Skip to content
Vagrant
This chapter explains how to setup the development environment for Icinga Web 2 inside a Vagrant VM.
If you are looking for a demo setup, please use the official Icinga Vagrant boxes instead.
Requirements
  • Vagrant >= version 1.5
  • VirtualBox or Parallels Desktop
Parallels requires the additional provider plugin vagrant-paralells to be installed:
$ vagrant plugin install vagrant-parallels
General
The Icinga Web 2 project ships with a Vagrant virtual machine that integrates the source code with various services and example data in a controlled environment. This enables developers and users to test MySQL and PostgreSQL backends as well as the LDAP authentication. All you have to do is install Vagrant and run:
vagrant up
Note: The first boot of the vm takes a fairly long time because you’ll download a plain CentOS base box and Vagrant will automatically provision the environment on the first go.
After you should be able to browse localhost:8080/icingaweb2.
Log into Icinga Web 2
Both LDAP and a MySQL are configured as authentication backend. Please use one of the following login credentials:
LDAP:
Username: jdoe
Password: password
MySQL:
Username: icingaadmin
Password: icinga
Testing the Source Code
All software required to run tests is installed in the virtual machine. In order to run all tests you have to execute the following command:
vagrant ssh -c "icingacli test php unit"
