Skip to content
Create your first Business Process Node
A Business Process Node consists of a name, title, an operator and one or more child nodes. It can be a Root Node, child node of other Business Process Nodes - or both.
Empty Config
Configuring our first node
To create our first Business Process Node we click the Add button. This leads to the related configuration form:
Add new Node
First setting is the Node name, an identifier that must be unique throughout all Nodes that are going to be defined. This identifier will be used in every link and also in Check Commands referring this node from an Icinga Service Check.
Set a title
As uniqueness sometimes leads to not-so-beautiful names, you are additionally allowed to specify a title. This is what the frontend is going to show:
Node Title
Choose an operator
Every Business Process requires an Operator. This operator defines it’s behaviour, this specifies how it’s very own state is going to be calculated:
Operator
Specify where to display
The form suggests to create a Toplevel Process. It does so as we are about to create a new root node. We could alternatively also create a sub process. As we are currently not adding it to another Node, this would lead to an Unbound Node that could be linked later on.
Node Display
Provide an optional Info URL
One might also want to provide a link to additional information related to a specific process. This could be instructions with more technical details or hints telling what should happen if outage occurs. You might not want to do so for every single Node, but it might come in handy for your most important (top level?) nodes:
Node Info Url
That’s it, your are ready to submit the form.
First Business Process Node ready
You are now shown your first Business Process Node. A red bar reminds you that your pending changes have not been stored yet:
First Node created
You could now Store the Configuration or move on with adding additional nodes to complete your configuration.
Hint: the blue arrow makes part of a breadcrumb showing your current position. You might want to learn more about breadcrumbs.
