switch to the external
authentication backend to be able to log in again. The new name better reflects
what’s going on. A similar change
affects environments that opted for not storing preferences, your new backend is none
Upgrading the MySQL Database ¶
If you installed Icinga Web 2 from package, please check the upgrade scripts located in /usr/share/doc/icingaweb2/schema/mysql-upgrades (Debian/Ubuntu: /usr/share/icingaweb2/etc/schema/mysql-upgrades) to update your database schema. In case you installed Icinga Web 2 from source, please find the upgrade scripts in etc/schema/mysql-upgrades.
Note
If there isn’t an upgrade file for your current version available, there’s nothing to do.
Apply all database schema upgrade files incrementally.
# mysql -u root -p icingaweb2 < /usr/share/doc/icingaweb2/schema/mysql-upgrades/<version>.sql
Example: You are upgrading Icinga Web 2 from version 2.4.0
to 2.5.0
. Look into
the upgrade
directory:
$ ls /usr/share/doc/icingaweb2/schema/mysql-upgrades/
2.0.0beta3-2.0.0rc1.sql 2.5.0.sql
The upgrade file 2.5.0.sql
must be applied for the v2.5.0 release. If there are multiple
upgrade files involved, apply them incrementally.
# mysql -u root -p icinga < /usr/share/doc/icingaweb2/schema/mysql-upgrades/2.5.0.sql
Upgrading the PostgreSQL Database ¶
If you installed Icinga Web 2 from package, please check the upgrade scripts located in /usr/share/doc/icingaweb2/schema/pgsql-upgrades (Debian/Ubuntu: /usr/share/icingaweb2/etc/schema/pgsql-upgrades) to update your database schema. In case you installed Icinga Web 2 from source, please find the upgrade scripts in etc/schema/pgsql-upgrades.
Note
# export PGPASSWORD=icingaweb2
# psql -U icingaweb2 -d icingaweb2 < /usr/share/doc/icingaweb2/schema/pgsql-upgrades/<version>.sql
to 2.5.0
. Look into
the upgrade
directory:
$ ls /usr/share/doc/icingaweb2/schema/pgsql-upgrades/
# psql -U icingaweb2 -d icingaweb2 < /usr/share/doc/icingaweb2/schema/pgsql-upgrades/2.5.0.sql
