Skip to content
Preferences
Preferences are settings a user can set for their account only, for example the language and time zone.
Preferences can be stored either in INI files or in a MySQL or in a PostgreSQL database. By default, Icinga Web 2 stores preferences in INI files beneath Icinga Web 2’s configuration directory.
/etc/icingaweb2/<username>/config.ini
Configuration
The preference configuration backend is defined in the global config.ini file.
Store Preferences in INI Files
If preferences are stored in INI Files, Icinga Web 2 automatically creates one file per user using the username as file name for storing preferences. A INI file is created once a user saves changed preferences the first time. The files are located beneath the preferences directory beneath Icinga Web 2’s configuration directory.
You need to add the following section to the global config.ini file in order to store preferences in a file.
[global]
config_backend = "ini"
Store Preferences in a Database
In order to be more flexible in distributed setups you can store preferences in a MySQL or in a PostgreSQL database. For storing preferences in a database, you have to define a database resource which will be referenced as resource for the preferences storage.
You need to add the following section to the global config.ini file in order to store preferences in a database.
[global]
config_backend = "db"
config_resource = "icingaweb_db"
